Clutch Problems - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 04-25-2007, 05:35 PM Thread Starter
Talking Clutch Problems
I just bought a honda vtx1300 I put 200 miles on my bike and the clutch is starting to slip I weight 460 pounds I'm using the clutch right is there any know problems with this bike.
gixxersforlife is offline
post #2 of 24 (permalink) Old 04-25-2007, 05:39 PM
Lovin this Twin
Hooligan's Avatar
what makes you sure that its slipping?
Are you running full synthetic oil?
fill us in here?
This is gonna hurt!
Hooligan is offline
post #3 of 24 (permalink) Old 04-25-2007, 05:43 PM Thread Starter
Talking
when i get it in third and fourth gear it will go up 5 to 10 mph and then the engine just revs up.
post #4 of 24 (permalink) Old 04-25-2007, 05:44 PM
things that made the clutch go bad
1. your dragging the clutch to much/ over revving?
2. the clutch is dragging "not adjusted properly"?
3. possible malfunction?
are you able to get it covered through warranty? the answer should be YES.
post #5 of 24 (permalink) Old 04-25-2007, 05:54 PM Thread Starter
No The Clutch Is A Wareable Item The Warrenty Does Not Cover The Clutch
post #6 of 24 (permalink) Old 04-25-2007, 05:56 PM
the only normal way to blow a clutch in 200 miles if you were drag racing for pink slips.
CALL HONDA and get a manager in there customer relations department.
post #7 of 24 (permalink) Old 04-25-2007, 05:57 PM
plotts's Avatar
Sportbike: KTM 690 SM
Years Riding: A little bit.
+1 A lot of people adjust their clutches to tight, meaning not enough free play. There should be a few mm's of play at the lever (check your owners manual for specifics) If it has been to tight too long it may be to late, this is the first place I'd look. Assuming it's not hydraulic.
plotts is offline
post #8 of 24 (permalink) Old 04-25-2007, 05:59 PM
a nickel widths is about average slack.
just as a referance.
post #9 of 24 (permalink) Old 04-25-2007, 06:00 PM Thread Starter
Ok I Will Call Honda What If They Say It's Not Covered Like The Dealer Already Told Me, The Service Guy Asked Me How I Ride The Bike And I Told Him How I Ride Including No No No Holeshots
post #10 of 24 (permalink) Old 04-25-2007, 06:01 PM Thread Starter
The Clutch Is Not Hydrraulic
post #11 of 24 (permalink) Old 04-25-2007, 06:06 PM Thread Starter
I Used A Nickel To Check Freeplay And The Nickel Stays Right Were I Put It But Inorder To Get The Nickel In There To Check Freeplay I Had To Pull The Handle The The Size Of Two Nickels To Get One In There
post #12 of 24 (permalink) Old 04-25-2007, 06:08 PM
sent you my # in a PM
call me
post #13 of 24 (permalink) Old 04-25-2007, 06:37 PM
plotts's Avatar
Then its too tight, back that shit out!!!
plotts is offline
post #14 of 24 (permalink) Old 04-25-2007, 06:52 PM
go read for a while and see if others are having clutch issues
http://www.vtxoa.com/forums/search.php?mode=results
so far is seems that there might some clutch quirks with that bike
post #15 of 24 (permalink) Old 04-25-2007, 09:45 PM
I just rode it. Clutch is toast. Suggestions folks?!
post #16 of 24 (permalink) Old 04-25-2007, 09:56 PM
Buy new fibers and metals. Adjust clutch properly. If clutch gets toasted again, get a more powerful motorcycle.
post #17 of 24 (permalink) Old 04-25-2007, 10:09 PM
if it doesnt get covered under warranty.
barnett clutch plates and fibers and spring.
post #18 of 24 (permalink) Old 04-25-2007, 10:11 PM
Some people say Barnett is no good. They have always worked good for me. I can help you get a deal on metals, fibers and springs.
post #19 of 24 (permalink) Old 04-25-2007, 10:26 PM
The first Tico here!
javio1's Avatar
Sportbike: 2000 Suzuki SV650
I just read your signature, does this mean I'm in good with the Lord?
javio1 is offline
post #20 of 24 (permalink) Old 04-25-2007, 10:27 PM
He best give credit where credit is do...that shit's MINE!!...well, actually the old man used to sing it a lot
post #21 of 24 (permalink) Old 04-25-2007, 10:39 PM
ive installed barnett clutches in my bikes once the stock clutch goes, BIG difference
post #22 of 24 (permalink) Old 04-27-2007, 08:31 PM
Lovin this Twin
Hooligan's Avatar
Yep.
Buy my VTX with a good clutch and use yours for spares!
If you go with a Barnett Id go every other spring, fully loaded with Barnett springs is a tough pull.
This is gonna hurt!
Hooligan is offline
post #23 of 24 (permalink) Old 04-27-2007, 09:15 PM
Chris, any word from the lawyer?
post #24 of 24 (permalink) Old 04-30-2007, 02:56 PM
Inu
Computer Junkie
Inu's Avatar
Sportbike: 02 Katana 600
You weren't meant to have that bike.. you should donate it to me.
Inu is offline
