need a little help.. - Chicagoland Sportbikes
post #1 of 22 (permalink) Old 11-23-2007, 02:25 PM Thread Starter
BOOSTD_GSXR's Avatar
im trying to take the clutch out on my xr50 so i can install the high volume oil pump. has any one done this before that can give me some pointers?
BOOSTD_GSXR is offline
post #2 of 22 (permalink) Old 11-23-2007, 02:26 PM
Infectious Human Waste
Milenko's Avatar
Sportbike: <600cc's
Years Riding: 9
See i knew you would need help! sorry bro
I'd let him pee in my butt
Milenko is offline
post #3 of 22 (permalink) Old 11-23-2007, 02:30 PM Thread Starter
haha ya i have never done a motorcycle clutch before. i'm sure i can figure it out if i start taking things apart, i just done want to take the wrong thing apart and figure it out the hard way.
post #4 of 22 (permalink) Old 11-23-2007, 02:34 PM
jimzx9r's Avatar
Sportbike: .
it will probably need an alignment after.
jimzx9r is offline
post #5 of 22 (permalink) Old 11-23-2007, 02:48 PM Thread Starter
wow your still hung up on that huh. well i guess ur right. i'll do a full 4 wheel alignment when the job is complete
post #6 of 22 (permalink) Old 11-23-2007, 02:56 PM Thread Starter
ok i went ahead and started taking it apart. once i took the center cover and bearing off i found the nut that holds it on. now i just need the tool for that nut, as HDTony told me its a special tool that is needed.
post #7 of 22 (permalink) Old 11-23-2007, 02:58 PM
See those Philips head screws, You need to Find a Screwdriver that fits them EXACTLY. they are tighter than a muffugger. Last itme we did it Craftsman screwdrivers fit it perfect. You dont want to strip those! Get the screw driver in there, put an assload of pressure on it and use a wrench to break them loose.
post #8 of 22 (permalink) Old 11-23-2007, 03:00 PM
+1 to what tony said. or an impact driver works well.
you'll need the clutch nut tool too.
post #9 of 22 (permalink) Old 11-23-2007, 03:00 PM
dude.. take the 2 bolts out that hold the motor in the frame and put the motor on the bench, makes life SOOO much easier.
post #10 of 22 (permalink) Old 11-23-2007, 03:28 PM Thread Starter
i used a impact screw driver to remove the screws.
i couldnt get the correct socket for the clutch pack nut from the dealer so i used a cheap craftsman 13/16 socket. with a little grinding it worked perfect.
post #11 of 22 (permalink) Old 11-23-2007, 03:29 PM Thread Starter
i know thats kinda half assing it but to get outa a pinch i guess you do what ya need to.
post #12 of 22 (permalink) Old 11-23-2007, 03:39 PM
you think those clutch screws are tight, you should try to remove the screws from the stator plate on the other side of the motor. incredible. the crazy part is they arent really in that tight, the tolerances are just perfect so they fit together fricken perfect. This is one of the many reasons why the honda bottom end is so good, japanese quality.
post #13 of 22 (permalink) Old 11-23-2007, 03:50 PM Thread Starter
well i have the clutch out and in my hands i would like to install the hd springs. the new ones that i got look like they are to big?? are these correct??
the old ones are on the left and new on the right....
post #14 of 22 (permalink) Old 11-23-2007, 03:51 PM Thread Starter
if they are correct how do i put them in?? they look to big to fit??
post #15 of 22 (permalink) Old 11-23-2007, 03:52 PM
you've removed the wrong springs. its not the little springs on the front of the clutch, put those back. you need to remove the screws that go through the clutch pack, drop the plates out, then replace the springs inside. reassemble
post #16 of 22 (permalink) Old 11-23-2007, 04:36 PM Thread Starter
damnit! ok thanks again dude
post #17 of 22 (permalink) Old 11-23-2007, 05:19 PM
i hope you're using a service manual!
post #18 of 22 (permalink) Old 11-23-2007, 05:56 PM Thread Starter
i wish i had a service manual, this would b a whole lot easier and faster.
i was able to get torque specs off the internet but i couldnt fined a service manual
post #19 of 22 (permalink) Old 11-23-2007, 08:33 PM Thread Starter
motor is all back togeather and ready to fire up. now its time to clean up
post #20 of 22 (permalink) Old 11-23-2007, 10:25 PM
missing the kick start lever. hope you used some assembly lube!
post #21 of 22 (permalink) Old 11-24-2007, 12:30 PM Thread Starter
haha good eye. after i cleaned up i put the kick start on and the body work and fired it up. that thing has a TON of compression now. its almost hard to kick over. it fired right up and ran good.
i need to reset the valve lash, my feeler gauge is to wide and will not give me an accurate reading.
Vcook thanks for talking me out of buyn a pos motor that would have probably caused me trouble down the road and for all the info. rep on the way!
post #22 of 22 (permalink) Old 11-24-2007, 01:22 PM
you'll like the 88. great grunt, solid reliability. Get a uni filter and ditch that piece of crap it comes with.
