vacuum cleaner? - Chicagoland Sportbikes
post #1 of 31 (permalink) Old 01-02-2008, 02:40 AM Thread Starter
SilentAlero's Avatar
Sportbike: 01 Giggy 7fidday
vacuum cleaner?
Anybody have a good one that lasts? Where to buy, best prices etc? Want something with the spray cleaner since those work wonders.
Dgrsuspension.com
~ High Performance Coilovers
Silentedition.com
SilentAlero is offline
post #2 of 31 (permalink) Old 01-02-2008, 02:46 AM
Define the floors/surfaces and whether or not you have a pet that sheds
Also, why or for what purpose do you need a spray cleaner? I have a "little green clean machine" and a hoover rug cleaner..each have their plus and minuses. Also, I have chewed through Hoover, Eureka and Phantom vacs (thank you 3 females with long hair and 2 shedding dogs)... not that they are bad, but some are easier to deal with and clean/replace parts than others.
post #3 of 31 (permalink) Old 01-02-2008, 02:59 AM
I just rent one of those good ones from Ace or whatever every few months.
obviously i have a vacuum also, but its not that great, and i dont even know what brand it is, and im too lazy to get up and look
post #4 of 31 (permalink) Old 01-02-2008, 03:05 AM Thread Starter
wont work for me
its majority carpet and i have 2 dogs with dark hair that shed. And on light colored carpet its a nightmare.
Dgrsuspension.com
Silentedition.com
post #5 of 31 (permalink) Old 01-02-2008, 03:19 AM
wont work for me
About how many inches is the hair? It makes a difference on the 'roller' part.
The absolute best vacuum I have ever used is the Hoover V2. It has 4 brushes, two on each side past the mid-line of the vacuum that counter rotate toward each other. IN FUCKING CREDIBLE at picking up Every little thing out of the carpet. The drawback? Longer dog hair (and human hair) if it gets trapped around the rollers will cause too much drag on the unit and eventually burn up the plastic pieces on each of the 4 rollers where they connect together (they use a metal rod to spin on, but the housing of the roller is plastic.) That piece will get off balance and will start to have a friction event with the casing if you do not clean it regularly. Cleaning is a little time consuming due to having 4 rollers but it's not rocket science.
I also have a hoover self propelled wind tunnel upright that has a larger diameter single roller that doesn't get as much wrapped around it (due to the larger diameter) and the parts are cheap (belts).
I had a Fantom Fury 10 amp that was awesome in its own right. My dog and human hair eventually did it in. When it worked, I'd place it in 2nd behind the Hoover V2.. but it eventually died due to the excess hair I kept having it pick up.
post #6 of 31 (permalink) Old 01-02-2008, 03:59 AM
Dyson, I've had one for a while and it works well, not as costly as an Electrolux but more than most Hoovers.
post #7 of 31 (permalink) Old 01-02-2008, 07:38 AM
Dyson...the purple one...for homes with pets. When I got the thing...the hosue was already vacuumed...I did it again...I couldn't believe what the Dyson picked up!
post #8 of 31 (permalink) Old 01-02-2008, 07:59 AM
MM Racing's Avatar
Sportbike: Squat
How you found us: Your Mother
+3 for Dyson, I have two cats and that thing works awesome.
Ian
MM Racing is offline
post #9 of 31 (permalink) Old 01-02-2008, 08:03 AM
Dysons suck.
post #10 of 31 (permalink) Old 01-02-2008, 08:24 AM
Dyson +4 I have long hair pet Australian Shepherd. I also use to have a Chinchilla with you had to give dust.
Dysons have shop vac power.
post #11 of 31 (permalink) Old 01-02-2008, 08:28 AM
Dyson Animal (purple one). I've had mine for 3+ years and it works better than any vacuum I've ever had or seen. It's designed for pet owners.
post #12 of 31 (permalink) Old 01-02-2008, 08:46 AM
stuck in 6th gear
Ernie's Avatar
another vote for Dyson
Ernie is offline
post #13 of 31 (permalink) Old 01-02-2008, 09:09 AM
Ducati Mama's Avatar
Sportbike: Trek
Years Riding: not often enough
How you found us: umm, my husband owns the site
I am going to buy the Bissell Pet Hair Eraser vacuum. I have read tons of great reviews on it. It is also a lot less money than the overhyped Dyson, and many of the reviews says they returned the purple Dyson for this one.
Ducati Mama is offline
post #14 of 31 (permalink) Old 01-02-2008, 09:11 AM
Bissell's suck.
post #15 of 31 (permalink) Old 01-02-2008, 09:18 AM
under200's Avatar
How you found us: web search
Oreck's outstanding warranty's
I just have a cheapo Eureka bag less. I really do not see the point of bag less ones anymore. The old bag ones needed a 2 dollar bag changed every month or two. These shitty bag less ones have no bag but typically need tons of user attention. Either a fancy screen/filter that needs to be cleaned every 3 times you use it or a filter that needs to be bought for 15 bucks every month.
