Clutch holding tool - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 04-26-2014, 11:43 AM Thread Starter
El Burrito Volador
spyder84's Avatar
Years Riding: I'm a rookie.
Clutch holding tool
Anyone in the Aurora area have a clutch holding tool I can borrow? A pack a beer of your choice in return.
Thanks in advance.
Erik
05 GSXR600
spyder84 is offline
post #2 of 8 (permalink) Old 04-26-2014, 05:54 PM Thread Starter
El Burrito Volador
spyder84's Avatar
Anyone? If not, does anyone know where I can purchase one other than online?
Erik
05 GSXR600
spyder84 is offline
post #3 of 8 (permalink) Old 04-27-2014, 09:11 AM
Derick's Avatar
Sportbike: R6
DGR should sell them. if you have air tools you dont need one. Put it in gear, then put a 2x4 through the wheel braced against the swing arm. I managed to get the nut off that way, with no air tools
WERA CCS EX #169
Riders Discount AllBalls Racing Woodcraft VinylSaurusRex Pit Bull Chicken Hawk Racing
Derick is offline
post #4 of 8 (permalink) Old 04-27-2014, 09:35 PM
You can make one using a steel plate and welding a screwdriver to it or by bolting a fibre plate and steel plate together. I jam an oil soaked shoprag into the primary drive gears to hold things snug and I've never broken a gear tooth in 40 years. It holds enough to get the torque you need to pop the nut loose but is soft and gives enough to prevent damage. Just make sure you clean any rag bits out of the gear teeth.
Derick's 2x4 trick sounds like it would work too. Good luck.
OldTimeBiker is offline
post #5 of 8 (permalink) Old 04-28-2014, 09:43 AM
a ratchet strap, minus the ratchet wrapped around the basket and hooked to the frame will also work in a pinch, make sure that the direction of it winding up onto the basket is the same direction as the direction of loosening the nut, assuming you lack the above suggestions
post #6 of 8 (permalink) Old 04-28-2014, 04:09 PM
I have one. You're welcome to come get it and leave a cash deposit.
post #7 of 8 (permalink) Old 04-28-2014, 08:52 PM Thread Starter
El Burrito Volador
spyder84's Avatar
Thanks all. I ended up buying one online.
Erik
05 GSXR600
spyder84 is offline
post #8 of 8 (permalink) Old 04-29-2014, 11:42 PM
Blap Blap........LOL
I've always gotten away with the air gun.
