locksmith or store to cut ford key? - Chicagoland Sportbikes
post #1 of 27 (permalink) Old 02-21-2008, 10:41 AM Thread Starter
The Victim Newbie
clearwaterms's Avatar
Sportbike: 2007 mountain bike
Years Riding: just started
How you found us: svrider.com
I am looking for a locksmith or place that can cut a key (and has the blanks) for a 2006 ford truck.
on the PATS system on ford, it has the ability to learn a key if you present the system with two valid keys. in other words, if you take the first key, turn the vehicle to on and off a few times, then do the same thing with the second, and then insert the third key and start the vehicle, its supposed to train the computer to accept that as a valid key.
since I am getting a remote start installed on my new vehicle I need to get a key made. I am hesitant to go to ford and have them charge me $75 to program it when I can go through the steps above. I know that some places can cut and program those keys. Anybody know of one?
<-- Chris
clearwaterms is offline
post #2 of 27 (permalink) Old 02-21-2008, 10:43 AM
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
I'm not sure about the programming part, but whenever I need a key cut for my Ninja 250 I head over to Anderson Lock. They have an entire wall of blank keys. The guy at the Kawasaki dealer couldn't cut it so he told me to try Anderson. I would give them a call and see what they say.
AgentofDarkness is offline
post #3 of 27 (permalink) Old 02-21-2008, 10:52 AM
Buy a key online and take it to a locksmith. Call first to make sure they can.
post #4 of 27 (permalink) Old 02-21-2008, 10:54 AM Thread Starter
The Victim Newbie
i have tested this on taurus's and mustangs in the past, it works
http://www.fordf150.net/howto/patskey.php
<-- Chris
post #5 of 27 (permalink) Old 02-21-2008, 10:59 AM Thread Starter
The Victim Newbie
the only problem is that I don't have enough time, I am scheduled to be at the car place for the remote start / alarm install next friday evening. so im not sure if I order a key if it will get here in time for me to run it to a locksmith.
<-- Chris
post #6 of 27 (permalink) Old 02-21-2008, 11:03 AM
The Sausage king
Abe_Froman's Avatar
I was just going to post this link up. Get a locksmith to cut it and program it yourself.
Are you using the key to enable a remote start to work? Maybe you should consider a bypass module for the remote start.
The PATS system is very effective.
Da Bears!
Ducati
Abe_Froman is offline
post #7 of 27 (permalink) Old 02-21-2008, 12:03 PM Thread Starter
The Victim Newbie
bypass module, do tell.
<-- Chris
post #8 of 27 (permalink) Old 02-21-2008, 03:36 PM
I'm reading the posts late in the game however it sounds to me like the reason that you needed the "extra" key in the first place is because whoever was going to install your remote start system was going to use a bypass module that would integrate the key into it such as a "DEI 556UW" in that type your extra key would actually be placed inside of the module. Another type of bypass module that would probably work out better for you because you would not need the "extra" key would be a "DEI 556SW" what makes this module different is that it actually programs just like it was your "extra" key, with out having to go thru the hassle of having a key cut and programed only to be lost in a module. Make sense?
Any alarm/remote start installation place worth it's weight in salt should be able to offer you both types.
Rudedog74 is offline
post #9 of 27 (permalink) Old 02-21-2008, 03:58 PM
The Sausage king
Abe_Froman's Avatar
PM Sent.
Da Bears!
Ducati
post #10 of 27 (permalink) Old 02-21-2008, 04:01 PM
The Sausage king
Abe_Froman's Avatar
I saw this, do you know if this would work like the DEI 556xx brand, Rudedog?
http://www.velocitymotorsport.com/se...ransponder.htm
Da Bears!
Ducati
post #11 of 27 (permalink) Old 02-21-2008, 05:35 PM
The Corn Contingency
SSCustoms's Avatar
Sportbike: 954
How you found us: Ernie
The problem with the 556S is that it could loose its programming, requiring a return trip to the installer. The 556U won't.
If the additional key is being used for a remote start, it doesn't need to be cut to program it through the ignition. I keep Ford keys in stock at my shop for this exact reason and never cut them. If the OP still needs a key, PM me a I can help him out and provide instruction on how to program it without cutting it.
