Chain/Sprocket help - Chicagoland Sportbikes
post #1 of 72 (permalink) Old 03-05-2010, 12:43 PM Thread Starter
Chain/Sprocket help
Alright....I need some help please
I want to change out my chain and sprocket, covert to the 520
I have NO CLUE what to get, I know or think that I have to get a certain size for my bike and all
So, can anyone help and tell me what I need?????
I have an 07 CBR 600rr
TIA!!!!
Shelly
post #2 of 72 (permalink) Old 03-05-2010, 12:45 PM
520 front sprocket
520 rear sprocket stay away from the aluminum ones for longer life
520 chain
youll need a chain tool and the know how to use it as well if youre doing it yourself
http://stores.sportbiketrackgear.com...+and+sprockets
post #3 of 72 (permalink) Old 03-05-2010, 12:49 PM Thread Starter
Really?? That easy??? I'm stupid!
Oh wait, maybe I should've added that I want to change the gearing....prolly 1 down in the front
So still just get what you posted Jason?
Shelly
post #4 of 72 (permalink) Old 03-05-2010, 12:51 PM
not stupid just uninformed. big difference
they give you all the options for gearing under the sun at that link, they will even call you and help you figure out what you need if you choose contact me in the teeth count bars
post #5 of 72 (permalink) Old 03-05-2010, 12:51 PM
Sportbike: 08 gsx six fiddy F
How you found us: forum link
Yes still get the same size gears and get what ratio you want. You then just have to adjust the tension on the chain before you go out. Pretty straight forward process.
2008 Suzuki gsx 650f.
Thomas Jefferson
michowski is offline
post #6 of 72 (permalink) Old 03-05-2010, 12:52 PM
Fat guy on a sport bike
Pocket Rockets's Avatar
Sportbike: Schwinn
How you found us: ask.com
I'd probably keep the front the same and go up in the rear. going -1 in front roughly equals +3 rear
Pocket Rockets is offline
post #7 of 72 (permalink) Old 03-05-2010, 12:52 PM Thread Starter
Thanks
Shelly
post #8 of 72 (permalink) Old 03-05-2010, 12:54 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
How you found us: No idea
Kevin at Safety First was having a sale on 520 chains and sprockets...maybe call him for the stuff
https://www.chicagolandsportbikes.com...84#post1660784
Nexus is offline
post #9 of 72 (permalink) Old 03-05-2010, 12:56 PM
Sportbike: Schwinn
CP also beat any price I could find for my 520 kit
post #10 of 72 (permalink) Old 03-05-2010, 12:56 PM
Talk to Kevin at Saftey First or Ken at Chicago performance.
I just bought new pit bull sprockets front and rear for my marchesinis and tsubaki gold racing chain for under $200
post #11 of 72 (permalink) Old 03-05-2010, 01:00 PM
post #12 of 72 (permalink) Old 03-05-2010, 01:02 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
Sweet now you have spare rims that might fit my bike for REALLY cheap? :P
Nexus is offline
post #13 of 72 (permalink) Old 03-05-2010, 01:05 PM
Nope I traded 2 sets of rims and rotors and cash for the Marchesini's. So I only have one set of rims now.
post #14 of 72 (permalink) Old 03-05-2010, 01:08 PM
oh btw, im just showing you what needs to be bought to do the conversion you want to do, not suggesting which actual product you should buy as i have no idea myself
post #15 of 72 (permalink) Old 03-05-2010, 01:21 PM
Sportbike: '08 Honda CBR1000rr
Doing a 520 conversion isn't hard, but it helps a lot to know a few of the tricks and tips. Having the OEM shop manual handy is always a good idea.
I'm actually in the process of writing another one of our "How to" articles to add to our collection of maintenance articles on the Turn One Racing website, but since it isn't finished yet, so I'll throw a couple of things out there for you.
First of all, you need to start with quality components, which of course, I prefer to get from Turn One Racing http://www.turnoneracing.com/Chains-and-Sprockets-c32/ But I'm kind of particular that way :-)
If you have access to an impact gun, that makes the whole job a lot easier, not to mention faster. If you don't, that's okay, just be prepared to need a friend to help steady the bike and/or stand on the rear brake while you remove and replace the front sprocket.
You can break the chain with the chain breaker tool, but it comes off faster and easier with a grinder, or even a Dremel with a cut off wheel. Make sure to wear safety glasses for this part.
If you don't have an impact gun and access to an air compressor, don't cut the chain until you've loosened the front sprocket nut, because you'll need the chain on the sprocket to hold it tight while you break the front sprocket nut loose.
