HTML question if anyone knows - Chicagoland Sportbikes
post #1 of 5 (permalink) Old 11-21-2005, 02:59 PM Thread Starter
I break everything!
JonGu's Avatar
Years Riding: Since 04/2003
I can't seem to figure this out...
I have this webpage that generates Excel reports, so after it generates the report, it presents the user with a link to the report. Whenever the user clicks on the link, it opens it as garbled text in the browser instead of opening it in excel. Even when I right-click save, the file type defaults to 'htm file' instead of 'xls file'
It only happens with Internet Explorer, and when I try to open Excel spreadsheets off the internet it does it correctly. I even tried copying the report file to my own personal web host and made a link to it and it works perfectly. Just that when it tries to pull it off our server here, it still thinks its an HTM file. And I tried adding the MIME type to the link like < a href="report.xls" type="application/msexcel" > but no luck.
The web server is Tomcat 5.5.
Post up if anyone has clues. Thanks!
Jon Gu
CCS AM/NESBA #276
JonGu is offline
post #2 of 5 (permalink) Old 11-21-2005, 03:12 PM
SV650N
crashomon's Avatar
Sportbike: 2005 SV650SN
Years Riding: Since 1980
How you found us: craigslist
Hi, you may need to configure tomcat to recognize the file type in order to serve it up properly. If its anything like apache, you simply add another mime type to make it work.
Not sure if this is your issue, but thats what I would check.
crashomon is offline
post #3 of 5 (permalink) Old 11-21-2005, 03:18 PM Thread Starter
I break everything!
JonGu's Avatar
I just thought to check that, it has "application/msexcel" mapped to .xls files, and just for shits and grins I removed the mapping and readded it and restarted the server, still no dice.
Jon Gu
CCS AM/NESBA #276
JonGu is offline
post #4 of 5 (permalink) Old 11-21-2005, 08:56 PM
In my ASP files, if I want to do something like this, I have to set the content type to excel so it specifically opens in excel. Not sure what script/lang you are using but you want to look for something that sets the content type specifically to excel for that particular script/lang. In your example you had something like that for the link..perhaps it needs to be at the page level which is what I have.
Response.ContentType = "application/vnd.ms-excel"
Perhaps just try switching this content type into your link and see if that works.
cam_neely_8 is offline
post #5 of 5 (permalink) Old 11-21-2005, 09:30 PM Thread Starter
I break everything!
JonGu's Avatar
Looks like the problem was the Tomcat just didn't want to serve up Excel files from the root directory. I made another folder and dumped the Excel files there and now they open up fine. Weird
Jon Gu
CCS AM/NESBA #276
JonGu is offline
