Now I need help with my furnace....ARGH!! - Chicagoland Sportbikes
post #1 of 35 (permalink) Old 11-26-2007, 09:47 PM Thread Starter
WTF?!?!?!? My week is just going great.
I've had intermittent problems with my heat/furnace for the past week. Again my uncle came out and looked at it...he has all the tools to diagnose that too...and he tool a few pieces apart and everything is fine. I had a friend look at it too...and he said it sounds like water. The furnace tried to ignite it just doesn't...well not every time. The gas company came out too and all that is fine as well.
So I'm 99% sure it's my vent...and it needs cleaning. This happened about 2 years ago..and I somehow got some water accumulation in my vent, there was also some bird nesting he pulled out. I live in a condo....so I have to take care of this myself.
Anywho...I called the guy who cleaned it out 2 years ago but I haven't heard back from him....so instead of just calling someone in the phone book I wanted to check here and see if anyone did this as their job, on the side...and/or knew anyone that they could recommend before I called someone.
Thanks guys!!!
Shelly
post #2 of 35 (permalink) Old 11-26-2007, 10:03 PM
Change your filter, it is a common problem.
post #3 of 35 (permalink) Old 11-26-2007, 10:03 PM
If you don't fix it on your own let me know, I've got a friend that does side work.
You're falling apart over there!!
post #4 of 35 (permalink) Old 11-26-2007, 10:05 PM Thread Starter
Already did that...didn't work
Shelly
post #5 of 35 (permalink) Old 11-26-2007, 10:09 PM
stuck in 6th gear
Ernie's Avatar
did you try sliding the fork tubes....er nevermind
blocked vent is probably getting condensation from the gases that normally flow out there. wire that up once you clean it out so the birds can't get back in it
as far as not starting, since you live in a condo, try taking your thermostat to a neighbor and make sure it works on their unit to rule out it's not a bad switch
I don't suppose you have a meter at your place so you can check at the furnace to see if it's getting 24v from the thermostat
Ernie is offline
post #6 of 35 (permalink) Old 11-26-2007, 10:36 PM
Have you tried turning the power on an off going to it? I have a light switch that kills the power to my furnace. Last winter the furnace did not work, and I turned the switch on and off. It worked again, and I was told it was an igniter switch going bad. But it was so cold, he said to let it go, and see that happened in 0 degree and up weather. It has been fine so far.
post #7 of 35 (permalink) Old 11-26-2007, 11:29 PM
RayN's Avatar
Sportbike: 04 CBR1000RR
Years Riding: 8 yrs.
Use leaf blower to blow the vent.
RayN is offline
post #8 of 35 (permalink) Old 11-26-2007, 11:53 PM
Every motor needs a turbo
LsilverR1's Avatar
LsilverR1 is offline
post #9 of 35 (permalink) Old 11-27-2007, 12:34 AM
stuck in 6th gear
Ernie's Avatar
ummm not the best idea in the world. soot is gonna be blowing a mess out somewhere and if there's blockage, all of it is going to be on the inside of her condo. pay the $$ and get a furnace guy to vacuum and inspect it
Ernie is offline
post #10 of 35 (permalink) Old 11-27-2007, 12:48 AM
Üter Zörker
Luvin' Twins's Avatar
Sportbike: Silver 'Blade
Years Riding: Jan '07
How you found us: Stumbled onto it by mistake...
Pay the $$ and get a furnace guy to vacuum and inspect it
or
Change it from "SUCK" to "BLOW" and try the leaf blower.
Luvin' Twins is offline
post #11 of 35 (permalink) Old 11-27-2007, 01:22 AM
Fart under the covers to keep warm in the meantime.
post #12 of 35 (permalink) Old 11-27-2007, 01:51 AM
stuck in 6th gear
Ernie's Avatar
Originally Posted by Luvin' Twins View Post
or
wat?
did somebody say pay for a blowjob?
Ernie is offline
post #13 of 35 (permalink) Old 11-27-2007, 05:06 AM
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
associations are responsable for the top of the vent to make sure it is not obstucted...i had to call our people to get mine cleared out cause mine was not working correctly either...as far as the tubing, yea, its your own resposability...u might even be able to use a chimney clearer to clear it out...see if they might be able to do it...
mmmm pussy
Thunderstruck is offline
post #14 of 35 (permalink) Old 11-27-2007, 10:51 AM Thread Starter
Thanks guys!!!
Tell me about it...what's next
I sent you a PM
I'm thinking it's condensation/birds.
No idea about the meter...this is me your talking to here
Yep, I've turned the power off and it's doing the same thing.
