Comcast vs Vonage - Chicagoland Sportbikes
post #1 of 10 (permalink) Old 02-22-2006, 07:22 PM Thread Starter
BusaDave's Avatar
Years Riding: Lost Track
How you found us: Tony
Comcast vs Vonage
Any of you network gurus who work with this stuff every day have any ideas how to isolate exactly where the fault lies with the current Comcast versus Vonage pissing match that seems to be going on?
During work hours for the last two days and intermittently for the last two or three weeks my outgoing Vonage audio connection is very choppy to the point of being unusable, pings to vonage.com are showing anywhere from 22%-55% packet loss and web connections to secure.vonage.com are very slow or timing out.
Each of them are blaming the other while on another web site I found some who claims that a Comcast engineer stated that Vonage is "using our lines without permission".
This appears on the surface to be Comcast intentionally interfering with Vonage traffic as they are introducing their own "digital phone" service. Anybody who works with this stuff daily have a better grasp of network tools to isolate the problem? Could this be an AT&T issue either contractually or otherwise limiting consumer bandwidth for Comcast in preferrance to business service during the day?
Why are providers pushing for bigger bandwidth pipes like FTTH if they cannot provide adequate bandwidth on the backbones? Are we edging toward measured service?
Dave
BusaDave is offline
post #2 of 10 (permalink) Old 02-23-2006, 01:33 AM
stuck in 6th gear
Ernie's Avatar
do you have QoS enabled router to share your bandwidth appropriately between your voip line and other networked devices?
I've only seen/had problems like yours when I forgot that some other machine in the house was running something network intensive (i.e. bitorrents)
you might have better luck asking your questions over at
http://www.dslreports.com/forum/voip
Ernie is offline
post #3 of 10 (permalink) Old 02-23-2006, 08:37 AM Thread Starter
BusaDave's Avatar
I've been watching this quite a bit. The last couple of days Vonage has posted service outage messages essentially blaming Comcast. I do have QoS enabled and set to high on port 1 of my router.
It's being discussed on both Vonage's forum and dslreports. It's only happening during the work day. At night it's fine. It just so happens I need my phone during the day.
I was hoping someone here knows network tools better than I and could tell me what I might learn using things like SNMP. I'll keep exploring.
Dave
BusaDave is offline
post #4 of 10 (permalink) Old 02-23-2006, 08:44 AM
It might be a bandwidth shortage on comcasts part. I know they are building an entirely new next-gen backbone right now, so they wont have to lease form other companies.
post #5 of 10 (permalink) Old 02-23-2006, 09:15 AM Thread Starter
BusaDave's Avatar
I think it probably is. I suspect that AT&T is throttling their lines based on their contactual agreement with Comcast placing daytime business traffic or other subscribers at a higher priority. It doesn't help that Comcast is now announcing the rollout of their own VoIP service at a higher price point.
Whatever the reason, the rivalry appears on the surface to be hampering a solution to the problem and it appears relatively isolated to Vonage service. I can run software simulations of VoIP to other servers and get reasonable results and ping times to other servers is fine.
Dave
BusaDave is offline
post #6 of 10 (permalink) Old 02-23-2006, 09:47 AM
If it is an issue with thier ATT backbone usage, its not going to matter which VoIP comapny you use, since your base service will still be comcast. The choke will still be that network. I hate to say it, but if you need reliable service during the day you may need to get a base package pots line put in and write it off as a business line or something, until they get this figured out. I can't tell you much here, but I can tell you this wont be a problem for much longer if what we are theorizing here is actually the problem
post #7 of 10 (permalink) Old 02-23-2006, 10:46 AM
Did you know alot of the backbone providers are trying to get a bill through congress that will legally allow them to charges 'net vendors (everything from google to amazon) if they want access to your home? Otherwise they will throttle the connection to the consumer. Its the start of something very bad.
ls14evar is offline
post #8 of 10 (permalink) Old 02-23-2006, 10:48 AM
Where did you see this, got a link?
post #9 of 10 (permalink) Old 02-23-2006, 03:06 PM
ls14evar is offline
post #10 of 10 (permalink) Old 02-23-2006, 10:41 PM
Wild slide rule roots
Morrand's Avatar
Years Riding: 8
It gets worse. There's software on the market now that allows backbone providers to block VoIP packets--and specifically VoIP packets--as desired. Apparently it's already in use on some of the European systems, to force phone calls to go through the public network at regular rates.
More bad news: Comcast reportedly has installed the software already, but declined to comment on whether they were using it to block VoIP. Maybe this is a sign that they are....
Morrand
NESBA #561 (I)
Morrand is offline
