For the auto mechanics - Chicagoland Sportbikes
Closed Thread
post #1 of 75 (permalink) Old 03-07-2006, 06:53 PM Thread Starter
ed0638's Avatar
Sportbike: 2000 ZX9r
Years Riding: A Few Years
How you found us: other site
For the mechanics out there……. I have a 2002 Isuzu Rodeo 4WD V6 …while driving the dash lights dim the radio goes out all the gauges go to the off position, ABS light comes on but the no engine loss it keeps going no loss of power steering….then it goes back to normal…
Anyone have any ideas or had a problem like this?
ed0638 is offline
post #2 of 75 (permalink) Old 03-07-2006, 06:56 PM
Alternator might need to be replaced. I'd check the battery first though,
post #3 of 75 (permalink) Old 03-07-2006, 07:03 PM
Bop your way home...
Dr. D's Avatar
Sportbike: Hypermotard
Years Riding: since 99'
Loose connection behind the dash is my educated guess.
-Alan-
Balancing the Paradox
of Art and Profit
Dr. D is offline
post #4 of 75 (permalink) Old 03-07-2006, 07:07 PM
Curb your dogma.
Phily-D's Avatar
Sportbike: another Honda:)
How you found us: BusaDave
How long have you been experiencing this and over how long of a period of time does it take for the whole scenario as you have relayed to play out?
"Cr-Cr-Cr-Crambone!!"
Phily-D is offline
post #5 of 75 (permalink) Old 03-07-2006, 07:09 PM Thread Starter
ed0638's Avatar
if it is the alternator i should feel the engine loose power....
battery checks fine
ed0638 is offline
post #6 of 75 (permalink) Old 03-07-2006, 07:10 PM Thread Starter
ed0638's Avatar
Just started
about a min or so
ed0638 is offline
post #7 of 75 (permalink) Old 03-07-2006, 07:13 PM
battery checks fine
Not necessarily; never hurts to start at the power sources before ripping into a dashboard looking for loose wires.
post #8 of 75 (permalink) Old 03-07-2006, 07:37 PM
The Plumber
Matoo's Avatar
Sportbike: 05 SV650S
Years Riding: enough
Start with the easy stuff, check the voltage from the alternator and make sure the battery is grounding. Clean the terminals while you are at it.
Then I would start chcking grounds from the dash.
Matoo is offline
post #9 of 75 (permalink) Old 03-07-2006, 08:12 PM
Something shorting out or you have a weak alt or battery.
post #10 of 75 (permalink) Old 03-07-2006, 09:03 PM
I doubt it is a battery or alternator. Since you have no starting issues.
If your battery or alternator couldn't handle a power surge or had a spike, then i can see that occuring.
I would look at fusible links, or main power circuits. They should have a box with all the large fuses. Sometimes a large fuse being more then 30 amps might have gotten loose. Then check the connection that go to the dash.
oldschoolninja is offline
post #11 of 75 (permalink) Old 03-07-2006, 09:15 PM
jimzx9r's Avatar
Sportbike: .
Voltage regulator.
jimzx9r is offline
post #12 of 75 (permalink) Old 03-07-2006, 09:53 PM
Post from the only Professional auto mechanic;
you have a charging system problem, alt. or battery.
the voltage regulator is internal in the alt.
the ABS light comes on because the ABS system is seeing low voltage and will not work.
my first check would be to check connections at the battery, then get the battery tested, you could have loose cells in the battery that move around and short out. if thats ok, then load test the alt. Easy backyard way is to turn on ALL the power things you can, fan, a/c, bright headlights, flashers, rear window defroster, and put a voltmeter on the battery. its not fool proof, but it might show a problem.
HAVE A NICE DAY
post #13 of 75 (permalink) Old 03-07-2006, 09:57 PM
HAVE A NICE DAY
dont you have to know stioch before becoming a professional?
I find it better to hook a scope up to the alternator so i can see the diode pattern.
post #14 of 75 (permalink) Old 03-07-2006, 10:01 PM
humm.. i doubt you even know how to use one..
the funny thing is you mentioned the alt. is prolly ok due to it starts fine last i checked the alt. can be out of the damn car and it will start fine.
i'm sorry but your knowlage is sub-par in this catagory, i would be battling whits with an unarmed man
post #15 of 75 (permalink) Old 03-07-2006, 10:06 PM
so the battery will never lose potential energy?
And you cant run all cars with the alternator out because not all cars have the charging system designed the same way.
post #16 of 75 (permalink) Old 03-07-2006, 10:12 PM
o geez.. i forgot, your the one that speaks general, and then when i do it you come down on me.. i forgot... my bad
IF: the alt was outputing lets say 13.1 volts instead of what it should at say 14.7 volts, theres still enough to charge the battery, and keep the battery "ok" but when full load is applied to the alt, he starts to experaince this problem.
