Suspension baseline - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 06-19-2008, 03:35 PM Thread Starter
Suspension baseline
Ive been thinking, and a little bored lately
I want to do a baseline suspension sag setup on my bike.
The other day I changed over to the galfer superbike frontbrake lines and was testing in front of the house them to what the difference in feel was. Anyways, id get up to about 35-40 and roll into the brakes. at the third try I was getting into it hard enough to barely lift the rear but it felt like the front end was either bottomed and actually was pogoing a bit, that is a sign that the front end s right on the ragged edge of locking completely right?
I was looking at the wiper line on the fork tube and Im definately using up the vast majority if not all of the available travel doing this.
Could someone help me out with doing a baseline on my bike at some point.
post #2 of 9 (permalink) Old 06-19-2008, 03:36 PM
Make sure your knees and elbows are on level surfaces
post #3 of 9 (permalink) Old 06-19-2008, 03:54 PM Thread Starter
should I slide the fork tubes up to compensate as well???
post #4 of 9 (permalink) Old 06-19-2008, 03:56 PM
Yes make sure you lube them really good
post #5 of 9 (permalink) Old 06-19-2008, 04:24 PM Thread Starter
lol
post #6 of 9 (permalink) Old 06-19-2008, 05:30 PM
Dug2's Avatar
Years Riding: yes
keep in mind; its possible you need new (stiffer) springs.
check out racetech.com
they have a spring calculater for you to figure out wat
springs you may need. my .02
Dug2 is offline
post #7 of 9 (permalink) Old 06-19-2008, 05:35 PM
Pierced & tattooed freak!
GixxerDave's Avatar
Sportbike: 1999 GSX-R750
Can you feel the love here?
GixxerDave is offline
post #8 of 9 (permalink) Old 06-19-2008, 05:41 PM
Talk to Marshall at Turn One Racing they charge $45 and can give ALOT of information to you.
Sklossmonster I believe is his screen name on here
post #9 of 9 (permalink) Old 06-19-2008, 06:17 PM Thread Starter
According to the calc for the street i need .860kg/mm springs adn .850kg/mm is what came stock for the front
for the rear they recommend 7.61kg/mm and stock is 8.6kg/mm
for the front im about as close as possible but the back is a full kg off
