C++ help - Chicagoland Sportbikes
post #1 of 19 (permalink) Old 02-08-2008, 01:27 PM Thread Starter
shhhhhhhhh!
sponge's Avatar
Sportbike: suzuki
Years Riding: yesterday
How you found us: Nabisco
C++ help
With all the IT and computer guys here, someone must be fluent in C++, anyone wants help out a little?
I am taking this class and just realize that how frustrating C++ can be. I am half way done, but kind of not meeting the assgnment requirements.
The code is about while loop with decision statement (while,,,if,,,,else,,,)
Please let me know and I will semd you the requirements and code which I have so far. Of course reward can be arranged (I am not wealthy, but I can buy you a beer or 4 next time around )
Thanks in advance.
sponge is offline
post #2 of 19 (permalink) Old 02-08-2008, 01:32 PM
habitual line stepper
Jack's Avatar
Years Riding: X
Post the code up. Several people on the board are fluent in C++ and likely to help.
Jack is offline
post #3 of 19 (permalink) Old 02-08-2008, 01:44 PM Thread Starter
shhhhhhhhh!
sponge's Avatar
Sportbike: suzuki
ok, please don't laugh too hard with my stupid codes,,,,,
Requirments:
Calculations
Use the following formulas for your calculations:
average velocity = change of position / time interval
average acceleration = change of velocity / time interval
Processing Requirements
At the top of your C++ source code, include a documentation box that resembles the ones from programs 1 and 2.
Notice (in the Sample Output below) that there are line numbers before each prompt for a position measurement. But also notice that the number does not change when invalid data is entered.
Sample Output
Motion Analysis
Enter the uniform time interval in seconds: 2.5
1. Enter a position in feet (negative value to quit): 2
Average velocity (this interval): 0.80 feet/second
Average velocity (all intervals): 0.80 feet/second
Average acceleration: 0.32 feet/second/second
2. Enter a position in feet (negative value to quit): 5
Average velocity (this interval): 1.20 feet/second
Average velocity (all intervals): 1.00 feet/second
Average acceleration: 0.16 feet/second/second
3. Enter a position in feet (negative value to quit): 4
Invalid value: 4 is less than the current position of 5. Try again.
3. Enter a position in feet (negative value to quit): 12
Average velocity (this interval): 2.80 feet/second
Average velocity (all intervals): 1.60 feet/second
Average acceleration: 0.64 feet/second/second
4. Enter a position in feet (negative value to quit): -1
Codes
int main()
float timeinterval;
int intervalcount=1;
float position, positiona, positionb;
float avgvelocity, avgvelocityb;
float avgvelocityall;
float avgacceleration;
cout <<"Please enter the uniform time interval in second: ";
cin >> timeinterval;
cout <<"Please enter a postion in feet (negative value to quit): ";
cin>> positiona;
avgvelocity= (double)(positiona)/timeinterval;
avgvelocityall=(double)(positiona)/(timeinterval*intervalcount);
avgacceleration=(double)(avgvelocity)/(timeinterval);
intervalcount++;
cout < cout < cout <
cout< cout <<"Please enter a postion in feet (negative value to quit): ";
cin>> positionb;
while (positiona>0 and positionb>0)
if (positionb {
cout < }
else
position=positionb-positiona;
avgvelocityb= (double)(position)/timeinterval;
avgvelocityall=(double)(positionb)/(timeinterval*intervalcount);
avgacceleration=(double)(avgvelocityb-avgvelocity)/(timeinterval);
intervalcount++;
cout < cout < cout < }
cout < cout <<"Please enter a postion in feet (negative value to quit): ";
cin>> positionb;
return 0;
Thanks again
sponge is offline
post #4 of 19 (permalink) Old 02-08-2008, 04:08 PM
Jack's Avatar
Years Riding: X
See if this gives you a few ideas. You'll have to debug it because I just whipped through it and didn't even compile it. Obviously you'll have to format the output to the user. Creating an object would be a nice touch and clean it up a little.
Code:
int IntervalCount = 1;
float TimeInterval = 0;
float Position = 0;
float NewPosition = 0;
float Velocity = 0;
float NewVelocity = 0;
float Acceleration = 0;
// get the uniform time interval from the user
cin >> TimeInterval;
// if user enters negative value here, we're done so exit.
if (TimeInterval < 0)
	return 0;
// get user's first position relative to zero
cin>> NewPosition;
// loop through getting new positions until the user enters a negative value
while (NewPosition > 0)
	// Check input for valid position
            // note: assumes Position = 0 for first run
	if (NewPosition < Position)
		// write try again message since input is not valid
		// Invalid value: 4 (NewPosition) is less than the current position of 5 (Position). Try again.
