This engine rules - Chicagoland Sportbikes
post #1 of 4 (permalink) Old 04-16-2006, 01:44 AM Thread Starter
jimzx9r's Avatar
Sportbike: .
This engine rules
850 horsepower, 850 cubic inches, and it only weighs 150 lbs...then it can also run on gasoline, diesel, or renewable energy sources.
Equiv. To 32 Cylinder, 4-stroke-cycle Diesel
Bore--mm(in) 76.2(3)
Stroke--mm(in) 95.25(3.75)
Displacement-- Cu in(L) 848 (13.8)**
Aspiration Normally
Compression Ratio 25:1
Rotation (from Fly Wheel end) CCW/CW
Cooling System Oil Cooling
Lub Oil System--Quart drysump, 5
Weight, Net Dry (Approx.) Kg(lb) including flywheel . 68 (150)
Advertised hp (KW) 850(634) NA 3,000 (2,238) SC/TC.
http://www.angellabsllc.com/index.html
jimzx9r is offline
post #2 of 4 (permalink) Old 04-16-2006, 03:46 AM
rider for life
Sandman's Avatar
Sportbike: CBR1100XX
Years Riding: First let the clutch out in 1972
How you found us: no- you found me
It may "rule" in concept, but here's what others say who have given feedback discussing it on another board:
...sounds too good to be true. Also, their website navigation sucks, with what looks like a master menu to change depending on page.
Their technical explanations too often lead to "it will not break because it is based upon 100 years of engineering design"
The guy is a fuckin' nutcase! I had a long talk with him at the L.A. Auto Show. He's a verifiable Section 8 all the way. The engine doesn't run, never has...only rotates on compressed air. He claims 814lb-ft of torque from 150psi compressed air input...on what dyno? An Ingersoll-Rand IR295 1" impact makes 1000lb-ft at 150psi...doesn't mean I'm gonna drive a vehicle's axles with it down the road. He claims he was "A specially chosen one by God" to design machines to save the world. This guy reminds me a lot of another crackpot I know named Larry Widmer...
Sandman is offline
post #3 of 4 (permalink) Old 04-16-2006, 08:31 AM
post #4 of 4 (permalink) Old 04-16-2006, 12:39 PM
The laws of physics would like a word with that man.
chach is offline
