alternator/electrical questions - Chicagoland Sportbikes
post #1 of 26 (permalink) Old 09-21-2009, 01:28 PM Thread Starter
^^^Bad for your hearing
streetracin1820's Avatar
Sportbike: 2007 gsxr 600
Trying to help out a friend/CLSB memeber, with her car. Her car sounded like (from what she told me) it cut out the other day when she got to work. So i figured id start with the most logical checking the alternator. Is there anyway to check it short of taking it off the car and having autozone or someone check it (i dont got much in the way of tools only whats needed to get by).
any other ideas on what to check. im guessing its the alternator, as usually when the car just suddenly looses power with the lights dimming, usually (at least with my past 2 cars), its been a bad alternator draining out the battery. hence why im starting with that first. except her car started up afterwork, and when her dad drove it the other day.
background i know is the battery and alternator were both replaced just under/just over a year ago, but i figure check easiest and work my way down.
thanks clsb
streetracin1820 is offline
post #2 of 26 (permalink) Old 09-21-2009, 01:32 PM
amp meter should show 13+ at the battery while running.Most shops (auto) will have a load test machine for the battery.
post #3 of 26 (permalink) Old 09-21-2009, 01:34 PM
beac83's Avatar
Sportbike: A couple
Check and make sure the belt isn't slipping. That would cause intermittent problems.
________________
beac83 is offline
post #4 of 26 (permalink) Old 09-21-2009, 01:39 PM
Being this is CLSB we'll probably need some pictures of the chick before we can correctly diagnose the problem.
post #5 of 26 (permalink) Old 09-21-2009, 01:52 PM
Pierced & tattooed freak!
GixxerDave's Avatar
Sportbike: 1999 GSX-R750
What a pig.
But seriously ... is there a chance to see some boobage?
No ... I mean ...
If the battery is drained, she's probably been driving on battery for a while, so the alternator is most likely shot. It's happened to me twice on on my Lumina. Glad to be rid of that car now.
GixxerDave is offline
post #6 of 26 (permalink) Old 09-21-2009, 02:07 PM
Teach me to Ride Please
Guess Who?'s Avatar
thanks clsb
take another battery and drive it to autozone and let them test it. I have a tester but my employ has it. If you can wait till later I can come check the battery and charging system. What year, make, and model car? Any check engine lights?
RIP ASHWIN 7/23/2009
trust me i am not the same cock sucker i was a few years ago either and so on.
Guess Who? is offline
post #7 of 26 (permalink) Old 09-21-2009, 04:20 PM Thread Starter
its a 04 chevy caviler with no lights that she saw. ill probably shoot over to her house eaither today or tommrow to start, toying with it. ill ask her and see if shes willing to drive down to you to have it checked. as long as i can get the problem figured out. it shouldnt be to hard for me to fix.
post #8 of 26 (permalink) Old 09-21-2009, 04:22 PM
check for loose or corroded connestions at the battery first, then check running voltage at teh battery as ressurection suggested
post #9 of 26 (permalink) Old 09-21-2009, 04:28 PM
Guess Who?'s Avatar
What town does she live in? I can come by there and check it out.
post #10 of 26 (permalink) Old 09-21-2009, 04:30 PM
I think that hooking it to a scope is in order.
post #11 of 26 (permalink) Old 09-21-2009, 04:34 PM Thread Starter
not sure what your meaning by that kegger but got a good feeling that its along the same lines of vcook's and xgamesboi's post
post #12 of 26 (permalink) Old 09-21-2009, 04:46 PM
your diagnostic skills are superior than Vcook. vcook is letting me down and ob1 kenobi
post #13 of 26 (permalink) Old 09-21-2009, 04:47 PM
Nope, just an attempt at some comedic flashback from days long gone by.
post #14 of 26 (permalink) Old 09-21-2009, 05:09 PM
It's Obi Wan, you hillbilly retard.
post #15 of 26 (permalink) Old 09-21-2009, 05:21 PM
ok starwars nerd
post #16 of 26 (permalink) Old 09-22-2009, 09:05 AM Thread Starter
and ouch....Laps in mind use, didnt noticed i posted this in the Cruiser section and not the 4 wheel section. Sorry mods
post #17 of 26 (permalink) Old 09-22-2009, 10:02 AM
Addicted
eE jeremy's Avatar
It could be a few things. I'd check them in this order
1) Battery, take it in to get tested. If the battery is trash no amount of charging will help.
2) Check the connections at the battery and alternator. They should be tight and clean.
3) Check the alternator belt. If the alternator isn't turning, it wont charge.
4) With a good battery connected start the car and measure the following
4a) DC voltage at the battery should be over 13 volts
4b) AC voltage at the battery should be less than 1 volt
4c) Using amp clamp, DC current should be flowing into the battery, the actual level will depend on the state of charge of the battery, but you should expect atleast 5-10amps at idle when you first start the car.
4d) Using amp clamp, AC current should be less than 1 amp.
If your AC measurements are too high you have a problem with the alternator diodes or rectifier.
If your DC voltage is good but the DC current is low i'd suspect your connections or a bad battery (but you should have already verified your battery was good before doing these tests.)
All said, most shops have battery and charging system testers and can quickly get you sorted out. I work for the leading company that produces this equipment and if all else fails you could bring the car to our facility in willowbrook
Shitty Pass Racing #513
eE jeremy is offline
post #18 of 26 (permalink) Old 09-22-2009, 03:07 PM
they looking for any software engineers?
post #19 of 26 (permalink) Old 09-22-2009, 03:13 PM
Addicted
eE jeremy's Avatar
We're looking to hire an intern, I was at an IIT career fair last week and we'll be bringing some candidates in next week. No full time positions available at this time.
post #20 of 26 (permalink) Old 09-22-2009, 03:24 PM
still need interns? i'm assuming your using assembler?
I don't have any experience to get a regular coding job cuz they want 3 years experience.
post #21 of 26 (permalink) Old 09-22-2009, 03:26 PM
Addicted
eE jeremy's Avatar
Must be proficient in C for embedded systems, experience with microchip or freescale processors preferred. Also strong knowledge of PCB schematics and circuit debugging required.
post #22 of 26 (permalink) Old 09-22-2009, 03:30 PM
Looks like TDS will have to fall back on his taxidermy skills.
post #23 of 26 (permalink) Old 09-22-2009, 03:38 PM
so its more elect engineering interns? i was thinking of getting a degree in that, later on. And i got a strong background in automotive technologies. rather do something in auto then making databases or website crap
i did C so long ago.
Do you know a company that is in willowbrook? they make handheld devices for john deere tractors. I saw them looking for software guys but didn't get a name from their job ad.
i should have interned while i was in school, doh,
post #24 of 26 (permalink) Old 09-22-2009, 03:54 PM
or driving to plainfield to moisturize odysseys back after his back waxes. like lotioning up a grizzly bear thats hairless and had to many to drink
post #25 of 26 (permalink) Old 09-22-2009, 04:09 PM
Addicted
eE jeremy's Avatar
Yeah sorry, EE or CE position. We do some work for John Deere, but that's a very very small part of our business, and we only have one guy that does it, I think it's referbing old instruments or something along those lines. It was a side business our CEO bought out like 20 years ago lol... Not sure what other company locally would do anything for them.
post #26 of 26 (permalink) Old 09-22-2009, 04:31 PM
i know john deere tractors have hand held devices to give out GPS locations on the farm and give readings of the vehicle.
So i'm assuming the ad was to do the coding for those devices.
UIC was no help in me picking a computer field. They have like 4 or 5 degrees. And the advisor was no help. oh well.
