Master Lock-Lost Key - Chicagoland Sportbikes
post #1 of 13 (permalink) Old 04-13-2006, 07:51 PM Thread Starter
I cant find the keys to my trailer and coupler. I have a felling theyve been locked inside the trailer.
I need ideas how to cut the lock off. A hack saw is useless. I dont have a grinder
Anyone have MacGyvers phone number?
post #2 of 13 (permalink) Old 04-13-2006, 07:56 PM
tension bar and rake (pick set).
Short of that, you can sometimes get 'smiliar' keys to work if you use the same raking/tension principles.
Possibly a carbon cutting disc.
post #3 of 13 (permalink) Old 04-13-2006, 07:56 PM
Freon(sp) inserted into the lock area then a very large sleage hammer to the end of it. It depends on the type you have though.
Chicago Monster is offline
post #4 of 13 (permalink) Old 04-13-2006, 08:33 PM
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
uhm...depending on the master lock model...u can actually go to a hardware store and look for the same model and digits on the bottom of the lock...seeing that they mas produce the lock...u might be able to get it open by buying a same # matching lock...but also depends on how old the lock is if its sstill being sold....
another option...is call a locksmith...they can pick it as long as u can prove the trailer is yours....and put new lock on it if u can not find keys inside it...should not cost more then 65 bucks...
mmmm pussy
Thunderstruck is offline
post #5 of 13 (permalink) Old 04-13-2006, 09:54 PM
jimzx9r's Avatar
Sportbike: .
I'm a pro at this.
Powerdrill + expensive hard drill bit + lock cylinder = busted. I used to break a lot of masters. Get a drill bit that's about 1/3 the size of the cylinder and go at it. It takes about 30 minutes, but it's better than paying $100 to a locksmith. Since it's on the trailer it will be a pain to hold onto and drill at the same time, just be really careful. I used to put the locks in a vice so I didn't have to worry about that. The only problem is that the whole lock will get burning hot...get an oven mitt..
Another option is the car jack method, if you have one strong enough and the lock is low enough to the ground. Just drape a towel over the lock once you have the jack set tight under it...the lock is going to go flying when it breaks. This is probably not a good idea if the lock is mounted to something weaker than it, because it will tear off whatever it is attached to before the lock breaks.
A hacksaw will work, and it's usually the quickest way. Wrap a lot of electrical tape around one side of the loop, about a millimeter away from where the loop goes into the lock. This will be your guide for the saw. Take the blade and saw through a bar of soap to lube the blade, then start cutting. You can get through the lock in about 5 minutes. You just have to make sure you cut the side that isn't attached to the lock. Once you cut the right side, the other side will spin open. If you cut the wrong side...sometimes nothing happens and you have to do the other side.
60% of the time, it works every time.
jimzx9r is offline
post #6 of 13 (permalink) Old 04-13-2006, 09:58 PM
Instigator
bigbaddiesel's Avatar
Sportbike: 2003 Yamaha R6
Years Riding: 8
How you found us: Google!
Gimme a pic of the lock, and ill tell you if i can pick it open....
Jake
2003 Yamaha R6 Raven Limited Edition
Cages:
1999 Ford F250 (Gas Sucker)
2001 VW Golf TDI (Gas Saver)
bigbaddiesel is offline
post #7 of 13 (permalink) Old 04-13-2006, 10:06 PM
Dremel?
post #8 of 13 (permalink) Old 04-13-2006, 10:19 PM
I had to double-blink on that one
post #9 of 13 (permalink) Old 04-14-2006, 12:38 AM
Originally Posted by Sticky
Dremel?
post #10 of 13 (permalink) Old 04-14-2006, 12:59 AM
goneridin's Avatar
Sportbike: 05 Busa LE
Years Riding: too many years to remember but not enough to be great
Screw the hack saw. How about a power saw. I got a nice Dewalt in the garage. That will make quick work of the lock problem.
goneridin is offline
post #11 of 13 (permalink) Old 04-14-2006, 04:42 AM
Instigator
Years Riding: 8
Dare i say .... bolt cutters, works well for me
jake
Cages:
post #12 of 13 (permalink) Old 04-14-2006, 06:29 AM Thread Starter
Ive thought of almost all of that. Its time to take a trip to the store
Thanks guys
post #13 of 13 (permalink) Old 04-14-2006, 09:03 AM
Labdog's Avatar
Mike if you are in the area i will pick those open for ya in no time at all.
If i cant (which i doubt) i have every tool needed to open those for ya as well!
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