Thanks Arch
I didn't pay anything 2 years ago when this happened...so I'm hoping it's the same thing....plus we (our building) now run our own association..soooooooooo
Shelly
post #15 of 35 (permalink) Old 11-27-2007, 11:14 AM
LsilverR1's Avatar
leave it broke. please!
post #16 of 35 (permalink) Old 11-27-2007, 11:15 AM
LsilverR1's Avatar
can we break the heat in your car to?
post #17 of 35 (permalink) Old 11-27-2007, 11:27 AM
Shelly, please stay away from anything mechanical I own. You break everything.
post #18 of 35 (permalink) Old 11-27-2007, 11:35 AM Thread Starter
It was hot in my house on Sunday wasn't it...and the heat was never on. But the oven was all day for all that damn food.
See....if anyone ever wants to ride with me in MY car...then you have to deal with my heat.....I have to freeze in everyone elses car...so now it's your turn
Tell me about it..when it rains it pours....what else can go wrong!!!
Shelly
post #19 of 35 (permalink) Old 11-27-2007, 11:50 AM
Mmmmmm....
Pinkrider's Avatar
Sportbike: RIP Rsux
Ken you have known her long enough by now... PLAN AHEAD!!! When I know I'm going out with her and staying the night at her house, I make sure I'm wearing lighter clothes so I don't sweat to death.
Pinkrider is offline
post #20 of 35 (permalink) Old 11-30-2007, 10:19 AM Thread Starter
It is now a suana in my house again
I ended up calling a local company cuz it was FREEZING in my house on Wednesday...they come out yesterday and pulled out about 4 feet of birds nesting from my vent on the outside...I also had some water in there cuz the pipe wasn't supported correctly to allow it to drain.
So they fixed it all....and hopefully it shouldn't happen again
Shelly
post #21 of 35 (permalink) Old 11-30-2007, 10:24 AM
LsilverR1's Avatar
great, now i cant come over all winter.
dont be surprised if it breaks again. wasnt me
post #22 of 35 (permalink) Old 11-30-2007, 10:54 AM
Glad you're in ship shape now w/ the heating
post #23 of 35 (permalink) Old 11-30-2007, 11:06 AM
post #24 of 35 (permalink) Old 11-30-2007, 11:15 AM
stuck in 6th gear
Ernie's Avatar
did anybody install any mesh to stop the birds from getting in there and doing it all over again?
Ernie is offline
post #25 of 35 (permalink) Old 11-30-2007, 11:18 AM
WTF.. and eliminate a future service call? Are you nuts?
post #26 of 35 (permalink) Old 12-03-2007, 06:30 PM Thread Starter
Damnit Ken, I'm going to beat your ass!!!!
My heat is not working again!!
Shelly
post #27 of 35 (permalink) Old 12-04-2007, 08:40 AM
That sucks!
Do you still have access to the horizontal section of the vent stack?
uniball is offline
post #28 of 35 (permalink) Old 12-04-2007, 10:12 AM
Labdog's Avatar
Shelly-- I understand you are having issues with birds nests etc... DID they indeed screen off the flue? If so did they clean/brush down the flue? Do you have a newer furnace? Is your water heater flue also tied into your furnace flue?
Reason i am asking is because you can do a quick draw check on your water heater by lighting a candle and blowing it out at the base of the water heater flue to see if the fire is drawn up and the smoke is drawn up as well. If its a quick drawing stack effect you should be good.
NOW--- Some and or most all newer furnaces have an airflow "sensor-switch". If it doesnt sense good draw it will not allow the furnace to fire. You said you had some water / condensate and its possible your draft air flow switch could be faulty or kinda plugged now. Have someone check that for ya....
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #29 of 35 (permalink) Old 12-04-2007, 10:19 AM Thread Starter
Originally Posted by uniball View Post
That sucks!
Yep....
Well now it's going on this morning...WTF!!! It wouldn't even ignite last night...but my water heater is electric and furnace is gas...so can I really still test that?
And yes they said they fixed the outside so birds couldn't get back in...we(the building) are going to get some covers to put on all of them (since we run our own association).
My furnace is about 2.5 years old...and they said it's a condensating furnace so the water has to drain somewhere...well I see a bit of water on my floor which was never there before.
They should be back out in a bit.
And I'm sick...so I really need my damn heat!!
Thanks guys!
Shelly
post #30 of 35 (permalink) Old 12-04-2007, 10:25 AM
you just need to get a professional in there and quit trying to rely on others. Youre dealing with gases etc and you shouldnt be messing with something thats potentially life threatening
