Street braking vs. track braking? - Chicagoland Sportbikes
post #1 of 32 (permalink) Old 08-27-2008, 01:48 PM Thread Starter
oh my...
Timmay!'s Avatar
Sportbike: '98 VFR + '03 Gixxer 750
Years Riding: According to my wife... too many.
How you found us: VFR World Forums
Send a message via MSN to Timmay! Send a message via Skype™ to Timmay!
They say the only dumb question is one not asked, so here goes...
Is there a difference in the way the brakes are used on the track vs. the street? For the Track/Street riders is there a difference in the way you brake?
"The tragedy in life is not what we suffer, it's what we miss."
NESBA #921 (I)
www.crashcoalition.org
'03 Gixxer 750
'05 VFR800
'05 745i (E65)
Timmay! is offline
post #2 of 32 (permalink) Old 08-27-2008, 01:50 PM
Squeeze vs _______
post #3 of 32 (permalink) Old 08-27-2008, 01:52 PM
Evil Moderatrix
KBOlsen's Avatar
Street riding: Controlled, steady application of both brakes.
Racing: Late, smooth, maybe a little harder using the back brake very judiciously.
Kim
I break stuff
Duck, duck, duck, GUZ!
KBOlsen is offline
post #4 of 32 (permalink) Old 08-27-2008, 01:53 PM
Yes and no.
On the track....
You apply a little brake to load the front ~1 heartbeat.
Then you ramp up to a high 95 % level.
At the end you fade off slowly to zero.
On the street....
Same EXACT thing..... just limit the middle to 70% or so
with the rest remaining in emergency reserve.
You never EVER *SNAP* the brakes on !
When the front is unloaded ( before the heartbeat...settle )
the front has limited load and traction. SNAPING the brake
on will lock the front wheel.
That;'s when the hand of god spikes your helmet to the asphalt...... WHAM!
post #5 of 32 (permalink) Old 08-27-2008, 01:56 PM
TDaytona650's Avatar
Sportbike: Sold the D650 and now sportin an 04 R1
Years Riding: Miles or years? I got em both under my belt...
To build on the already mentioned comments,
For street riding, you typically tend to brake smoother- starting with light pressure and applying more brake as need be.
From a track/racing perspective, the initial braking is usually more sudden or dramatic. This enables the driver to focus more on accelerating through the turn as opposed to slowing for the turn.
TDaytona650 is offline
post #6 of 32 (permalink) Old 08-27-2008, 01:59 PM Thread Starter
oh my...
Timmay!'s Avatar
Allow me to clarify the question a bit... I was asking more about the application of the front brake vs. the back brake on the street vs. the track.
NESBA #921 (I)
'03 Gixxer 750
'05 VFR800
'05 745i (E65)
Timmay! is offline
post #7 of 32 (permalink) Old 08-27-2008, 02:00 PM
Yes and no.
On the track....
On the street....
Best description of it I've read. :
post #8 of 32 (permalink) Old 08-27-2008, 02:13 PM
Using the rear brake..... on the track ?
I do not..... as you transfer weight to the front the back wants
to lock.... if you don't do this just right it's an issue. Sometimes
the back wheel is clear off the ground !
On the street, I occasionally use it when I am two up, but if
pushed, or rushed I use only the front brake....
post #9 of 32 (permalink) Old 08-27-2008, 02:17 PM
Yes and no.
On the track....
On the street....
That's it right there. Perfect explanation.
post #10 of 32 (permalink) Old 08-27-2008, 02:21 PM
brakes on the track???, only for the slow
post #11 of 32 (permalink) Old 08-27-2008, 02:25 PM
beac83's Avatar
Sportbike: A couple
On the street I'll use the back brake, but at the track, only when coming to a final stop in the pit, if then, or when I've run off onto the grass, and then, very carefully.
Track = Front brake ONLY
Street = Use both brakes, Front brake 80-90% of stopping power, back 10-20% of stopping power.
This also varies by type of bike. The above is for the CBR. On the GW and FJR I tend to use the back brake more often, sooner and harder, especially with the GW. On the GW front brake only will take quite a while to stop the bike. I sometimes get reminded of that after riding the CBR and switching.
________________
beac83 is offline
post #12 of 32 (permalink) Old 08-27-2008, 02:29 PM
on the street, On a sportbike all anyone ever really needs is the front brake. Now it's different on a cruiser.
Now me personally, for some reason modualting both front and rear together comes very naturally to me, but for most it does not. this probably comes from switching back and forth from cruisers to sportbikes and now add in dirtbikes. but having that perfect technique is very rare.
post #13 of 32 (permalink) Old 08-27-2008, 02:31 PM
Most cruisers you just squeeze both brakes as hard as you can and pray you stop in the next mile or so.
post #14 of 32 (permalink) Old 08-27-2008, 02:31 PM
El Burrito Volador
spyder84's Avatar
Years Riding: I'm a rookie.
To add to Tom's explanation, I like to illustrate braking as a bell curve. The y-axis being brake presssure and the x-axis being your position relative to the apex - the apex being the end of the curve. Of course the curve would be different depending on the corner, pace, etc. But it makes it easier for me to understand how the front brake lever is used smoothly from 0%-XX%-0% to get the bike to slow down and change geometry to initiate turn-in.
