Need Advice to Replace AirConditioning Compressor in Excursion - Chicagoland Sportbikes
post #1 of 32 (permalink) Old 06-11-2008, 06:05 PM Thread Starter
So, the frackin thing broke on the way to Heartland.
Patient:
Overworked/Underpaid massive trailer hauling, country crossing, 2000 Ford Excursion V-10 with Auxiliary Air Conditioning (Rear Air)
Symptoms:
Nice little rattle noise when truck is running.
AC no workie
AC blow hot air
Wife not happy
Windows down make noise
Windows down in rain make passengers all wet
Determination:
Fix because wife says so.
Diagnosis (unverified):
Bad AC Compressor
Prescription:
Remove/replace AC Compressor
Recharge System with Freon (55-60oz. capacity)
Request:
How the heck do I do this????
Need it fixed by tomorrow night, so that we can go to Putnam on Friday in glorious palatial and cool comfort.
Worry: High pressure hoses... how do I remove the pressure so that I can remove the unit and replace.
I went to Elgin Super, bought the replacement unit. I went to CarQuest bought the hose and the 60oz. of Freon.
What's next?
post #2 of 32 (permalink) Old 06-11-2008, 06:08 PM
Talk to Ryan, he has the tools and the machine you're gonna need to suck the system down to vacuum once you replace the compressor.
Edit: this is not something that you can do properly in your driveway.
post #3 of 32 (permalink) Old 06-11-2008, 06:10 PM
i wish i knew anything about that stuff but i got no idea man.
post #4 of 32 (permalink) Old 06-11-2008, 06:19 PM Thread Starter
Man, I need a machine? Who is Ryan?
post #5 of 32 (permalink) Old 06-11-2008, 06:20 PM
Yup, you will need a vacume pump to suck the system down after you open it up. your also gonna want some nitrogen to blow the system out first, get with Ryan, he can bang it out for ya. screen name Ryan, oh and our beloved moparboyy may be able to help ya also.
or just go trade that big boy in on a nice diesel 2500 suburban.
post #6 of 32 (permalink) Old 06-11-2008, 06:29 PM
Richfiero's Avatar
Sportbike: 06 Ninja zx636
Years Riding: 6 years
How you found us: no
You might get lucky and it only be the clutch.
Richfiero is offline
post #7 of 32 (permalink) Old 06-11-2008, 06:32 PM
How can we determine that? The clutch does not engage when the AC is turned on and the engine is running.
On the Dakota, there is a low pressure sensor thats get shorted out so the compressor continually runs. Who knows excursions.
I already had left Mopar a VM. Just waiting a call back.
post #8 of 32 (permalink) Old 06-11-2008, 06:43 PM
They all have pressure sensors. If the compressor itself is making clanking noises then I'm 99% sure it's shot. A/C systems are all pretty much the same Greg, you don't have to a Excursion guru to fix it.
post #9 of 32 (permalink) Old 06-11-2008, 06:43 PM
Sure you are just not out of refrigerant, and being low makes the compressor not engage?
My venture had a problem that someone said I needed a whole new compressor. Turns out I had a leak in the line (known technical service bulletin) and 2 cans of the refrig w/ the leak-seal worked like a champ last year. After this past winter, voilla, still good
post #10 of 32 (permalink) Old 06-11-2008, 06:52 PM
THe coolant is also the lubricant for the compressor.
Most systems have a pressure - check switch that prevents the compressor
from running if the coolant ( lubricant ) is all gone.
Could just be flat ( leaked ).... I believe you can check the system pressure on one of the schrader valves near the compressor ( have a book ?) not sure what the value should be.
post #11 of 32 (permalink) Old 06-11-2008, 07:01 PM
Registered Loser
Otis's Avatar
Sportbike: 06 gsxr 1k
How you found us: i forgot
Check the clutch.
Theres a 2 pin connector on the front of the compressor.
Its a simple electromagnet.
use a test light or a meter to check 12v power and ground.
If you have both and it does not engage, its the clutch.
Its very common, cheap and easy.
Otis is offline
post #12 of 32 (permalink) Old 06-11-2008, 07:46 PM
Wink PM sent with Ryan's # but I called and he's booked solid til after Friday.
post #13 of 32 (permalink) Old 06-11-2008, 07:49 PM Thread Starter
So, update, all great info coming, thanks guys.
We pulled the clutch face off and the outer ring was loose and making a ton of rattling when running. Put the new outer face on, and started it up. No noise.
That part is solved, however, no cool air either.
Just got off phone with Mopar again and he suggested same thing with the 12V check. Only prob is that Greg's voltmeter is at home. Gonna call Glenn (Insomniac) he lives a block away or two and has one....
post #14 of 32 (permalink) Old 06-11-2008, 07:50 PM Thread Starter
Thanks Chey, we'll see what we can do from this end.
post #15 of 32 (permalink) Old 06-11-2008, 08:44 PM
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
Is your clutch engaging? If it isn't engaging then check if there is 12V at the wire for the clutch solenoid(GY/WH).
