out of gas - Chicagoland Sportbikes
post #1 of 15 (permalink) Old 05-09-2007, 06:33 PM Thread Starter
God of Thunder
KingsGene's Avatar
Sportbike: 03 copper 'busa, 01 shadow sabre
How you found us: NESBA links
out of gas
Simple question....what's the right answer?
So, I'm cruising the highway on my Shadow Sabre, knowing full well that I'm running low on fuel and the engine starts to lose power and sputter. Is it better to:
a) go as far as you can until the engine dies, coast to a stop, switch on the fuel reserve, fire it back up and get to the next exit with a gas station.
b) switch to fuel reserve while engine is still running and hope it keeps running until you get to the next exit with a gas station.
Discuss...
<---Scott
KingsGene is offline
post #2 of 15 (permalink) Old 05-09-2007, 06:35 PM
switch to reserve while its still running, and just dont be wide open throttle untill the carbs can refill completely and you have good fuel flow. running it all the way out of gas is just dumb, you dont want to lean out the engine.
post #3 of 15 (permalink) Old 05-10-2007, 08:59 AM
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
You also don't want to walk home.
AgentofDarkness is offline
post #4 of 15 (permalink) Old 05-10-2007, 09:01 AM
OBAMA FTW!!!!1!
.:K2:.'s Avatar
Moparboy has a cell phone, so he can always call his mom for a ride
<---- Andy
Crashed Bike pictures:
.:K2:. is offline
post #5 of 15 (permalink) Old 05-10-2007, 09:06 AM
I don't, so I have to walk home (it has happened before, twice).
post #6 of 15 (permalink) Old 05-10-2007, 09:40 AM
The Violator
Troy's Avatar
Don't want to burn up a fuel pump either...
Troy is offline
post #7 of 15 (permalink) Old 05-10-2007, 09:47 AM
Back off, switch to reserve, keep cruising.
post #8 of 15 (permalink) Old 05-10-2007, 11:47 AM
Switch to reserve before running out
post #9 of 15 (permalink) Old 05-10-2007, 11:53 AM
Never fails you can't find that reserve switch while running.
post #10 of 15 (permalink) Old 05-10-2007, 12:03 PM
Pathological Thrill Seekr
Deuces's Avatar
Sportbike: Trek Marlin
Years Riding: Noob
You should be able to, it's not hard at all
Ride smart... stupid hurts.
Godspeed 788!!! We miss you!
Deuces is offline
post #11 of 15 (permalink) Old 05-10-2007, 01:07 PM
Its pretty easy to find the reserve switch, on my bike its on the left side right under the gas tank so I don't even have to take my hand off of the throttle.
post #12 of 15 (permalink) Old 05-10-2007, 01:18 PM
Or your bike is starting to sputter and you find that the reserve is already on because you forgot to reset from your last fill up.
They are all easy to find till you need it right away.
post #13 of 15 (permalink) Old 05-10-2007, 02:07 PM
SV650N
crashomon's Avatar
Sportbike: 2005 SV650SN
Years Riding: Since 1980
How you found us: craigslist
HERE's a TIP: If you find that you're already on reserve, you can start pulling the choke out to help 'richen' the mixture and keep the bike alive for up to another half mile. Bit by bit, start pulling it out as it begins to sputter. You may have to open the throttle even more, which uses fuel quicker, but at least the bike is still mobile.
I've also just let the bike die while rolling along (gear down to neutral) and coast as far as you can. You'd be suprised to see how far along you can coast after you've wicked it up to about 80mph!
On some street standards, you can remove the gas tank and carry that to the gas station (I've done this, once, after pushing my bike almost half a mile...I thought "why am I pushing this umpteen hundred pound beast along in the grass when I can simply detach the gas tank and take it with me to get gas?").
But once you've run out of gas a few times, you get religous about resetting your trip meter on the speedo to track your available mileage.
good luck.
NOTE: my tips don't apply if you have fuel injection (duh!), an electric fuel pump (dubble duh!) or your tank is impossible to remove (stupido duh!). YMMV.
crashomon is offline
post #14 of 15 (permalink) Old 05-10-2007, 02:18 PM
get a Mr. Fusion and a flux capicitor, go back in time to when you had gas....problem solved.
post #15 of 15 (permalink) Old 05-10-2007, 03:06 PM
Anyone can call his momma, her number is written on the mens room wall.
J/K
