Painting Help - Chicagoland Sportbikes
post #1 of 2 (permalink) Old 04-04-2003, 07:56 PM Thread Starter
Man with Big Hose
Pugsly's Avatar
Painting Help
When i tested a section to paint my sharkskinz, a few small sections won't accept the paint...it seems as if there was grease of something there. I cleaned it i thought was good.
Should i sand it first? if so, with what grit. what else should i clean it with?
I also am going to put a clearcoat on. should i wet sand before the clearcoat or after? also with what grit?
That Boy Just Ain't Right
CCS #414
PARTS411.COM
Lockhart Phillips USA
NESBA #414 Advanced
2001 GSXR 600
Pugsly is offline
post #2 of 2 (permalink) Old 04-04-2003, 11:44 PM
CRAZe Inc's Avatar
Sportbike: Big Wheel
Years Riding: Since 3
I'd do like an 800-1000 grit on the primer just so it will accept the base coat, spray however much you want, do a clear coat (or 2) then wet sand with 1500 and 2000 grit
CRAZe Inc is offline
