06 gsxr 1k problems - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 08-25-2008, 02:56 AM Thread Starter
06 gsxr 1k problems
hey guys in mot a nweb but for some reason it wont let me post. i think my account was disabled by the admins. my username is colloso if anybody wants to help me figure that one out, but on a much more serious note...
IM STUPID. my bike worked perfectly fine but i decided to take a look at my spark plugs. i took off the airbox as well as all the accompanying hoses and sensors. pulled off the coil and unscrewed the plug. i went away and my buddy NOTE: retard, decided to start the engine. i come back and NOTE: retard, admire the cool sound of only 3 cylinders firing. after the bike is back together i realize i probably filled the cylinder with gas... and i didnt put the bike back together until about a week later. now when i start it, it idles badly. in fact it sputters at all rev ranges and wont idle. when i let off the throttle it cuts out.
any help?
limitdone is offline
post #2 of 9 (permalink) Old 08-25-2008, 06:40 AM
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
it almost sounds like a few spark plugs wires might have been switched around when they plug back into the head...make sure u have the right wire plugs on the right cylinders...this would also cause this problem, as it would in a car...so double check that...
mmmm pussy
Thunderstruck is offline
post #3 of 9 (permalink) Old 08-25-2008, 06:48 AM
redo entire operation minus retarded friend. make sure all hoses are in proper locations, all wires go to their proper plugs, all coils are firmly seated on plugs. without a spark plug that cylinder wont flood with the engine running, the liquid gets pumped out the spark plug hole with each upstroke.
post #4 of 9 (permalink) Old 08-25-2008, 08:10 PM Thread Starter
okay. im gonna try it right now
post #5 of 9 (permalink) Old 08-25-2008, 09:58 PM Thread Starter
okay. so when i FIRST pulled the plug out (back when the bike worked perfectly) it looked great. i put it back in, the bike didnt run well, i pulled all of the plugs back out and they're covered in some kinda black residue. like if you took a lighter to a fork or something like that.
any suggestions? i already know i have to replace the plugs now but does anyone know what i did wrong to make that happen?
post #6 of 9 (permalink) Old 08-26-2008, 06:41 AM
the black stuff is carbon.
i would seriously ask retarded friend if anything was put into the engine then it was run without the plug
was the coil module still hooked up to its ignition wires when he ran it, im concernec the high voltage discharge might have screwed something up
once youre done redoing everything try disconnecting the battery for a minute or 2 this should clear the computer of any trouble codes hopefully.
post #7 of 9 (permalink) Old 08-26-2008, 07:31 AM
Note to self never let friends that wanna hear the bike around when it is in pieces
post #8 of 9 (permalink) Old 08-26-2008, 08:07 AM
oh yea...
you need to kick this friend in the nuts if you havent already, if you have do it again to refresh the lesson
post #9 of 9 (permalink) Old 08-26-2008, 08:13 AM
IM STUPID.
i am 1 of the admins here, i just checked your account. you never activated your account by checking your e-mails for the confirmation e-mail that gets sent out automatically for new users to confirm there registration.
so ahh your accusation is
good luck getting your bike fixed.
