Cooling system pressure tester, anyone got one? - Chicagoland Sportbikes
post #1 of 6 (permalink) Old 06-03-2006, 02:13 PM Thread Starter
I could really use one right now if anyone's got one to borrow.
Also, if anyone knows of a way to test a radiator that would be good too... I personally can't think of a way and haven't found one by searching around.
chach is offline
post #2 of 6 (permalink) Old 06-03-2006, 02:24 PM
jimzx9r's Avatar
Sportbike: .
I thought they were tested by pumping them with air and dunking them in a tub of water, like a tire.
jimzx9r is offline
post #3 of 6 (permalink) Old 06-03-2006, 04:29 PM
No you got it all wrong thats how you test the buoyancy of it.
You know incase you ever wheelie into a lake.
Currupt247 is offline
post #4 of 6 (permalink) Old 06-03-2006, 06:38 PM
Ryan's Avatar
Years Riding: Since 2001
I have one but it's at work so you'd have to wait till Monday and I probably don't have an adaptor for a bike radiator if that's what you plan on using it on. Why don't you just let the vehicle get hot and make it's own pressure?
-Ryan
Ryan is offline
post #5 of 6 (permalink) Old 06-03-2006, 06:49 PM Thread Starter
The vehicle in question is my '90 BMW 535i that overheated on me yesterday, it has a mystery coolant leak that doesn't show up anywhere (all the hoses are fine, nothing leaks under the car, engine bay is dry, doesn't show up in the oil)... I will just drive it but rest assured whenever I turn it off or turn it on *bing* Coolant Level flashes like clockwork. Before you say the sensor is bad, it's always right, whenever I check the reservoir it always needs to be topped off.
I kinda just want to make sure there isn't a crack in the block or something, or some kind of weird headgasket failure that isn't coming up in the oil.
chach is offline
post #6 of 6 (permalink) Old 06-03-2006, 07:48 PM
I have the Rad kit which you draw a vacunm to it by shop air.