SO therefor you have a bad alt. and the car still starts fine.
(NOTE: the voltages that were used were for exsample only, and are not specific to every car on the planet)
also: i have a stupid piece of paper on the wall, and a big fatty paycheck that says i'm a professional (please note sarcasim)
post #17 of 75 (permalink) Old 03-07-2006, 10:23 PM
But during the time, he experienced that problem; he didn't have any loads on the electrical system. Unless, he is unaware of it, such as a cooling fan coming on, abs pump activating, a/c clutch locking up etc...
The car is going to start fine a few times. But at 13.1v, the system is hardly putting a charge on the battery. And if he is driving with his headlights on, then the alternator will not put a proper charge on the battery. After a few days, his battery will be dead. He will be noticing dim headlights and dim dash while driving.
I sewn a patch on my shirt that says im a professional.
post #18 of 75 (permalink) Old 03-07-2006, 10:35 PM
Of course he doesnt' know what loads are on the alt while your driving.. SHEESH..
i said 13.1 was an EXSAMPLE.. maybe its 13.2 its funny also how you mentioned he would see a dim dash... ISN"T THAT ONE OF HIS COMPLAINTS?!?!?!!?
and for shits and giggles i'm gonna give you a quick exsample;
Customer comes in, complains that ONCE the car wouldn't start, needed a jump, car has been running FINE for a month but still wanted to get it checked out cause SOMETIMES he thinks the headlights look dim.
Pull the car in, everything seems ok, starts fine and dandy, runs down the road as good as it can, turn on the a/c, rear defrost, high beams, wipers, radio, everything i could think of. huh.. shows 14.1 volts at the battery.. everything seems ok.. Let the car run for about 15-20 mins with everything going, and what do you know.. it slowly drops to about ~12.7-13.2.. then it comes back.
replace alt.
recheck car for over an hour, problem is now gone.
ODD huh?
Seriously sweetie, time for bed and let the grown ups talk
post #19 of 75 (permalink) Old 03-07-2006, 10:38 PM
o yeah and your gonna mention how my story about the one time it didn't start which prolly in your mind shows its an alt.
but how do i know the guy didnt leave the headlights on? or the inside light on? or leave a cell phone plugged in and went on vacation for 2 weeks? YOU DONT
Ed's problem is just one of many i fix all day long. i think i know what im talking about
post #20 of 75 (permalink) Old 03-07-2006, 10:38 PM
CRF50 Squid
Years Riding: Veteran Poser
I am shutting off my TV. This is comedy gold!
Blah Blah Blah is offline
post #21 of 75 (permalink) Old 03-07-2006, 10:40 PM
bring over some popcorn!
post #22 of 75 (permalink) Old 03-07-2006, 10:41 PM
His complaint was an intermittent dim. The dim im talking about is constant till the battery goes dead or below 12.6 volts DC.
replace alt.
ODD huh?
that would be commonly caused by a bad diode, allowing current to flow in the wrong direction in the alternator.
uh, vcook can make your bed warm, he likes you more.
post #23 of 75 (permalink) Old 03-07-2006, 10:42 PM
and were is are the diodes??????????? (totally loaded question)
post #24 of 75 (permalink) Old 03-07-2006, 10:43 PM
Ryan's Avatar
Years Riding: Since 2001
This is fun to watch. And my 2 cents (as someone who's been doing this every day for 7 years and has a few pieces of paper on the wall that say I know what I'm doing ): Moparboyy is right.
-Ryan
Ryan is offline
post #25 of 75 (permalink) Old 03-07-2006, 10:44 PM
you dont know. since the customer doesn't know anything about cars.
Thats why you do a battery test, charging test,and a diode pattern test with a scope. , then a current draw test.
post #26 of 75 (permalink) Old 03-07-2006, 10:45 PM
So then why are you even talking about it?
"hey i got coolant in my oil.. maybe its related to all this??" (please note sarcasim again, dont start more useless posts about this)
post #27 of 75 (permalink) Old 03-07-2006, 10:45 PM
CRF50 Squid
"You must spread some Reputation around before giving it to MoparBoyy again."
post #28 of 75 (permalink) Old 03-07-2006, 10:46 PM
in the rectifier. So it turns alternating current into direct current.
post #29 of 75 (permalink) Old 03-07-2006, 10:47 PM
wow,.. you are off the wall man.. your first post said it wasn't a battery or alt.
you should copy my post.. edit your first post.. then everyone will think your right
post #30 of 75 (permalink) Old 03-07-2006, 10:48 PM
and the rectifier is were again??? come on.. just say the car part i want to hear.
Closed Thread
