HELP! my bike is running terrible after front cylinder head swap!!! - Chicagoland Sportbikes
post #1 of 25 (permalink) Old 05-20-2012, 10:56 AM Thread Starter
Buell 1125's Avatar
So I replaced my front cylinder and cylinder head on my 07 SV650 and now my bike is running really weird. It sounds terrible, it is idling pretty slow, when I give it gas it barely responds. Anyone have any idea of what it could be? I am almost positive I lined up the timing marks correctly on the cams. I also smell gas like the bike is running very rich. the front header is hot so the cylinder is working. What could it be??
Buell 1125 is offline
post #2 of 25 (permalink) Old 05-20-2012, 11:13 AM
scott23's Avatar
Sportbike: 01 RC51
Your cam timing is off. Probably on wrong stroke when you lined up the timing marks
scott23 is offline
post #3 of 25 (permalink) Old 05-20-2012, 11:18 AM Thread Starter
Buell 1125's Avatar
Thats what I am hoping it is. I will check after work tonight and see. other than that I have no clue what else it could be
post #4 of 25 (permalink) Old 05-20-2012, 11:30 AM
scott23's Avatar
Sportbike: 01 RC51
Yeah you have to pay close attention to that. Guarantee that's what it is
scott23 is offline
post #5 of 25 (permalink) Old 05-20-2012, 01:18 PM
did you make sure you were at Top dead center BEFORE you took it apart? did you rotate the motor at all after that before you timed it?
post #6 of 25 (permalink) Old 05-20-2012, 08:46 PM Thread Starter
Buell 1125's Avatar
I lined up the "F" in the sight glass before I took everything apart and it remained there ever since. I am about to take off the cylinder head cover and check the timing again to see if I did it wrong.
post #7 of 25 (permalink) Old 05-20-2012, 10:10 PM Thread Starter
Buell 1125's Avatar
OH MAN! my timing was terribly off! I must have not been at TDC. It is all good now and purring like a kitten! thanks guys!
post #8 of 25 (permalink) Old 05-20-2012, 10:49 PM
Lucky you are,as to get off so easy.
post #9 of 25 (permalink) Old 05-21-2012, 06:21 AM
Haha, exactly. Working on low compression engines is nice sometimes. lol
post #10 of 25 (permalink) Old 05-21-2012, 02:51 PM Thread Starter
Buell 1125's Avatar
yes I am very lucky I didnt bend a valve or anything. probably because it only ran for like 2 minutes like that
post #11 of 25 (permalink) Old 05-21-2012, 03:01 PM
I'm always double, quadruple check. Walk away then come back and check it like 10 more times. LOL! My timing check usually involves rotating the motor about 100 times.
post #12 of 25 (permalink) Old 05-21-2012, 03:09 PM
Good bit of luck there !
post #13 of 25 (permalink) Old 05-21-2012, 03:32 PM
I do the same thing.....
post #14 of 25 (permalink) Old 05-21-2012, 03:38 PM
A good double check is going through a valve clearance check.
For the most part if you can fit a shim in there with the crank ref. right your golden.
post #15 of 25 (permalink) Old 05-21-2012, 03:39 PM
As a side note the assembly and clearance check on an sv has some difference's as to ref.
post #16 of 25 (permalink) Old 05-21-2012, 06:49 PM Thread Starter
Buell 1125's Avatar
The thing is I swear I checked like 6 times, I just cant believe how the timing marks were lined up it was terrible I dont know how that could have happened lol I guess I shouldve checked one more time.
I took her for a ride and everything is all good!
post #17 of 25 (permalink) Old 05-21-2012, 06:52 PM
Most people don't know you have to time cams with the crank. They don't just time to each other.
post #18 of 25 (permalink) Old 05-21-2012, 07:03 PM
Addicted
eE jeremy's Avatar
did you remember to tension the timing chain once it was lined up and before you turned the motor over?
Shitty Pass Racing #513
eE jeremy is offline
post #19 of 25 (permalink) Old 05-21-2012, 07:42 PM Thread Starter
Buell 1125's Avatar
yes, the SV's have an automatic tensioner. Everything is all good now but my radiator is leaking for some odd reason. IT NEVER ENDS AHH
post #20 of 25 (permalink) Old 05-21-2012, 07:51 PM
Sportbike: 08 gsx six fiddy F
How you found us: forum link
Il give ya 100 bux for it.
2008 Suzuki gsx 650f.
Thomas Jefferson
michowski is offline
post #21 of 25 (permalink) Old 05-21-2012, 08:06 PM Thread Starter
Buell 1125's Avatar
lol I can buy another radiator for 100!
post #22 of 25 (permalink) Old 05-21-2012, 08:08 PM
Ain't that a bitch when it's hard to get off?
Nice save
post #23 of 25 (permalink) Old 05-21-2012, 08:10 PM
Ok I hear ya loud and clear, $75
Thomas Jefferson
post #24 of 25 (permalink) Old 05-22-2012, 10:25 PM
scott23's Avatar
Sportbike: 01 RC51
you mean its not magic? haha
scott23 is offline
post #25 of 25 (permalink) Old 05-22-2012, 10:43 PM
Dude, i think I have 10,000 miles on the mustang motor and I haven't turned the starter yet LOL