We have been had by the marketing people. We are mesmerized by seeing dirt spin around in a clear cylinder. I rather have the cheap low maintenance bag back but nobody seems to make them in a upright with the attached hoses for those hard to get to spots.
Under200
under200 is offline
post #16 of 31 (permalink) Old 01-02-2008, 09:21 AM
Orecks's suck.
OK, OK! All vacuums suck!
post #17 of 31 (permalink) Old 01-02-2008, 09:22 AM
CRF50 Squid
Years Riding: Veteran Poser
Dyson if want to spend the cash. I have one of those Hoover bagless uprights. Kicks ass for sucking up doggie fur. Works on carpets and bare floors.
Blah Blah Blah is offline
post #18 of 31 (permalink) Old 01-02-2008, 09:29 AM
Sportbike: Trek
I have a Hoover WindTunnel and it sucks. Ever since I bought it it has been a piece of shit. The belts keep coming off, even after replacing them. That is why it is getting replaced. I contacted Hoover and they never responded, so they will never get my business again. Their customer service sucks.
post #19 of 31 (permalink) Old 01-02-2008, 09:56 AM
This is why I liked their V2... the 4 head rollers are gear driven
post #20 of 31 (permalink) Old 01-02-2008, 10:00 AM
The cool thing about Dyson is that they have a video game
http://www.dyson.co.uk/about/games/telescope.asp
aside from that $600.00 is a crapload of cash to drop on a vacuum
post #21 of 31 (permalink) Old 01-02-2008, 10:05 AM
I got kids...
Walter T's Avatar
Sportbike: Got one you don't want?
Years Riding: BMX days
How you found us: Used to work with "RDRASH".
I have this one:
http://www.amazon.com/Hoover-U5507-9...9285660&sr=1-3
I've had it for two year now, and I am very satisfied. Used everyday and still on the same belt with awesome suction. Works well the carpet and the hardwood. (don't try that infomercial stuff, if you rice, use the hose. sometimes it spit's a few out the back) the hose isn't real long either. Not many tools, but the ones it has are good, the upholstery attached is a monster. The only other negative is the cannister. When you empty it, you have to be careful not to spill any of the contents. So I make sure that it's well into the garbage can before I open it. It's now $79.
Watch your thoughts; they become you words...
Watch your words; they become your actions...
Watch your actions; they become your character...
Watch your Character; it will become your legacy.
Walter T is offline
post #22 of 31 (permalink) Old 01-02-2008, 10:06 AM Thread Starter
hmm, well the longest pet hair is maybe 1"
Dgrsuspension.com
Silentedition.com
post #23 of 31 (permalink) Old 01-02-2008, 10:13 AM
Labdog's Avatar
We have a Rainbow and thewife thinks its the best vacuum she has ever used! Its a bit pricey but the performance is absolutly incredible!!!! It has the shampooer that works great and all the attachments to do everything you need. We have had it for atleast 6 years and its as strong as when we bought it. There are newer models out there but we/ SHE just loves the damned thing!
This is a pretty good link and should help with some of your questions....
http://images.google.com/imgres?imgu...%3Den%26sa%3DN
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #24 of 31 (permalink) Old 01-02-2008, 10:16 AM
I bought my in laws a Dyson for Christmas and turned it on to vacuum a 2' x 2' area just to show them how to use it and it picked up an inch of crap in the cannister from that small area. They said they had vacuumed that morning too
post #25 of 31 (permalink) Old 01-02-2008, 10:22 AM Thread Starter
So far its sounding like dysons are the best. Now where to shop to get one is the next question? Is it cheaper to get online or a store?
Dgrsuspension.com
Silentedition.com
post #26 of 31 (permalink) Old 01-02-2008, 10:51 AM
Costco has them.
I bought a factory refurb at heartland america dot com. No issues with it.
I have even seen them at Big Lots
post #27 of 31 (permalink) Old 01-02-2008, 11:23 AM
Another + for Dyson. I have a referb Dyson too. If I remember correctly it was around $300 delivered. It does a great job and is very easy to use. One feature I really like is how easy it is to remove and clean the rug beater rollers. Grace sheds (no jokes ) long thick hair that has clogged every vacuum cleaner we have had. I can have the rollers out for cleaning in under 60 seconds.
Blade Runner is offline
post #28 of 31 (permalink) Old 01-02-2008, 11:38 AM
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
The Dyson also uses washable filters so you can take out the filter and clean it and put it back in. Filters are pretty easy to remove, there is a button and you just pop it out.
AgentofDarkness is offline
post #29 of 31 (permalink) Old 01-02-2008, 11:51 AM
shop vac. make sure you get a low HP one cause otherwise it really pulls on your skin when your jerking off into it.
post #30 of 31 (permalink) Old 01-02-2008, 11:53 AM
pfft.
ill_ag's Avatar
If you really want to invest in a good one go with Oreck or with Miele.
If you want to save some $ go to Best Buy and buy an $80 Hoover with the $20 add-on Best Buy protection plan. They will replace it for you at the slightest sign of poor performance.
ill_ag is offline
