Car Audio question - Amp - Chicagoland Sportbikes
post #1 of 12 (permalink) Old 05-12-2008, 04:43 PM Thread Starter
The Sausage king
Abe_Froman's Avatar
I noticed a high pitch whine coming from one of the amps in my car.
About a week ago it was soft but a couple of days ago it got louder and I also noticed that the sound is not crisp. Sounds like its over driving the speakers. Is the Amp on its last legs, can it be repaired or maybe my headunit?
Someone with some car audio experience please chime in!
Alpine headunit CDA - 9835 and the amp is an Eclipse 4 channel, I'll check the model number when I get home.
Da Bears!
Ducati
Abe_Froman is offline
post #2 of 12 (permalink) Old 05-12-2008, 05:03 PM
Prolly not the head unit, try using a crossover , passive or electronic.
post #3 of 12 (permalink) Old 05-12-2008, 05:06 PM
Bop your way home...
Dr. D's Avatar
Sportbike: Hypermotard
Years Riding: since 99'
change the outputs from one set of speakers to the another to see if the noise is coming from the amp or headunit. Then it's time to see if you have a ground issue (this is usually the case). Then post back up with your findings.
-Alan-
Balancing the Paradox
of Art and Profit
Dr. D is offline
post #4 of 12 (permalink) Old 05-12-2008, 05:16 PM
SilentAlero's Avatar
Sportbike: 01 Giggy 7fidday
That or make sure your power to the amp isnt running on the same side as you speaker wires.
Dgrsuspension.com
~ High Performance Coilovers
Silentedition.com
SilentAlero is offline
post #5 of 12 (permalink) Old 05-12-2008, 05:22 PM Thread Starter
The Sausage king
Abe_Froman's Avatar
I was thinking maybe a bad ground too, but the other amp is fine.
The amp in question is powering a set of MA Audio Components with a passive crossover.
I have two amps hooked up to a distribution (?) block. I think that's what its called, been a while since I went through car audio stuff.
I will double check the ground and wires, see what I find. Anything else I should check? Thanks guys.
EDIT
Silent: I ran power on one side of the car and RCAs/speaker wires on the other.
Da Bears!
Ducati
post #6 of 12 (permalink) Old 05-12-2008, 05:28 PM
Sounds like a bad groud. Possibly loosened up or depending where you have might of gotten dirty
Also but highly doubltful could be bad set of RCA's, possible pinched wire under seat depending how you ran them and if a seat was moved recently
post #7 of 12 (permalink) Old 05-12-2008, 11:00 PM
check your ground
post #8 of 12 (permalink) Old 05-12-2008, 11:33 PM
+1 on checking the ground.
Also check the alternator, battery and chassis (I think those are the big 3) ground points under the hood of the car.
post #9 of 12 (permalink) Old 05-13-2008, 12:51 PM Thread Starter
The Sausage king
Abe_Froman's Avatar
Well, the amp in question is a 2 channel Eclipse 3322. I checked the ground connections with my mulitmeter and it seems good. I also have an Eclipse EA2212 connected to the same power and ground feeds through the distribution blocks and that one sounds just fine.
I swapped out my amps, I now have the EA2212 powering the component speakers and the 3322 powering the subs. With some tweaking on the built in amp crossovers I got it to sound better. The whine is still coming out of the one amp. If I remember correctly, capacitors make a high pitched whine when they are bad or going bad, right?
I'll check all my wiring, but I just swapped amps and it sounds better. If it is the amp, any recommendations on a new amp?
Da Bears!
Ducati
post #10 of 12 (permalink) Old 05-13-2008, 12:55 PM
change the blinker fluid, and grease the muffler bearing
post #11 of 12 (permalink) Old 05-13-2008, 12:57 PM
Is it a constant whine or does it vary when the car is running through the RPM range?
post #12 of 12 (permalink) Old 05-13-2008, 01:12 PM Thread Starter
The Sausage king
Abe_Froman's Avatar
Constant. Does not get louder when I hit the gas.
Da Bears!
Ducati
