Bike Trouble..... - Chicagoland Sportbikes
post #1 of 18 (permalink) Old 04-17-2006, 09:44 PM Thread Starter
Bike Trouble.....
Maybe a stupid question but everytime I start up my bike I'll hold the throttle at 2 rpms and it seems to be misfiring, but once it's been on for a while it's fine. Should I get it checked? Is this normal?
kitty15 is offline
post #2 of 18 (permalink) Old 04-17-2006, 10:20 PM
Bop your way home...
Dr. D's Avatar
Sportbike: Hypermotard
Years Riding: since 99'
I have heard that GS500s have a little bit of a temper when cold. If you haven't had your bike jetted yet this may help a lot. My friends Bandit 600 ran pretty rough when first started up, we jetted the bike a little richer and it warms up and idles fast and smooth.
-Alan-
Balancing the Paradox
of Art and Profit
Dr. D is offline
post #3 of 18 (permalink) Old 04-17-2006, 10:26 PM
2 rpms?!?!?!??! damn that thing has a LOW idle
seriously though.... how many miles on it?
post #4 of 18 (permalink) Old 04-17-2006, 10:36 PM Thread Starter
It has <2000 miles
kitty15 is offline
post #5 of 18 (permalink) Old 04-17-2006, 10:46 PM
Originally Posted by kitty15
It has <2000 miles
humm... well i guess the plugs arn't worn out i guess i would go with what Dr.D said..
you could fix it if you had a scope (that will never get old)
post #6 of 18 (permalink) Old 04-17-2006, 10:47 PM
BEER!
Grover's Avatar
GS500s, while bulletproof, are still carburated and notoriously cold blooded. A properly installed jet kit would seriously help that out. It's not too expensive, and I'm sure there's a couple dozen people here that can install it.
I'd be more concerned about misfires once it's up and running. Misfires while warming up aren't too bad. My old Maxim 750 would take 10 minutes of idling just to be able to not die when you clicked it into gear.
NESBA/CCS #142
AIM: GroverSV650S
Dirtbikes are not submarines
Grover is offline
post #7 of 18 (permalink) Old 04-17-2006, 10:52 PM
Dr. D's Avatar
I just need a tin cup and a rubber band, I don't need any scope.
-Alan-
of Art and Profit
Dr. D is offline
post #8 of 18 (permalink) Old 04-18-2006, 12:12 AM
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
its cold weather hun...its gonna run like crap until decently warmed up...every 1 is right...needs to be jetted...otherwise wait until 70+ weather and then it should start and idle just fine...alsom when u stored it...did u put sta-bil in the tank or run the bike out of gas?...cause carbs could be gummed up also....
mmmm pussy
Thunderstruck is offline
post #9 of 18 (permalink) Old 04-18-2006, 09:16 AM
How old is the GS? the 91 in the garage started right up, has sat there since last October, has 7400 miles on it. Not jetted....but the carbs are clean
post #10 of 18 (permalink) Old 04-18-2006, 09:26 AM Thread Starter
It's a 2004 and yes i did put sta-bil in it.
kitty15 is offline
post #11 of 18 (permalink) Old 04-18-2006, 09:46 AM
anyone got racing fuel floating around that they can give her about 2 or 3 gallons worth so she can clean those carbs out???
when u stored it hun...did you run the gas completely out of the carbs?...do you have a petcock where you can manually shut off the fuel, and did u turn it off if you do?
mmmm pussy
post #12 of 18 (permalink) Old 04-18-2006, 09:49 AM
From what you explained it sounds like its briefly running on one cylinder until it gets a little warmed up.
Old gas and sitting for a while will cause the low speed jets to clog. That's why people put stabilizer in the gas before winter storage. This helps the gas not to turn into crap. Gas starts to turn into crap after about 2 months of sitting without stabil.
Carbs probably need to come off, and a little wire needs to be poked through the low speed jets.
Spraying carb cleaner or running expensive gas 9 times out of 10 will not unclog the lowspeed jets
post #13 of 18 (permalink) Old 04-18-2006, 11:43 AM Thread Starter
Well I'm running the gas out now. I'm waiting for it to run down.
kitty15 is offline
post #14 of 18 (permalink) Old 04-18-2006, 04:02 PM
right, believe it or not, running premix really cleans things out, it was a tip i got a while back from Godfather, i did it on a 82 nighthawk i had a hard time with, idled the stuff and it really cleared out, like magic.
Billyboy is offline
post #15 of 18 (permalink) Old 04-18-2006, 04:15 PM
Puppy Love!
Gixx's Avatar
Sportbike: 05' Gixxer 6
Don't have any racing fuel "floating" around, but I beatcha a speedway gas station would!!!!
KJ
The CLSB Bitch Wrecking Crew
MySpace
XBox Live - Gixx009
Gixx is offline
post #16 of 18 (permalink) Old 04-18-2006, 04:20 PM
If you want the job done correctly the carbs need to come off and be cleaned out.
If you want to be half assed about it, spray some carb cleaner in the intake. Running racing fuel or premix through the carbs is not going to unclog them. Spraying carb cleaner is most likely not going to unclog them.
The passage way through a pilot or low speed jet is almost microscopic, that is why they clog up so easy.
Old gasoline turns to gunk and clogs them up.
post #17 of 18 (permalink) Old 04-18-2006, 07:21 PM
I see how it is, give advice to the fish and Prufrock gets the shit end of the stick.
chach is offline
post #18 of 18 (permalink) Old 04-18-2006, 11:45 PM
I'd rather be railing :)
Jammin's Avatar
Sportbike: Riding Suzukis: 04 GSX-R600, 98 DR650SE
How you found us: Gixxer.com
Send a message via AIM to Jammin Send a message via Yahoo to Jammin
hmmm Sta-bil??..... We just dropped in fuel injector cleaner and topped the tank off completely (to get rid of as much air as possible). And she was on a battery tender throughout winter.
We just started it up last weekend for the first time and it fired right up
Track bike, here we come!
J A Y riding around the world on a 98 Suzuki DR650SE (sanDRina)
follow at >> JamminGlobal.com | facebook | twitter | youtube
Consider a small donation to support my trip or Buy a T-shirt
"Emancipate yourself from mental slavery, none but ourselves can free our mind." - Bob Marley
Jammin is offline