	else	// input is valid, so make calculations and display
		// average velocity = change of position / time interval
		NewVelocity = (NewPosition - Position) / TimeInterval;
		// average velocity for all runs
		// change of position / time interval
		Velocity = NewPosition / TimeInterval; // assumes original starting position of 0
		// average acceleration = change of velocity / time interval
		Acceleration = (NewVelocity - Velocity) / TimeInterval;
		//OUTPUT THE CALCULATIONS HERE: NOTE VALUES HAVE TWO DECIMAL PLACES
		//Average velocity (this interval): NewVelocity feet/second
		//Average velocity (all intervals): Velocity feet/second
		//Average acceleration: Acceleration feet/second/second
		Velocity = NewVelocity;
		Position = NewPosition;
		IntervalCount++;
             // Get the next position from the user
             // NOTE: USE IntervalCount HERE
	cin>> NewPosition;
return 0;
Jack is offline
post #5 of 19 (permalink) Old 02-08-2008, 04:15 PM
i'm a java developer with just enough knowledge of c++ to know i hate pointers. with that said, where's the rest of the if conditional?
if (positionb
cout <<<"invalid value ! "<<<" is less than current value " << positiona<< " try again ";
PaikyPoo is offline
post #6 of 19 (permalink) Old 02-08-2008, 04:16 PM
teets
Sportbike: teets
Years Riding: teets
How you found us: teets
Dayam.. this shit reminds me of college. I haven't done any Java or C++ programming in years. I can write you a PERL script though... or some SQL perhaps
teets
Flounder is offline
post #7 of 19 (permalink) Old 02-08-2008, 04:17 PM
if youre going to have and statements shouldnt it be double parathensis?
vs
while ((position > 0) && (positionb>0))
post #8 of 19 (permalink) Old 02-08-2008, 04:41 PM
DieselBoy's Avatar
Sportbike: 08 R6 , CRF250R
Code:
float Position = 0;
float Velocity = 0;
	return 0;
cin>> NewPosition;
		IntervalCount++;
	cin>> NewPosition;
return 0;
Few corrections :
Define new variable TotalTime = 0;
Define new variable avgVelocity = 0;
Add TotalTime += TimeInterval; inside the loop and before any of calculations
Replace Volocity = NewPosition/TimeInterval ; with
avgVelocity = NewPosition/TotalTime;
avgVelocity is your avg velocity (not Velocity)
CCS 787(ex). 08r6
DieselBoy is offline
post #9 of 19 (permalink) Old 02-08-2008, 04:46 PM Thread Starter
shhhhhhhhh!
sponge's Avatar
Sportbike: suzuki
thanks everyone, (Jack especially). I will play around more with this until I am absolutely sick of it (or lose it).
sponge is offline
post #10 of 19 (permalink) Old 02-08-2008, 07:33 PM
BusaDave's Avatar
Years Riding: Lost Track
How you found us: Tony
I don't see much that's C++ about this code other than the use of cout.
Dave
BusaDave is offline
post #11 of 19 (permalink) Old 02-08-2008, 07:35 PM
BusaDave's Avatar
vs
Not needed...see order of precedence.
Dave
BusaDave is offline
post #12 of 19 (permalink) Old 02-08-2008, 07:52 PM
been a few years
post #13 of 19 (permalink) Old 02-08-2008, 11:18 PM
Jack's Avatar
Years Riding: X
Originally Posted by DieselBoy View Post
Few corrections :
Good point, I missed that in the calculation. The real problem here is that the time interval to get the average velocity over all runs is TimeInterval * IntervalCount.
So no need for additional variables. Try replacing this line
with this line
Velocity = NewPosition / (TimeInterval * IntervalCount); // assumes original starting position of 0
If it makes it more readable, you could rename my Velocity variable to OverallVelocity.
Also, you can delete this line:
It's not needed.
Jack is offline
post #14 of 19 (permalink) Old 02-08-2008, 11:20 PM
Jack's Avatar
Years Riding: X
Agreed. It's basically C not C++. I wasn't sure they are working with classes yet. But if you are, you could wrap all the variables and calculations in a class with properties. It would clean things up a bit and make it more readable, but it's not really needed.
Jack is offline
post #15 of 19 (permalink) Old 02-08-2008, 11:23 PM
Jack's Avatar
Years Riding: X
Also noticed,
should be
while (NewPosition >= 0)
Jack is offline
post #16 of 19 (permalink) Old 02-09-2008, 12:58 AM
[Online]
Fracker's Avatar
Years Riding: Since 2004
I'm too drunk to code, but I have to comment on this. Pointers is the best thing in C++. This is the sweetness, the love and the dao. Fuck, pointers are pure sex .
- Stas
Fracker is offline
post #17 of 19 (permalink) Old 02-09-2008, 01:30 AM
BusaDave's Avatar
Don't need C++ for pointers either. Works just fine in C.
Jack, I noticed your conditional mistake, but decided not to nit-pick. I prefer people do their own homework anyway.
Dave
BusaDave is offline
post #18 of 19 (permalink) Old 02-09-2008, 11:24 AM
Jack's Avatar
Years Riding: X
Another thing to consider, is since the user enters the TimeInterval you should do a test for TimeInterval==0? If it is zero you should prompt them to enter a positive number or negative to exit. TimeInterval can not be zero since it wouldn't make sense and you would get a division by zero if you tried to do the calculations.
Jack is offline
post #19 of 19 (permalink) Old 02-09-2008, 11:28 AM Thread Starter
shhhhhhhhh!
sponge's Avatar
Sportbike: suzuki
Man, you guys are hardcore on this. Thanks a whole bunch. I will now go see some hot bikes and weird people walking around in their riding jackets in the middle of dead winter, then come back and work on this again.
sponge is offline
