HDTV (satallite or cable) and cables? - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 06-15-2006, 05:11 PM Thread Starter
ClevisR6's Avatar
Sportbike: 04 Zuma, 06 Crf50
Years Riding: sho' nuff!
How you found us: Nesba
When you get HD, do you need to rerun the coax in the whole house? They sell these crazy expensive cables for component to component, but i'm thinking not many people change the coax.... is there a need to change?
I'm thinging of getting some HD satallite for the domicile, and have coax already run to each room that I want + garage. will it need to be changed?
ClevisR6 is offline
post #2 of 24 (permalink) Old 06-15-2006, 05:15 PM
Go Hawks!
CHI1000RR's Avatar
Your Coax should be okay... You need component cable(HDMI is preferred) if you're running HD from a cable or sat box. If your display can decode, then you do not unless the cable that is run in your house is really old.
"I am Jack's smirking revenge.."
CHI1000RR is offline
post #3 of 24 (permalink) Old 06-15-2006, 06:55 PM
Labdog's Avatar
Coax RG-6 from dish to HD reciever. HDMI out of reciever to HDTV.
Its a BEAUTIFUL thing!
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #4 of 24 (permalink) Old 06-15-2006, 10:27 PM
plotts's Avatar
Sportbike: KTM 690 SM
Years Riding: A little bit.
except I live in a condo built in the 60's and my crusty ass coax cable coming through the wall (and the whole building) gives perfect high def from RCN cable box. The only cables to worry about are the ones from reciever to the tv.
plotts is offline
post #5 of 24 (permalink) Old 06-15-2006, 11:33 PM
CRF50 Squid
Years Riding: Veteran Poser
Is there a noticeable difference in HD content between components vs. HDMI? I currently have Comcast HD service and running components with optical audio from the Comcast HD DVR. Would it be worht it for me to invest in HDMI?
Blah Blah Blah is offline
post #6 of 24 (permalink) Old 06-16-2006, 12:49 AM
VTwin FTW!
ChicagoFactory's Avatar
Years Riding: 20
Yes! HDMI carries both a digital audio and video signal with the same (one) cable instead of 3 or 4. It's a must for HDTV.
I have a question. What would give you better surround sound, an optical cable, or the HDMI? Hmmmmmm?
ChicagoFactory is offline
post #7 of 24 (permalink) Old 06-16-2006, 07:50 AM
Labdog's Avatar
DEFINITLY HDMI!!!!
Mike i would have to say Optical for audio. Just a guess here due to the fact the money spent on another HDMI cable. Optic is optic......
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #8 of 24 (permalink) Old 06-16-2006, 08:55 AM
the other option is DVI for video and optical audio for stereo. This works real well if you have a stereo reciever.
post #9 of 24 (permalink) Old 06-16-2006, 08:58 AM
CRF50 Squid
Looks like I need to go HDMI.
post #10 of 24 (permalink) Old 06-16-2006, 10:06 AM
Go Hawks!
CHI1000RR's Avatar
DVI is done, they are no longer selling displays with DVI. I don't think Comcast is distributing boxes with a DVI output any longer. DVI is basically HDMI without the sound and CR protection. Hollywood got its way with HDMI, they will be able to restrict copying on HD content in the future via HDMI. Also, if you do not have HDMI, you may not receive some content in HDMI although this has yet to happen.
HDMI will get you the best picture. Use digital optical for sound to your A/V receiver. Some of the more expensive A/V receivers have HDMI inputs as well but then you need two HDMI cables. Sound should not differ between HDMI or optical, they are both a digital signal.
post #11 of 24 (permalink) Old 12-18-2006, 03:43 PM
Ok I'm confused on the whole HDMI issue. If your running an HDMI cable from the cable box, to the TV which also carries sound, how are you getting the sound to your receiver. I have never used my TV speakers on my set, I run fiber directly to \my receiver for sound and always use the receiver for sound no matter what I'm watching. HDMi seems like a waste to me if I am paying extra to lump audio signal cabling in with video cabling if its going to the wrong place.
post #12 of 24 (permalink) Old 12-18-2006, 03:47 PM
I've got the 5 or so cables running out of the HD Tuner into the tv which also carry the sound I believe. I then use my tv's 'Audio Out' to run that into the receiver. So the receiver never changes off of Video1 or whatever it's set at by default since the tv basically does than when I change inputs.
post #13 of 24 (permalink) Old 12-18-2006, 03:49 PM
So theres no concern with the TV adding extra processing tot he audio signal?
post #14 of 24 (permalink) Old 12-18-2006, 03:53 PM
if he's using 5 cables then he's doing component(3) along with anolog audio(2). not ideal.
run hdmi to the tv, then optical to your reciever.
