Oops... - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 02-03-2004, 12:06 PM Thread Starter
Head Stepper
Pirate's Avatar
Sportbike: TREKK
Years Riding: 9
Oops...
I need some help here.
Due to the cold Chicago weather and the moisture that fell from the sky last night, my windshield was coated with a crunchy substance. I turned on my wipers to remove said obstruction, but the wipers were stuck to the windshield. O.K. fine, so I got out of the car, and did the manual "lift and let slam" ice removal technique... Well, what I didn't do was turn the wipers completely off. So, as I was walking around to the other side of the car to get the opposite wiper, they tried to swipe again. Well, one side went, and the other blew up. It shook for a second, (I'm assuming while stripping the entire inards of the mechanical structure). So, now one side works, and the other side just lays there placid.
So my question is, how expensive do you think it is to replace the ww motor, or the arm if that's what's stripped... and is it a "do-it-yourself" kind of thing?? What about just tieing a string to the working wiper and using it as sort of a splint??
Any ideas?? Thanks.
<-------- Jeff
Pirate is offline
post #2 of 24 (permalink) Old 02-03-2004, 12:08 PM
if the drivers side still works you are money.
post #3 of 24 (permalink) Old 02-03-2004, 12:08 PM
That's just too funny!!!!
post #4 of 24 (permalink) Old 02-03-2004, 12:20 PM
a splint on a wiper arm? Its official ! Ive now heard it all !! !!
post #5 of 24 (permalink) Old 02-03-2004, 12:21 PM
MoTo178's Avatar
Sportbike: 1998 CR 250
Years Riding: Dirt: 1988 Street: 2001
Send a message via AIM to MoTo178 Send a message via MSN to MoTo178 Send a message via Yahoo to MoTo178
you may just need to take the arm off and realign something. like if the gears arent lined up from slipping? I dunno.
Even if its the drivers side not working, you can just lean over and look out the passanger side
Sean
NESBA ADVANCED #178
MoTo178 is offline
post #6 of 24 (permalink) Old 02-03-2004, 12:21 PM
maks's Avatar
Sportbike: 2002 CBR F4i
I read somewhere about someone doing this same thing and it just loosened the screw where the wiper is attached at the base. Maybe you'll get lucky and that's all that happened?
maks is offline
post #7 of 24 (permalink) Old 02-03-2004, 12:28 PM
Yes, that happens. You may have just lost a pin or got a screw loose. ......well we know ya got a screw loose Anyway, try to take it apart and look to see what's wrong. It shouldn't be that hard even if ya got to replace the mechanism
post #8 of 24 (permalink) Old 02-03-2004, 12:33 PM
Re: Oops...
Originally posted by Pirate
...moisture that fell....was coated with a crunchy substance.....
turned on....and did the manual....blew up.... shook... ...lays there placid....
are you trying to tell us something?
VIVID1 is offline
post #9 of 24 (permalink) Old 02-03-2004, 12:39 PM
Leave the poor guy alone. It CAN happen.
MeggysGixxer is offline
post #10 of 24 (permalink) Old 02-03-2004, 12:40 PM
Re: Re: Oops...
way to drag it into the gutter
Anyway, you should loosen the arm at the base and check to see if you stripped the splines on the shaft. you may be able to clean it out and put it back on and have it work.
post #11 of 24 (permalink) Old 02-03-2004, 12:42 PM
A string splnt will only work for the first pull...you need to push the wiper back
post #12 of 24 (permalink) Old 02-03-2004, 12:43 PM
Re: Re: Re: Oops...
hold on, I can do better.... watch when I change the order of the words a little:
turned on and did the manual, blew up, shook, lays there placid was coated with a crunchy substance moisture that fell
I think he is sending us a subliminal message
VIVID1 is offline
post #13 of 24 (permalink) Old 02-03-2004, 12:44 PM
post #14 of 24 (permalink) Old 02-03-2004, 01:03 PM
Labdog's Avatar
Before you get carried away just lift the hood and check if the motor is driving the center post/arm stud. You might have a stripped/loose set screw.
Check the easy stuff on your own. If its the passenger side let it go till it warms a touch.
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #15 of 24 (permalink) Old 02-03-2004, 01:12 PM
Re: Re: Re: Re: Oops...
post #16 of 24 (permalink) Old 02-03-2004, 06:26 PM
Dude, in all seriousness.
Just throw away the car, its never gonna work again
post #17 of 24 (permalink) Old 02-03-2004, 09:02 PM
OK take the broken wiper off and see if the splines on the ARM are ground off. The splines on teh shaft are usually steel and dont strip easily. Thats USUALLY. Some cars have soft pot metal splined shafts. IF teh shaft is fine, then look at teh part of the wiper where it goes. IF those teeth are shot, go to a bone yard and get another one. Shafts a bit more fun to replace but is not all that bad. Might have to remove the cowling to access it.
post #18 of 24 (permalink) Old 02-03-2004, 10:44 PM
Cali's Twisty Tamer
Nickyfan's Avatar
Sportbike: '96 CBR F3
Years Riding: since 98
How you found us: met at Strat's
Start by checking the splines on the arm, that's the easiest since it's on the outside of the car. If that checks out ok then check to see if the drive arm(it's like a drag link for your wipers) is attached to the motor if it is then check to see if it is attached to the driven side that doesn't work. My bet is that it popped off at one of these two places, not uncommon.
The optimist believes that we live in the best of all possible worlds...
The pessimist fears this to be true.
<----Shane
Shane's Facebook
Nickyfan is offline
post #19 of 24 (permalink) Old 02-03-2004, 11:03 PM
Well he can use a shock cord to pull it back...
Blade Runner is offline
post #20 of 24 (permalink) Old 02-04-2004, 12:45 AM
I'll trade ya a lincoln for it. Wipers work great!!
YTRAP is offline
post #21 of 24 (permalink) Old 02-04-2004, 12:57 AM
yo quiero su taco
whiteSeatEnvy's Avatar
nice
whiteSeatEnvy is offline
post #22 of 24 (permalink) Old 02-04-2004, 06:13 AM
Do what I do.......don't drive when you need wipers The car gets dirty, then you have to clean it, it's a pain, trust me I had a Toyota Corrolla that I drove for 2 years, that didn't have reverse, or 2nd and no wiper functions. I had to be careful where I parked Driving in the hard rain was a biatch, I did that by "feel"
post #23 of 24 (permalink) Old 02-04-2004, 08:04 AM
Cali's Twisty Tamer
Nickyfan's Avatar
AAAAHHHH the brail method, know it well
<----Shane
Shane's Facebook
Nickyfan is offline
post #24 of 24 (permalink) Old 02-04-2004, 09:51 AM
Well Rick also had his cane out the window also.
Rick probably has a full cab on his walker.
