FM modulation: best frequency? - Chicagoland Sportbikes
post #1 of 14 (permalink) Old 01-05-2006, 11:03 AM Thread Starter
For those that use fm modulators in their car(sat. radio, ipod, etc) which channel frequency do you find to be the best? There has got to be one frequency in the chicagoland area that nothing is broadcast on at all.
This is for a company car where direct aux input is not an option, so dont go there.
post #2 of 14 (permalink) Old 01-05-2006, 11:11 AM
The Victim Newbie
clearwaterms's Avatar
Sportbike: 2007 mountain bike
Years Riding: just started
How you found us: svrider.com
i use 87.9, but mine is directly plugged into my antenna. Don't know if that will help you.
<-- Chris
clearwaterms is offline
post #3 of 14 (permalink) Old 01-05-2006, 11:13 AM
Sportbike: 2002 YZF-R1
I use 87.9 as well for my Sirius.
The most annoying thing is on some stations when people say "S" you get that distorted noise.
Keyhole is offline
post #4 of 14 (permalink) Old 01-05-2006, 11:13 AM Thread Starter
you're running an inline modulator between the factory antenna and the headunit?
post #5 of 14 (permalink) Old 01-05-2006, 11:18 AM
it will change from location to location how much interferance you will get. when I was using one in my work truck I was changing it constantly. I then went to a tape adapter.
post #6 of 14 (permalink) Old 01-05-2006, 11:21 AM Thread Starter
thats why you hardwire one, it should overpower stations and provide better sound.
post #7 of 14 (permalink) Old 01-05-2006, 11:23 AM
The Victim Newbie
yes...
I bought it on ebay, it works great. It cost me like $20 plus I had to buy a few adaptors because my car uses VW antenna connestions, almost all inline pieces are setup for a GM style antenna system
<-- Chris
post #8 of 14 (permalink) Old 01-05-2006, 11:25 AM
I have a VW as well clearwater...
What exactly did you buy? Did it make a huge difference than just using the standard way?
Keyhole is offline
post #9 of 14 (permalink) Old 01-05-2006, 11:33 AM
The Victim Newbie
I actually have a saab, but it's the same hookups...
I needed three parts to make it work
5849595214 - VW antenna adaptor
5849595253 - VW antenna adaptor (you need the male and female adaptors)
5848770067 - something along the lines of this
You will also need a RCA to minijack adaptor, and then basically all I did was pull out my factory head unit, wire in this thing to the stereo, and also I hard wired my XM reciever to switched power, It works great, it never has static, it sounds good, etc.
for the adaptors, you will have to see which ones you need depending on your actual stereo, and clearence, etc. I needed the two parts listed above. Also, the modulator is so strong, that you need to wire a switch to power it off when you want to listen to broadcast radio, or you will get static on all stations. i am sure there is probably a way that you could probably install a relay that if it noticed power on the line to the satalitte reciever it would power on the other box, but I didn't get that technical with it, and since I never listen to broadcast, I never put a switch in either
<-- Chris
post #10 of 14 (permalink) Old 01-05-2006, 11:38 AM Thread Starter
wow, it screwed up ALL other broadcast stations?
post #11 of 14 (permalink) Old 01-05-2006, 11:40 AM
I probably wouldn't need a switch either since I never go back to broadcast anyways
Also I believe the Sirius unit can be used as an FM tuner if you want.
Keyhole is offline
post #12 of 14 (permalink) Old 01-05-2006, 12:45 PM
The Victim Newbie
yes, but if you disconnect the power (switch) it works great again... so with a switch you would be fine
<-- Chris
post #13 of 14 (permalink) Old 01-05-2006, 12:53 PM Thread Starter
what brand did you get? Does what kind of input do you feed it, rca or minijack?
post #14 of 14 (permalink) Old 01-05-2006, 12:57 PM
The Victim Newbie
i got some off brand off of ebay, and it takes an RCA, so I got an RCA to minijack cable because my xm radio piece has a female minijack
<-- Chris
