With all the conversation going on about rear-end collisions and riding tactics…..
I thought I would capture a few techniques I have used of many years of riding to stay safe on the street.
The things that will hurt you are... a high speed impact with a fixed object ( leaving the roadway ),
a high speed impact with a vehicle that took away your path of travel or getting struck by a vehicle at speed.
Falling down on your own is small potatoes by comparison.
STOPPING AT LIGHTS
Getting struck from behind by a vehicle at speed will cripple or kill you.
There are a few things you can do to avoid this.
I normally ride in the left wheel track of the car lane. As I finish my stop I go to the center of
the lane ( carefully as this can be slick especially at stoplights ) then stop with my front wheel
in the left track, rear tire in the center with the bike at a bit of an angle in the lane. Why ?
1. It makes the side profile of your bike more visible from behind.
2. At a slight angle, your left rearview mirror now looks straight down the lane behind.
3. It angles the bike so that if you move you go to the left of the vehicle ahead of you.
Leave adequate space in front of you to do this.... do not get too close the car in front.
Once stopped, I leave the bike in first gear, clutch in ready to move and watch the traffic behind
me intently….. until one or two cars are completely stopped behind me.
Then, if it’s going to be a long light I might put the bike in neutral and let the clutch out.
INTERSECTIONS…..
There are two primary threats at an intersection….
The LEFT turner….. Approaching vehicle turning left into your path.
If I am riding behind a car on a two-lane street or in the left lane on a
multi-lane street I move to the extreme left of my lane so that the car
in the left-turn lane can clearly see my headlight. The WORST place to
be is behind a vehicle that obscures the turning cars view !
If I am in the right lane on a multi-lane street I try to use a car in the left lane
as a blocker as I approach the intersection…so that a left turner would have to
drive through the car in the left lane to get to me. You cannot ride NEXT to
a car in the left lane….. here’s why.
RIGHT TURN ON RED -- > Vehicle coming from right, right turn on red into your path.
SO you are in the right lane riding NEXT to your blocker in the left lane…..all good
now right ? Wrong. Soccer-mom rolls the stop and turns right on red and pulls
out in front of you at 5MPH….. choices ? hit soccer mom or evade left….. oops.
Lesson ? If you are going through an intersection ( or a shopping district with driveways )
you have to leave a GAP in the left lane you can slip into if your path is obstructed.
Position yourself next to this gap. My Preferred spot is LEADING the car in the left
lane by a little…. so I can see them in my left mirror….. if things go bad I can steal
their lane and evade.
LEAVING THE ROADWAY
This will get you dead…. in fact, cause of death in most single-vehicle MC accidents
is left road, hit solid objects. This occurs because you get into a corner too hot and
convince yourself you cannot make it.
This is what you must do…..
Brake hard in a straight line, pick the spot where you must turn in
When you get there…..
FADE off the brakes
LOOK through the corner to the exit < ----- This is hard
TURN --- DAMMIT TURN !
All this while the bike is shedding speed and decreasing the angle of
impact ( running straight is never good ). And now if you are *actually*
too fast you may grind parts, lose grip or lowside but with the turn partially
behind you it reduces the speed of impact and the distance to fall.
Maybe you learn something about what your bike can *actually* do !
Hope this gives you something to think about…… I know I am thinking *all* the time.
STOPPING AT LIGHTS
INTERSECTIONS…..
LEAVING THE ROADWAY
FADE off the brakes
