batterytenderismyfriend!!
Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools | Display Modes |
Bike vs Winter...
I was simply wondering how often should I ride the bike through winter if I'm not "putting it away" for the winter? Obviously there will be times with snow, salt, etc. where it'll sit for a week or two, but is riding it for 10-20 miles once a week enough to keep the fluids, tires, etc in good shape?
As long as there's no snow and 30-35*+ out there I'm fine with riding so I figure I'll get to take it out at least once or twice a week. When it's not out it'll be cleaned up, sealed/waxed and under a cover, on stands.
-Ivan
Sponsored Links | |||
Advertisement |
Greg
You do not need to ride it.
Greg
Don't start the bike unless your going to ride long enough to burn off the condensation.
starting the bike stone cold is the worst thing you'll ever do to your bike.
Advertisement |
Just pull the battery and be done with it. Why bother with the rest? If you're one to push the limits with the weather, meaning the bike won't sit for more than a few months I wouldn't even say that Stabil is absolutely necessary, though it's good insurance for $10.
Yea I know but I also don't "need" to change the oil for about 30k miles or more. I just want to do what's best like we all do.
Definitely won't be doing that. I guess that's where my question comes from... how long is long enough to burn off condensation and how often should it be done through winter.
Also, I know running it through gears on the stands isn't the same as there's little to no resistance, but is it worth it at all?
Originally Posted by resurrection
View Post
-Ivan
Originally Posted by Cerk
View Post
-Ivan
Ah, well if you're riding it then you really don't have to do anything at all.
If you're going to ride it. Ride it. You don't worry about your car this much when it's cold.
If you don't need or want to ride it.
Put stabilizer in the tank. Get a battery tender. Park the bike wood to get it off the concrete or put it on stands if you can. If not. Don't sweat it.
^^^Bad for your hearing
Not to sound like an ass but are you new to chicago. 30-35+ only riding will get you riding maybe once every 2-3 weeks in the average chicago winter. Last i remember i thought chicago is typically 20-30.
IMO do what gkotlin said, Stabil the tank, battery tender on bike. and park it on wood or ive used a thicker hallway runner to get it off the cold concrete and call it a season.
Hey I used to brave the cold...with each passing year my temperature tolerance went up and up
...anybody want a whole bunch of heated gear?
time required to burn off condensation will vary from bike to bike and by how cold it is outside... that said, I would say it needs to get up to full normal operating temp for at least 15 mins to drive off the moisture
these bikes werent designed to operate at these temps and like gus said the startup will be especially hard on t he engine and moving parts of the bike... the lubrication system will be sluggish to get oil to where its needed and the fitment of the engine parts will be further off then normal causing increased wear until things get warmed up
Sweet jesus, do not run the bike thru the gears while on stands
Sportbike: R6, SV1000s, rm250
View Post
Ha, you better lug around a battery with my stuff
i used to ride through December often for about 10 years.
If the streets were dry and it was above 30 I would typically ride to work or do small errands on the bike.
This was more of a daily driver then a bike to look good so it was a little tired when I sold it (Goldwing)
Leading up to this:
The salt oxidizes the aluminum and unpainted surfaces.
If this does not matter to you Get some warm gear and just ride, If it does make sure and wash it right after your ride.
Same about the salt /oxidation goes if you are transporting a bike on a Mototote/bike carrier on the highway in the winter.
Good luck,
"D"
Leading up to this:
Good luck,
"D"
Sportbike: '07 Factory RSVR
View Post
Rapid temp changes will add a nice coating of corrosion on cylinder walls and valve seats. A few times won't hurt but continued starting in cold weather and you'll actually be able to see the corrosion.
So is it simply best to just put it away until March/April?
I like to ride through winter because I like riding, and I make sure to ride only when it's clean outside and no salt on the roads. I do still clean it up after every ride so I'm not too worried about that. Now I'm worried about starting it in the cold, but I'm assuming warming up the garage a bit (just insulated & drywalled everything) then starting the bike would be fine.
Decisions decisions.
In case I do decide to just park it for a few months (which I really don't see myself doing since I know I'll want to jump on it a few times a month when the sun pops out and roads are clear) does anyone have a link to a good set of winter storage instructions?
-Ivan
the salt never really goes away during the winter and it gets friggin everywhere.
and even if its a warm winter day with some snow melting that just means youre riding in salted water thats spraying everywhere on your bike into places not really washable.the tires are also gonna be rock hard from the cold as will the suspension, all adds up to additional handicapping placed on the bike and its rider.
as for storage, I keep mine in climate controlled conditions it get a fresh oil change just before storage and i top the gas off in the tank so there is as little exposed metal in the tank as possible and that all i do... come march or so ill go get the bikes and so far theyve started right up for me.
Originally Posted by Pilotx1
View Post
-Ivan
Highspeed ditch inspector
Years Riding: Since 2000
Originally Posted by lecchilo
View Post
!!!!!!!( y )!!!!!!!!!!!!!!!!
temp swings cause condensation, specifically cold to warm, but just sitting there it wouldnt be an issue at all
I trust people here more than random people online posing DIYs when it comes to stuff like this. I've looked and have a pretty good idea of what's needed.
I just can't seem to decide for good to store it for 4 months because we have plenty of days with sun, decent temps and no/minimum salt on the roads. That and my garage will be heated up every now and then... I guess I'll make the decision when snow falls this weekend haha
-Ivan
Just store the Dam thing. U had issues starting your zzr why take the chance during winter of screwing it up. Keep in mind no one will be looking for bikes for obvious reason weigh the pros and cons and listen to what most have said call it quits for the season
Greg
doesn't look like it or you are just having problems with reading comprehension.
Greg
Originally Posted by C2M
View Post
-Ivan
vroom-vroom
This will be my last week of riding, temps are skirting freezing, so im gonna take it out one more time to get it up to operating temps, then change the oil, and im done for the season.
2004 K1200Gt
2009 KLR650
1978 CB400A
View Post
I had trouble with the zzr because of me knowing little about bikes and nothing about carbs haha. I probably will just store it. Thanks.
Ok this will sound anal.
But you mentioned heating the garage now and then.This will also cause a rain forest in the tank and the crankcase.
Filling the tank completely will help there but after you get the garage up to temp, notice the sweat line on the engine case.This is your main concern as the inside of the engine will be dripping condensation.
I understand this leaves most people without a climate controlled storage place in a bad way. I'm just trying to help you understand the trouble stems from heat fluctuation.
View Post
What was to know about pulling the choke forward? Its one more process then a fuel injected bike
Tho to ruffle your feathers alittle you have had to winterize a bike now for two winters right? so how is this any different then the last two?
View Post
Anything I can do to help prevent the condensation inside the engine? I don't mind cleaning the bike every few days to get rid of any dust, condensation, etc. in case it forms, as well as flushing the fuel tank every week or two to ensure it stays clean and fresh. I'm mainly worried about the engine now as I'm not sure how to prevent the inside from condensation.
-Ivan
lust for bikes!
Sportbike: a prostitute
Years Riding: a prostitute
just put the bike on the corner before u have an aneurysm
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
