Yamaha waverunner repair help - Chicagoland Sportbikes
post #1 of 4 (permalink) Old 06-18-2010, 01:33 PM Thread Starter
boilermaker's Avatar
Sportbike: 98 FZR 600
How you found us: the interweb
So I get a call from a buddy last night and got roped into putting his waverunner back together. I don't know the full story, but someone else tore it apart looking for a problem that wasn't there....
This is the first watercraft I have worked on but it seems to only need basic work right now. Either way I need to put the manifold and a few head pipes back on. I am looking for a repair manual and some parts diagrams. (Can anyone help with those?) I am going with the assumtion that any gasket that was touched will need to be replaced even if they look good. The waverunner is a Yamaha XLT 1200 from 2002 or 2003. I also found a model number on hte inside sticker saying it was a xa1200a-a.
I can handle simple bolting on of parts, but might need advice if it doesn't start. It hasen't seen water in 3 years, and my buddy is the one who winterized it last. I know I have to do the usual of fluid changes and fuel system cleaning since he doesnt know what fuel stabilizer is.
He showed me a place I can connect a garden hose to so that you can run the motor as much as you like without it being in water. Any truth to that? Otherwise what is the longest I should run it since it won't have lake water to cool the motor.
Thanks all.
98 FZR600R
boilermaker is offline
post #2 of 4 (permalink) Old 06-18-2010, 01:43 PM
Greg
gsd656's Avatar
Thanks all.
Not long at all, a few minutes at most.
Greg
gsd656 is offline
post #3 of 4 (permalink) Old 06-18-2010, 01:44 PM
Greg
gsd656's Avatar
I know you plan on working on it yourself, but here is a thread about some local shops incase you change your mind or need advice.
http://www.pwctoday.com/f70/what-bes...is-283317.html
Greg
gsd656 is offline
post #4 of 4 (permalink) Old 06-18-2010, 02:19 PM
I work on my own PWCs, no big deal. The only problem is that the access to work in the confined area is a PITA.
Related to the hose, be sure to read your manual. Mine says not to run it on the hose more than 20 seconds at a time. A hose CANNOT deliver the same volume of water that the water intake does, so you can EASILY fry the engine.
There are some good forums out there for PWC, I use Green Hulk myself.
Download a Service Manual or buy one and get started. I have two here at home at the moment, just finished getting one working, need to get the other one working now.... maybe this weekend if the weather holds out.
Good luck!