And if you don't have an impact gun, you'll need a long breaker bar to loosen the front sprocket nut, you may also need a friend to steady the bike so it doesn't fall over while you crank on the nut.
Also, a 2x4 in the rear wheel between the swingarm/rear stand and the wheel arm to keep the wheel from moving past the swingarm will help lock everything in place while you lean on the breaker bar.
Once you get the front sprocket loose, you can cut the chain and pull the rear sprocket as well.
While measuring your chain, consider where you want the wheel to sit with your new gearing. The longer the wheelbase the more stable the bike will be, but keep in mind the chain will stretch a little as it breaks in.
If you're not going to be changing sprockets back and forth for different situations, then just set the length in the middle of the range and stick with it.
Double check the chain length before you mount it, it's the old "Measure twice, cut once"
Make sure you properly tourque all your sprocket nuts, and set your chain tension, being careful to keep the rear wheel in line.
Pump your rear brake before you ride, and best of luck!
Marshall Skloss
CCS#19 ASRA#191
Midwest Trackside Vendor and Support
www.TurnOneRacing.com
Comprehensive Track Bike Preparations, Modifications, and Repairs
Sklossmonster is offline
post #16 of 72 (permalink) Old 03-05-2010, 02:34 PM
ThirdgenTa's Avatar
Sportbike: 2001 zx6
How you found us: Search
I have a chain cutter if you need to borrow it.
ThirdgenTa is offline
post #17 of 72 (permalink) Old 03-05-2010, 02:38 PM
I recommend these guys:
http://www.drivesystemsusa.com/ In addition to the good advice you get on here, these guys will tell you what you need to know.
here is a kit for your bike. If you want to chance the gearing, just tell them what you want:
http://www.drivesystemsusa.com/p/593...0rr-03-09.html
post #18 of 72 (permalink) Old 03-05-2010, 02:53 PM
Shelly,
once you get your parts, bring your bike over - I have all of the needed tools and I will walk you through the change. Ive done it for 2 other people on the site, its really easy. A couple of other things we will need are the torque setting for the counter shaft nut, and I typically replace the counter shaft nut with a new one while I am in there.
post #19 of 72 (permalink) Old 03-05-2010, 03:11 PM
d0 work s0n!
paintedblue's Avatar
Sportbike: '06 GSX-R
+1 picked up my 520 from Kevin last month.
Or you can use this link which i got from Steve...
http://www.indysuperbike.com/customer/product.php?productid=1000000
#910
paintedblue is offline
post #20 of 72 (permalink) Old 03-05-2010, 03:22 PM
Shelly,
I might take you up on this offer as I don't have a chain breaker and/or a chain tool.
post #21 of 72 (permalink) Old 03-05-2010, 03:23 PM
No probs man!
post #22 of 72 (permalink) Old 03-05-2010, 03:24 PM
d0 work s0n!
520 Party?
I need to have my changed out too.
#910
post #23 of 72 (permalink) Old 03-05-2010, 03:29 PM
Originally Posted by paintedblue View Post
520 Party?
Im here for the gangbang.
post #24 of 72 (permalink) Old 03-05-2010, 03:31 PM
d0 work s0n!
Ha...i'm waiting for wink's tech day but i'm up for doing it earlier if anyone has the tools.
#910
post #25 of 72 (permalink) Old 03-05-2010, 03:51 PM
Safety First's Avatar
I've got them in stock and we use Pit Bull sprockets.....as durable as their stands!
Go 1 down in the front and either 1 or 2 taller in the rear. I like 1 taller in the rear personally. Bike accelerates quicker but doesn't lose any topend and doesn't buzz the crap out of your hands going down the road.
847-357-1309
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
Safety First is offline
post #26 of 72 (permalink) Old 03-05-2010, 03:54 PM Thread Starter
Thanks everyone for all the info, I just need to figure out what size sprockets I need and then I'll shop around!
Originally Posted by auditech View Post
Ha, nice...but that's not the right pink
Shelly,
Thanks Kegger!! I will get it all and then we'll figure it out
520 party And it'll be in a garage...so the side is not that far away
Shelly
post #27 of 72 (permalink) Old 03-05-2010, 03:57 PM
d0 work s0n!
Keep me posted.
#910
post #28 of 72 (permalink) Old 03-05-2010, 03:59 PM
Great, now that you put it that way, we will have people lined up around the block waiting for their turn.
post #29 of 72 (permalink) Old 03-05-2010, 04:17 PM
post #30 of 72 (permalink) Old 03-05-2010, 04:19 PM
Kegger, I have about 6 bikes for you to do as well.
