MP3 Player Questions - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 06-15-2006, 02:01 PM Thread Starter
We just bought a Creative (8 GB Storage) MP3 player. I guess it can hold like 5 thousand songs. It was cheaper than the average I-POD so I went for it. I also bought the FM modulator. Thats where the question comes in. What is the best station to use? What stations have people had problems with. I bought a digital one so I can pick any station I want to play the IPOD over. How does this affect the sound quality? I know there is a hard wire interface but I figure Rachel and I will be swapping it back and forth between cars and we both travel for work so it would nice to bring the device with thats why I bought the modulator.
post #2 of 24 (permalink) Old 06-15-2006, 02:12 PM
Human lawn dart
rdrash's Avatar
How you found us: I know all
The station really depends on where you are. There is one station by my house that actually broadcasts something. 5 minutes away the broadcast is gone. So it all depends. As for quality. Think FM quality, you are broadcasting it on FM after all.
MotoGP 200 mph no roll cage
NESBA # 599
rdrash is offline
post #3 of 24 (permalink) Old 06-15-2006, 02:21 PM
[Online]
Fracker's Avatar
Years Riding: Since 2004
The quality vs hardwired will be worse. In theory it all should work fine, but you inevitably get some quality loss at the transmitter. Plus, there will be some degradation from the static, of course.
How bad or good it is - depends on the quality of the FM modulator and your own preference. A lot of people are OK with that level of quality, some just wince and say "never again".
Oh and +1 on the station depending on your location. Just find a frequency that doesn't have anything but static noise, as far as possible from other stations.
Fracker is offline
post #4 of 24 (permalink) Old 06-15-2006, 02:25 PM
7tex is right. But, high 80s (like 88.1) and low 90s work most of the time. Definate loss in sound quality and problems with static, but it is workable.
post #5 of 24 (permalink) Old 06-15-2006, 02:32 PM
that's where most of the stations I listen to are!
post #6 of 24 (permalink) Old 06-15-2006, 02:36 PM
[Online]
Fracker's Avatar
BTW, depending on the cars that you have there could be inexpensive hardwired interfaces available. You would be able just to connect/disconnect the player. You probably won't find an integrated solution with docking station and controlling the player from the car stereo since it's not an iPOD, but you should be able to find a simple one that just connects to the headphones jack. Yet, it depends on the car's make/model. For example, until a recent time it was next to impossible to find an interface solution for Infiniti G35.
Fracker is offline
post #7 of 24 (permalink) Old 06-15-2006, 03:05 PM
cassette adapter work awesome, for real.
post #8 of 24 (permalink) Old 06-15-2006, 05:18 PM
Hardwire all the way. 30 minutes of work one time to get perfect sound. Heard my buddies FM tuner and could never go that route.
post #9 of 24 (permalink) Old 06-15-2006, 05:19 PM Thread Starter
The hard wire adaptor won't work for mine or Rachels vehicles. Both our RCA jacks are used up by amps.
post #10 of 24 (permalink) Old 06-15-2006, 05:19 PM
[Online]
Fracker's Avatar
How can you do it in 30 minutes??? Removing the dashboard may take longer (and for example in my car it is needed because the stereo is not removable).
Fracker is offline
post #11 of 24 (permalink) Old 06-15-2006, 05:20 PM Thread Starter
Both our stereos are aftermarket and are easily removable.
post #12 of 24 (permalink) Old 06-15-2006, 05:20 PM
My car (350Z) and Hunny's (Accord) were a snap. Not necessary to remove the radio at all. Easily plugs into one of the Satellite/alternate slots.
post #13 of 24 (permalink) Old 06-15-2006, 05:21 PM
Wish I could hardwire. No aux jacks. no tape either. Sucks.
I use 101.5 IIRC on my fm modulator.
ls14evar is offline
post #14 of 24 (permalink) Old 06-15-2006, 05:21 PM
The big ripoff is that you're basically just plugging in a converter/splitter into your radio. You're paying $100 for maybe .25c worth of wire and a plug.
post #15 of 24 (permalink) Old 06-15-2006, 05:21 PM Thread Starter
Elaborate please. How does the hardwire interface between the deck and the MP3 play
post #16 of 24 (permalink) Old 06-15-2006, 05:22 PM
and I bet neither have inputs on them, the amps are using the outputs. a hardwired fm modulator is king, it will drown out all other radio stations and you'll be money. they plug into the antenna hole on the headunit then the antenna in to them.
post #17 of 24 (permalink) Old 06-15-2006, 05:24 PM Thread Starter
AH HA!!!!!!!! It plugs into the antenna eh?
They make splitters
post #18 of 24 (permalink) Old 06-15-2006, 05:26 PM
[Online]
Fracker's Avatar
You're lucky, I guess. I have the G35 Coupe and there're no interfaces at all . The only option is to buy special adapter for factory XM radio input that will accept work as a regular line input.
Fracker is offline
post #19 of 24 (permalink) Old 06-15-2006, 05:29 PM
Right, that's exactly what I had to do. But it was a very fast install. I can't imagine that the G35 is much different.
post #20 of 24 (permalink) Old 06-15-2006, 05:32 PM
For starters, our radios are satellite ready. There's usually Aux-1 and Aux-2 in the back (one may be in use if your car came wired to XM or whatever service). The box you buy will simply plug into one of the Aux slots in the back of your radio and then you run a standard audio cable from that box to the ipod.
post #21 of 24 (permalink) Old 06-15-2006, 05:40 PM
[Online]
Fracker's Avatar
I just can't believe it (no offense, I can't believe myself here ). I've done hours of research and everyone is saying there's no AUX in. They say the the XM interface on G35 requires some sort of a special converter. Do you have factory Bose stereo? That could be the difference.
Fracker is offline
post #22 of 24 (permalink) Old 06-15-2006, 05:42 PM
he's talking about using a PIE style converter for the stock inputs on the back, this runs to box that converts to standard RCA input jacks.
post #23 of 24 (permalink) Old 06-15-2006, 05:49 PM
[Online]
Fracker's Avatar
Sorry, I am not sure I understand. Are you talking about the connector with a bunch of wires to speakers, antenna, power etc that plugs into the factory stereo? Using a converter that will plug in between?
Or we're talking about the hardwired FM (which is great and simple IMHO)?
Fracker is offline
post #24 of 24 (permalink) Old 06-16-2006, 11:08 AM
Yea mine's a Bose. I believe you cannot do it on the factory radios.
