Rear drum brake help??? (2001 Ford Ranger 2wd) - Chicagoland Sportbikes
post #1 of 12 (permalink) Old 10-02-2005, 03:26 PM Thread Starter
ClevisR6's Avatar
Sportbike: 04 Zuma, 06 Crf50
Years Riding: sho' nuff!
How you found us: Nesba
apon furthur inspection of the clicking/ clunking noise coming from my ranger i noticed:
1. when i rotate the rear wheel forward and then backward, the rear of the transmission makes a clunking noise. it's my understanding that rangers typically have a bit of driveline slop though.
2. there is a clunking/ dull clicking noise that occurs when going over bumps and when starting to brake. if you tap the brake when carrying some speed, it makes the noise. sounds like its coming from the rear.
i'm kind of hoping that it is something to do with the rear drum. is it possible that the ratcheting mechanism that controls the "diameter" of the shoes isn't adjusted to the diameter of the drum? then that could be making the shoe assembly slop around in there? or is that ratcheting device self adjusting? we had the rear drum apart to change the shoes btw.
ClevisR6 is offline
post #2 of 12 (permalink) Old 10-02-2005, 03:38 PM
might be in the axle
pressurluk is offline
post #3 of 12 (permalink) Old 10-02-2005, 04:27 PM
pull the drums see what it looks like in there..
post #4 of 12 (permalink) Old 10-02-2005, 04:33 PM
try using your emergency brake, going forwards or backwards and on some of them, it will adjust the shoes to the drums.
But mopars nuts about taking the drums off, it's pouring outside.
oldschoolninja is offline
post #5 of 12 (permalink) Old 10-02-2005, 04:35 PM
get a shop
post #6 of 12 (permalink) Old 10-02-2005, 04:51 PM
Originally Posted by MoparBoyy
get a shop
there not open on sundays
post #7 of 12 (permalink) Old 10-02-2005, 05:05 PM
MM Racing shop is open 7 days a week
post #8 of 12 (permalink) Old 10-02-2005, 07:33 PM
BandM's Avatar
Sportbike: X-1, XR-1000
How you found us: Badweb
U Joints?
BandM is offline
post #9 of 12 (permalink) Old 10-02-2005, 07:42 PM
Sportbike: Older one
Years Riding: Many
How you found us: browsing
Click upon stopping could possibly be shoe hanging up on faceplate. I'd open it and check to see everything is ok.
As for clunking, had you checked the u-joint on the driveshaft for play?
Skeletor is offline
post #10 of 12 (permalink) Old 10-02-2005, 09:18 PM Thread Starter
ClevisR6's Avatar
found it. the caliper bolts were loose on the front right side... which was the side that my knucklehead friend did. dumbass
ClevisR6 is offline
post #11 of 12 (permalink) Old 10-02-2005, 09:22 PM
i thought the noise was in the rear??
hey as long as its fixed.
post #12 of 12 (permalink) Old 10-03-2005, 09:17 AM Thread Starter
ClevisR6's Avatar
it sounded like it was. maybe the noise was echoing thru the bed? and i guess all that slop everywhere is normal.
b4 i went any furthur, i had a friend jump in the bed while i went for a cruz and he said it was coming from the front.
ClevisR6 is offline
