Fack me, Electrical wiring question - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 08-16-2012, 01:54 PM Thread Starter
Hokay so yesterday wife unplugged one of my water pumps in the laundry room which the outlet shares a connection to the outlet with the TV on the other side of the wall.
The TV flickered out and that outlet as well as two other family room outlets no longer work. Now the laundry room outlet still functions and there is a burn mark on the outlet from where the power strip was plugged into.
Thankfully the TV equiptment didn't get burnt out and I have an extension cord running to the bathroom so I can get my TV on.
I checked the fuses and none were "tripped"
Any other suggestions for what I should look for?
post #2 of 8 (permalink) Old 08-16-2012, 02:00 PM
Wisconsin FIB
TripleZ's Avatar
Years Riding: Since June 2002
How you found us: Pilotx1
Flip the breaker and pull the outlet cover off. Then pull the outlet out, my guess is a break in either a connected wire, or the tiebar on the side of the outlet. If you have a spare outlet, replace it right away.
TripleZ is offline
post #3 of 8 (permalink) Old 08-16-2012, 02:01 PM
I'm not an electrician, but I've had to deal with flaky wiring in the house plenty.
The breaker could be bad, or the outlet didn't arc enough to trip the circuit.
You could verify the circuit breaker by swapping the one going to the burnt outlet with one from another circuit, making sure they are the same amperage.
I wouldn't plug anything into that outlet till the outlet is replaced, and the wiring verified.
Do you have an outlet tester?
I can help you swap this out this weekend if you can wait.
post #4 of 8 (permalink) Old 08-16-2012, 02:07 PM
didn't you say you're an electrical engineer?
take a multi meter, set to ac and test that outlet. Also take out the outlet and test the wires going to it. There should be a wirenut there that has wires going to the other outlet in that box.
Possible that outlet is overloaded. You could have burned out the outlet, or even the wiring. See how much amperage is that water pump. Also, is the washer and dryer on the same circuit?
post #5 of 8 (permalink) Old 08-16-2012, 03:49 PM
2wheelinn near the dragon
ninjaridaz's Avatar
Sportbike: Kawasaki Concours 14
How you found us: cog forum
Something not right. Laundry circuit is supposed to serve the laundry only. Sometimes breakers trip, but don't look like they have tripped. Definitely check out the outlets involved and whatever wiring and splices you can see. Don't forget to flip the breakers off and verify they are off before taking anything apart.
ninjaridaz is offline
post #6 of 8 (permalink) Old 08-16-2012, 04:09 PM
outlets near water are often GFCI, when one of these craps out and is no longer tripping right it will kill power to the outlets downline from it. Laundry room = water. Water = GFCI. GFCI = fails over time. Failure = no power to your tv.
post #7 of 8 (permalink) Old 08-16-2012, 04:15 PM Thread Starter
quick response. I have been on the PC for about half an hour today. been passed out on the couch sick.
The house is 19988 and RETARDEd. Example. The downstairs fishtank and bathroom and fused into the Upstairs bathroom.
They skipped on the GFCI in the laundry room sadly. I had that same idea chris.
I will figure out which fuse it is because heres where it gets tarded. The Laundry room still had power to it last I checked... But the other outlets were dead. I am hoping I can find the fuse and get that bad plug out as directed. I will also test the fuse switched with another to see if that fixes.
I ilke how my time was better spent asking my peeps on here rather than trying to google-fack the answer. Thank you guys.
Time to go pass out again
post #8 of 8 (permalink) Old 08-16-2012, 04:18 PM
electrical done right is dead easy to work on and diagnose. however it sounds like a moron wired your house and you got circuits stretched all over the place, lord knows how its all junctioned out too.