If there is 12V
If the clutch is receiving 12V, it should engage. I would check the resistance on the clutch coil, the coil might have burned out. If the coil is burned out, the clutch won't work.
If there isn't 12V
The clutch receives power from the Compressor clutch relay, so the first thing I would check is to see if this relay is working properly. Check for 12V at the coil side, if there isn't 12V then one of the A/C controls is stopping the clutch from engaging. From the schematic I am looking at, it seems that the PCM grounds the coil side of the relay. The coil side of the relay gets power from the fuel pump relay. The PCM receives a signal from A/C clutch cycling pressure switch, Refrigerant contamination switch, and function selector switch. I haven't read all the stuff on this system, but here is how I think it works. Power goes to the selector switch, if you select A/C or whatever, power flows to the rest of the circuit. The circuit has two more switches, the pressure switch and contamination switch. If both of these switches are closed, the PCM receives a 12V signal. This tells the PCM that the A/C system is OK to turn on. Then then grounds the coil side of the relay, which in turn closes the switch side of the relay. This causes power to flow to A/C compressor clutch and the compressor should engage. There is also a diode in the compressor clutch circuit, it is suppose to absorb voltage spikes.
If you want schematics so you can check them out for yourself, I can probably get them for you.
AgentofDarkness is offline
post #16 of 32 (permalink) Old 06-11-2008, 08:51 PM Thread Starter
Clutch not engaging. Getting a way to test the 12v in another hour.
Thanks!
post #17 of 32 (permalink) Old 06-11-2008, 10:15 PM
Just got back...... You Got your meter Wink ?
post #18 of 32 (permalink) Old 06-11-2008, 10:37 PM
so what ya find?
post #19 of 32 (permalink) Old 06-11-2008, 10:49 PM Thread Starter
Nah, no meter. Gonna worry about it after the weekend. Got the outer portion of the clutch replaced at least the rattling noise is gone. Will worry about fixing it on Monday and thereafter, I have until Iowa (2 wks) to get it fixed that way.
Thanks for the help.
post #20 of 32 (permalink) Old 06-12-2008, 09:40 AM
I got a few volt meters if you need to borrow one Wink, but I'm not exactly close to ya.
post #21 of 32 (permalink) Old 06-12-2008, 09:56 AM
wink ive done a decent amount of work to my ac om my car, including replacing the condenser coil, if its empty of refrigerant you dont need the expensive reclaimer just the evacation pump, which i have. ive got the gages to check the pressures as well.
keep us informed
post #22 of 32 (permalink) Old 06-12-2008, 10:05 AM
keep us informed
You can rent pressure gauges and the vacuum pump from AutoZone for free. Its going to be hard to check the pressure in your A/C system as the compressor doesn't turn at this point. Do you have reason to believe there may be a leak? The compressor will not turn if you are low on refrigerant. One of the functions of the pressure switch is to only allow the compressor to run if the refrigerant level is correct. If there is no leak the refrigerant levels are correct, the problem is probably in the electric circuit that controls the clutch. If there is a leak, the pressure switch will probably stay open.
post #23 of 32 (permalink) Old 06-12-2008, 10:49 AM
I may have a multimeter in my car wink. if you need it we can meet at lunch.
post #24 of 32 (permalink) Old 06-12-2008, 10:57 AM
you can check the pressure of the system without the a/c compressor being on. This will tell you if any freon has leaked out. But not the pressure of the overall system as in the low and high side when the compressor is running. And you can jump the low pressure switch to turn on the compressor. Or even jump the clutch directly.
post #25 of 32 (permalink) Old 06-12-2008, 11:01 AM
SNF
Gixxer6Dan's Avatar
Sportbike: Nothing.
Dan is unhappy.
Dan wants cold air.
Gixxer6Dan is offline
post #26 of 32 (permalink) Old 06-12-2008, 11:27 AM
Dan, update your signature and stop your bitching.
post #27 of 32 (permalink) Old 06-12-2008, 11:52 AM
When you shut the A/C off, doesn't the pressure in the system equalize? Is there a certain pressure that the system will have when its turned off? Is this pressure lower when refrigerant has leaked out?
post #28 of 32 (permalink) Old 06-12-2008, 12:07 PM
Ninja Kick!
Insomniac's Avatar
Sportbike: 09 R6 09, RS125
Years Riding: Not enough
How you found us: Spongebob
I got a bit held up last night, multimeter has been dropped off at Wink's this morning.
Insomniac is offline
post #29 of 32 (permalink) Old 06-12-2008, 12:18 PM
Man wheres fierospeeder and his scope when you need him?
post #30 of 32 (permalink) Old 06-12-2008, 12:21 PM
I got one of those.
Somewhere
