Hobbyist Tig Welder - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 03-02-2013, 04:50 PM Thread Starter
Hobbyist Tig Welder
Curious about if I wanted to snag one, what am I looking at for cost. etc.
Main job is for doing pinning barrels.
http://www.ar15.com/forums/t_3_4/391053_.html
And I figure some small fun projects for myself.
Anyone have any direction for me to research/brands, etc.
post #2 of 8 (permalink) Old 03-02-2013, 06:00 PM
a tig welder made by a known company will generally run about 1k+ and will also require you to have a tank of argon hooked up to it, figure another 2-3 hundred if you want to buy that, rental is an option but I dont know those rates. A tig will also generally require a 3 phase power source
TIG will allow you to weld both steel and aluminum given the correct settings and setup but aluminum is a tricky bitch just a warning
in the link you provided the guy used a mig welder, which if used with flux core wire will not need a gas bottle, solid steel wire will require a bottle of c02 at minumum and preferably a bottle of mixed gas 80/20 carbon/argon which helps to reduce spattering.
a good "home" sized welder of this sort will run about 400-500. this type will run on standard 110v
the mig welder(wirefeed) will generally limit you to working with steel though. this would be my recomendation strongly if the primary use is pinning, esp with the flux core wire since you are only doing tack welds with less than a second of on time each. if you wanna give this a try let me know
if youve seen pictures of my past welding work it was all done with a mig welder running flux core wire.
post #3 of 8 (permalink) Old 03-02-2013, 07:34 PM
Jason, can you be a little more specific?
Lol, J has mad welding skills, props.
post #4 of 8 (permalink) Old 03-02-2013, 08:43 PM
Ride Naked
mac11's Avatar
Sportbike: z1000
JAsons stuff is good but I will add that there are a lot of small tig welders - <250 Amps - that run off single phase 220V power.
But yea for the job you want to do a Mig welder that runs off 110V will do you just fine, are a lot easier to procure and easier to get up and running on.
This guy has run a bunch of welds on the Everlast welder side by side with the Blue and Red machines. I think the general conclusion i can draw is that for hobbyist or home guy it would be a good economical choice, but its worth spending the extra for the bigger brands when you are doing it every day.
http://www.weldingtipsandtricks.com/...ss-welder.html
mac11 is offline
post #5 of 8 (permalink) Old 03-03-2013, 03:39 AM
With your mom.
Sportbike: bigwheel
How you found us: referred for some reason..
Send a message via AIM to Gamble
What do you want to know? I tig weld almost daily and have 7 welders currently.
I can't see that link, it's blocked at work.
90 ex500 (Sold)
02 F4i (Sold)
92 F2 (Sold)
04 600RR (Sold)
01 ex500 (Sold)
93 vulcan 150 (Sold)
92 GSXR 750 (Sold)
94 Ex500 - Current
Gamble is offline
post #6 of 8 (permalink) Old 03-03-2013, 03:45 AM
I am the Stig.
JRobbins's Avatar
You're at work at 2:39 am? Also... can you weld titanium?
JRobbins is offline
post #7 of 8 (permalink) Old 03-03-2013, 04:04 AM
With your mom.
Sportbike: bigwheel
Yep i work 11:45pm to 12:15pm.
I've never tried titanium, so I'll say no. lol
I mainly do aluminum. Going to try building a SS manifold as my next project.
90 ex500 (Sold)
02 F4i (Sold)
92 F2 (Sold)
04 600RR (Sold)
01 ex500 (Sold)
92 GSXR 750 (Sold)
94 Ex500 - Current
Gamble is offline
post #8 of 8 (permalink) Old 03-03-2013, 07:23 AM
SL954's Avatar
Sportbike: Not really
Years Riding: many
A lot of good info on weldingweb.com
SL954 is offline
