lost keys - Chicagoland Sportbikes
post #1 of 22 (permalink) Old 12-25-2007, 12:59 PM Thread Starter
lost keys
misplaced the keys to both of my bikes. how do i get copies and how simple of a process is it?
thanks
Jenya is offline
post #2 of 22 (permalink) Old 12-25-2007, 01:01 PM
I know with cars all you need is your VIN and proof of ownership and the dealer can cut them from that. Not sure on bikes so I'd call the stealership and ask first.
post #3 of 22 (permalink) Old 12-25-2007, 01:01 PM
you can usually get key sets off ebay for pretty cheap, ignition, cas cap, keys.
post #4 of 22 (permalink) Old 12-25-2007, 01:06 PM
set them both on fire there worthless now.
post #5 of 22 (permalink) Old 12-25-2007, 01:15 PM
Its easier to put out by your mailbox on garbage day, btw whats the address?
I would call stealership, ask cost. then debate replacement or buy new off of ebay.
post #6 of 22 (permalink) Old 12-25-2007, 01:20 PM
Move along
Eugene's Avatar
Sportbike: 08 GSXR 600
Years Riding: Day after yesterday
How you found us: referred
Send a message via AIM to Eugene
I will take one off your hands for $100.00.
Xbox Live: BrBGot2Pee
Eugene is offline
post #7 of 22 (permalink) Old 12-25-2007, 01:27 PM
leavundst's Avatar
Years Riding: 9
How you found us: Jesus
On the gsxr there is a code on the bottom of the ignition key block. The down side is that you need to remove it. Two security bits at the bottom. Give that code to a dealer and bam. Also a locksmith could take care of you.
You know the Germans, if you donīt join the party they come and get you.
leavundst is offline
post #8 of 22 (permalink) Old 12-25-2007, 01:30 PM Thread Starter
thanks for the info
Jenya is offline
post #9 of 22 (permalink) Old 12-25-2007, 01:42 PM
A to B is for Amatuers
goof4080's Avatar
Sportbike: 2 Wheeled Junk
How you found us: BWA
goldielocks or goldsmith whatever that locksmith is called will come cut them at your property for sub $100 i think,
that's what Icehouse had to do before i bought his old bike
goof4080 is offline
post #10 of 22 (permalink) Old 12-25-2007, 01:46 PM
a lock set is around $170-$200 for a Honda. Or, you can sometimes pull the ignition off, and the code will be stamped on the cylinder, which you can then take to a dealer and get a key maked
post #11 of 22 (permalink) Old 12-25-2007, 01:49 PM Thread Starter
minimal investment, maximum return. lock set seems a bit too much
Jenya is offline
post #12 of 22 (permalink) Old 12-25-2007, 01:52 PM
do you have your title and proof of purchase in your name? Take it to a dealer and have them make a key for you.
post #13 of 22 (permalink) Old 12-25-2007, 01:54 PM
unless you bought the bike new, the dealer prolly can't help you. locksmith is prolly the best option, or pull ignition and take to locksmith
post #14 of 22 (permalink) Old 12-25-2007, 02:00 PM
Fear is the mind killer
ChiefBD's Avatar
Try retracing your steps first before you try the locksmith and ebay. If you find them make a spare immediately, and put the spares in a safe place.
Xbox Live GOW Killer
Handle : ChiefBDR
ChiefBD is offline
post #15 of 22 (permalink) Old 12-25-2007, 02:13 PM Thread Starter
both titles are in my name. one of the bikes was purchased new by me, the second one - used from a private seller.
I just moved and i guess will have to wait till i completely unpack to see if the keys fall out of somewhere. If not, there is still plenty of time before the riding seasoon to take care of this.
I just needed to have an idea how big of a trouble would it be to get copies.
Jenya is offline
post #16 of 22 (permalink) Old 12-25-2007, 02:16 PM
well, if you bought one new, the dealer you bought it from may be able to help. All depends on their setup procedure and computer system.
The Honda dealer i work at, we only record key codes for new bikes, so might have to pull ignition on the other one.
post #17 of 22 (permalink) Old 12-25-2007, 03:11 PM
CRF50 Squid
Years Riding: Veteran Poser
You moved? I thought you lived with Steve. What happened?
Blah Blah Blah is offline
post #18 of 22 (permalink) Old 12-25-2007, 03:15 PM
Screwdriver. That's the setup I have on my 1975 CB550, no one is gonna lift that bike and it gets a chain and lock when it's parked, so I'm not worried.
post #19 of 22 (permalink) Old 12-25-2007, 03:23 PM
Brian, I have a handful of keys for Mandys bike. I will bring them over, try a few, see if one fits.
post #20 of 22 (permalink) Old 12-25-2007, 08:27 PM
+1 Vcook. At the end of the day - it's a helluva lot easier/cheaper to re-key everything. eBay is your friend.
post #21 of 22 (permalink) Old 12-25-2007, 08:41 PM
How you like me now?
Bratva5's Avatar
Years Riding: since Friday
My friend had to go through it. All he did is removed the ignition lock and took it to locksmith 3 days later and $30 he got the lock back with two keys.
Russ
Bratva5 is offline
post #22 of 22 (permalink) Old 06-19-2008, 01:47 PM
thanks
Was this in the purse that was stolen???