Or hdmi to your reciever and then hdmi out from the reciever to the tv(for video) assuming your reciever does hdmi switching.
Just because HDMI can carry audio and video, doesnt mean it always will. Something to be aware of.
post #15 of 24 (permalink) Old 12-18-2006, 04:07 PM
chibeemer's Avatar
Sportbike: BMW R1100s
Years Riding: 13
How you found us: Rider
Nope, I use my TV speakers and my receiver's surround sound at the same time with HDMI.
In a nutshell you should make sure your TV has multiple HDMI ports or you'll need to shell out $150 for a splitter which degrades your signal.
Here is an example:
1. cable
2. HD DVD player (give it 2 years and this will be the only type available)
3. PS3
Now if just want to watch ABC, NBC, CBS, FOX, PBS, or about 30 other terrestrial stations for free you can simply make sure your HDTV has a built in terrestrial receiver. If you are getting one older than 1 year you can buy this:
http://www.circuitcity.com/ssm/Samsu...oductDetail.do
I'd suggest researching all this stuff here:
http://www.avsforum.com/avs-vb/showt...67#post9159767
Blah, Blah, Blah
Get your Portable ID!
chibeemer is offline
post #16 of 24 (permalink) Old 12-18-2006, 04:17 PM
CRF50 Squid
HDMI is overrated. I recently switched my HD DVR from components to HDMI. After some tweaking, I can't say I can see any improvement over components. Maybe I need to get my eyes checked.
post #17 of 24 (permalink) Old 12-18-2006, 04:20 PM
Hey Vcook, do you mean that simply using those cables vs hdmi is not ideal or that running the audio into the tv and then tv out to receiver is not ideal? (Or both I guess?)
In terms of sound, I ran it this way since the Comcast tech set it up that way and have not had time to research it much. I've never been a tv sound buff, so unless I get a dramatically better picture I'm probably not going to get hdmi cable.
post #18 of 24 (permalink) Old 12-18-2006, 04:22 PM
using analog cables for audio is not ideal. you're getting stereo sound, dolby prologic at best. booohisss.
post #19 of 24 (permalink) Old 12-18-2006, 04:24 PM
It's an older receiver (about 4 years old). I think the only settings I see on there are prologic movie and prologic music...I don't think it even has any digital inputs.
post #20 of 24 (permalink) Old 12-18-2006, 04:27 PM
must be pretty old.
post #21 of 24 (permalink) Old 12-18-2006, 04:30 PM
must be pretty old.
Yea, but it's one of those things that sounds good to me for now. No doubt there's much better out there, but when I'm watching whatever, it still sounds pretty darn good to me...and I guess that's half of what counts.
I do see deals out there for newer 7.1 systems, so one day I'll look into those.
post #22 of 24 (permalink) Old 12-18-2006, 04:32 PM
chibeemer's Avatar
Years Riding: 13
I agree, HDMI is preferred but somewhat over rated. I tested a few devices between my HDMI and component and saw little difference. In fact I actually prefer component connection between my upconverting DVD player and TV because if I use HDMI my contrast is washed out and I can't adjust it.
That makes scenes like the end of Resident Evil all white washed out.
Anyway, IMO its a somewhat deminished return. Sure they say better and it probably is but sometimes its not very noticable.
Blah, Blah, Blah
post #23 of 24 (permalink) Old 12-18-2006, 04:40 PM
CRF50 Squid
I also noticed that with HDMI the colors are a tad washed out. It took me some tweaks to get it the way I like it. Another problem I have with HDMI is the handshaking between my Comcast/Motorola HD DVR and my TV sucks ass. The DVR has to be powered on after the TV or else I get snow for picture. The only way to get the picture back is to power cycle the DVR or switch tuners from HD to SD and vice versa.
post #24 of 24 (permalink) Old 12-18-2006, 05:08 PM
chibeemer's Avatar
Years Riding: 13
Oh and don't get me started with HDMI's handling of HDCP. ARG!
So get this, there isn't a standard yet for HDMI's handling of High Definition Copyright Protection (hence HDCP). Sometimes you can hook up a device and everything is OK and then sometimes you'll hook up a device and all you get is a black screen.
What ticks me off is that so few people have the same equipment you never know if its an equipment problem or what.
http://www.digitalconnection.com/FAQ/HDTV_12.asp
Blah, Blah, Blah