It all goes back together the way it came apart...unless it came apart at redline!
SSCustoms is offline
post #12 of 27 (permalink) Old 02-21-2008, 06:41 PM
I do believe it would work like the DEI brand but considering it is about the same price as the DEI one I would just go with a tried and true brand if possible.
post #13 of 27 (permalink) Old 02-21-2008, 06:46 PM
Yes I have heard of the 556S losing it's programing, another thought might be the DEI XK04 that is supposed to be there newest and best bypass.
post #14 of 27 (permalink) Old 02-21-2008, 10:33 PM
SSCustoms's Avatar
Sportbike: 954
The bypass kit modules are really nice. But, for the extra cost (depending on the price of a key), it isn't necessary.
post #15 of 27 (permalink) Old 02-22-2008, 10:18 AM
The Sausage king
Abe_Froman's Avatar
But having a programmed key on the vehicle to allow remote start would pretty much cancel out the PATS system as opposed to the module Rudedog suggested, right?
I don't know how easy or hard it is to "hot wire" a car, but I hear that the PATS system is a very effective system. For my money, I would keep that in place.....but I might be misunderstanding what is being suggested.
Da Bears!
Ducati
post #16 of 27 (permalink) Old 02-22-2008, 04:34 PM
I think that with everything being posted about "bypass modules" it can be confusing I will send you a PM if the system allows me to and hopefully it will answer all your questions
post #17 of 27 (permalink) Old 02-22-2008, 06:35 PM
SSCustoms's Avatar
Sportbike: 954
The module "tricks" the PATS system into thinking there is a key in the ignition while the vehicle is being remote started. Nothing is truly bypassed. The factory anti-theft system remains fully operational.
post #18 of 27 (permalink) Old 05-30-2008, 09:49 PM
The original procedure works if you have 2 keys.
I only have 1, any local places that will program or provide and program a key aside from the dealer.
The one here quoted me $150
sheesh
post #19 of 27 (permalink) Old 05-30-2008, 10:03 PM
A to B is for Amatuers
goof4080's Avatar
Sportbike: 2 Wheeled Junk
How you found us: BWA
gotta go to ford and they have the key with the chip in it and then as you said, turn 1, turn 2, and program the 3rd. (i think dealer cost is 20bucks btw)
goof4080 is offline
post #20 of 27 (permalink) Old 05-30-2008, 10:17 PM
those steps only work if you have 2 keys.
post #21 of 27 (permalink) Old 05-31-2008, 09:04 AM Thread Starter
The Victim Newbie
sheesh
what year is the vehicle? Ace hardware can program ford key's if its older then like 02 or 04, I can't remember exactly which.
<-- Chris
post #22 of 27 (permalink) Old 06-06-2008, 07:47 AM
you only needed 1 key prior to 2001 I think.
Mine is a 2003 exploder and which ACE are you talking about?
The ACE over here can barely cut a regular key much less program one into a vehicle.
I found a guy near Players on Ashland at $90 with him providing the key.
$80 if I provide the key. so far that looks like my least expensive option.
Later I"m going to add a key from a fusion, this has the keyfob built onto the key and after 2 keys you can program them in yourself.
post #23 of 27 (permalink) Old 06-06-2008, 01:54 PM Thread Starter
The Victim Newbie
the last one that did it for me was in eagle river wisconsin, so I don't know around here, but I called one in lombard and they at least knew what I was talkinga bout
<-- Chris
post #24 of 27 (permalink) Old 06-06-2008, 08:39 PM
If nothing else pops up,
I'm probably going to bite the bullet and go to the local guy on monday
post #25 of 27 (permalink) Old 06-06-2008, 09:06 PM
im the greek guy
Pete The Greek's Avatar
is this by any chance stolen?
Pete The Greek is offline
post #26 of 27 (permalink) Old 06-07-2008, 10:07 PM
If it was, I don't think I would be dumb enough answer your question on a public forum
post #27 of 27 (permalink) Old 06-07-2008, 10:32 PM
im the greek guy
lol it was a joke
