Calling VB coders, stupid question for u's - Chicagoland Sportbikes
post #1 of 5 (permalink) Old 09-22-2005, 11:55 AM Thread Starter
Trying to get a bunch of IF's to run basically to show an address all nice and pretty, otherwise if I simply set the fields within Crystal reports then there are gaps sometimes. So my original code was...
{Command.CUSTOMERNAME} & chrw(13);
if {Command.ADDRESS1}<> "" then {Command.ADDRESS1} & chrw(13);
if {Command.ADDRESS2}<> "" then {Command.ADDRESS2} & chrw(13);
if {Command.ADDRESS3}<> "" then {Command.ADDRESS3};
Why won't this work? I allow the field to grow but it seems to return only one of the Address (usually Address3) fields (the customername always displays correctly).
Finally I ended up doing it this way which seemed to do the job, but curious about what is wrong with my logic above...
Stringvar Address;
Address := {Command.CUSTOMERNAME} & chrw(13);
if {Command.ADDRESS1}<> "" then Address := Address & {Command.ADDRESS1} & chrw(13);
if {Command.ADDRESS2}<> "" then Address := Address & {Command.ADDRESS2} & chrw(13);
if {Command.ADDRESS3}<> "" then Address := Address & {Command.ADDRESS3} & chrw(13);
Address:=Address & {@Display City State Zip};
Address;
post #2 of 5 (permalink) Old 09-22-2005, 12:23 PM
I do it in the dirt!
X-SLaYeR's Avatar
Years Riding: lots
How you found us: Intarwebz
It's been awhile, but I believe the 2nd way works because it is comparing a variable. Something to do with VB's memory handling I believe.
X-SLaYeR is offline
post #3 of 5 (permalink) Old 09-22-2005, 12:33 PM Thread Starter
2nd method yes. I simply create a variable and concat on to it.
post #4 of 5 (permalink) Old 09-22-2005, 02:42 PM
WARNING! GEEK TALK INCOMING!
The way it's evaluating this statement is that it evaluates all the if clauses before it returns the value to the field. So each time it sees a {Command.AddressX} it is overwriting the previous value for the field. So if Command.ADDRESS3 is not blank, that is all that will be returned. So you would never get an address1 or customer name returned, the only values that could be returned are Address2 if Address3 is blank or address3. In crystal you have to think like the field is a string, not an output stream, which means you must store you evaluations and then return the result at the end instead of "printing" to the field as you evaluate.
flinchy is offline
post #5 of 5 (permalink) Old 09-22-2005, 02:52 PM Thread Starter
Ok, that makes sense. Although I'm pretty sure it was giving me the customername. Could it print the name and then cycle through all the IF's, or does it fly through the full function? I don't really care to go back and test, but I know I was seeing the customernames, perhaps I manually put that field in and that's what I was seeing. Oh well. Now I know. Thanks!