Erik
05 GSXR600
spyder84 is offline
post #15 of 32 (permalink) Old 08-27-2008, 02:31 PM
Open the fucking throttle you whiny little girl.......
post #16 of 32 (permalink) Old 08-27-2008, 02:33 PM
Originally Posted by spyder84 View Post
To add to Tom's explanation, I like to illustrate braking as a bell curve. The y-axis being brake presssure and the x-axis being your position relative to the apex - the apex being the end of the curve. Of course the curve would be different depending on the corner, pace, etc. But it makes it easier for me to understand how the front brake lever is used smoothly to get the bike to slow down and change geometry to initiate turn-in.
That's the 301 class right there......... .but that is a good explanation.
post #17 of 32 (permalink) Old 08-27-2008, 02:34 PM
Oh it's on like donkey kong. See you this weekend.
post #18 of 32 (permalink) Old 08-27-2008, 02:34 PM
El Burrito Volador
spyder84's Avatar
I figured it was overkill....
Erik
05 GSXR600
spyder84 is offline
post #19 of 32 (permalink) Old 08-27-2008, 02:35 PM
Ahhhh you have ridden a Harley
post #20 of 32 (permalink) Old 08-27-2008, 03:11 PM
Illegitimi non Carborundu
Paul's Avatar
Sportbike: That Bike
Years Riding: That Long
I usually listen to old school techno when I brake on the streets - like Rocket. It's much easier to make those robot moves to music that supports it. i usually don't brake on the track.
2012 Goldwing Owner
2013 Ninja 1000 Owner
Paul is offline
post #21 of 32 (permalink) Old 08-27-2008, 03:14 PM
breaks are over rated
post #22 of 32 (permalink) Old 08-27-2008, 04:37 PM
ZOMBIES ON FIRE!!!
crjBeez's Avatar
Sportbike: a couple
Years Riding: i've learned a few lessons
How you found us: youporn
Send a message via AIM to crjBeez
when i first started riding way back when, i was told to completely ignore the rear brake. hell, remove it! i've grown extremely comfortable with using both in conjunction with the motor to do what i need to. it's amazing how much faster you can stop on the street when you've learned to manipulate all 3 at once!
crjBeez is offline
post #23 of 32 (permalink) Old 08-27-2008, 08:26 PM
The apex was where?
Power House's Avatar
Sportbike: '07 GSX-R 600
How you found us: A vision.
I would say if you wanna learn more on the street braking take the MSF class, they explain it all in easy terms as to why you would use 1 of the brakes or both, in a multitude of situations...now they don't cover any engine braking in there, which i personally have become used to using all three. so when i finally go to a track, i'm sure i'll have to "re-teach" myself how to brake properly for the track.
Power House is offline
post #24 of 32 (permalink) Old 08-27-2008, 08:47 PM
I break everything!
JonGu's Avatar
Years Riding: Since 04/2003
On the track, if with maximum braking it takes say 200 feet to slow from X mph to Y mph, then your goal is to time it so you are braking for 200 feet exactly. Any more and your not going fast enough, any less and your going to be on your head.
On the street, if it takes 200 ft to slow from X to Y, you better be slowing down way before 200ft before when you need to slow down. The application of brakes is the same regardless though, I mean brakes are brakes, you squeeze, and you slow down.
In other words, leave plenty of margin on the street but leave as little as you can on the track.
Jon Gu
CCS AM/NESBA #276
JonGu is offline
post #25 of 32 (permalink) Old 08-27-2008, 09:20 PM
Ken, You shoulda been a flat tracker!
According to Keith Code ( in his school and in his books) "On the track, the rear brake will get you into far more trouble than it will ever get you out of."
I was taught in advanced rider training that braking on the road should be done with a light touch on the rear brake and a slightly heavier hand on the front, adjusting front pressure as needed, using the rear brake as a stabilizer. The front brake provides 70% + of braking power. Always brake while still upright going into a curve or turn and accelerate (roll the throttle on) out...slow in, fast out...road or track.
The only time I use the rear brake on a motorcycle with any regularity is when I'm in the dirt... mostly setting up a brake slide or a broadslide (AKA powerslide).
My advice...
If you're going to ride track days or race...stay off the back brake, period. learn to use the front for all of your braking.
If you're street riding, use the back brake very lightly...the front provides most of your braking power and it's easy to lock up the rear wheel when the front brake is shifting all the weight to the front end. A locked wheel = skid = fall= SUCKS.
As you gain riding experience and familiarity with your bike, it will all become very automatic and second nature and you will gain confidence in what works for you.
OldTimeBiker is offline
post #26 of 32 (permalink) Old 08-27-2008, 10:48 PM
Flat tracking is a great way to learn how to use the rear brake properly. Its amazing how much you can learn when you're bar to bar screaming into a corner....and you had to remove the front brake lever before getting on track!
post #27 of 32 (permalink) Old 08-28-2008, 12:31 AM
The brake on a flat tracker is seldomly used for the purpose of actually slowing in the traditional sense...I started flat tracking in the "No Brakes" era, engine braking is how it's done on an oval. Even today, the best guys seldom use the brake unless they are using it to scrub off speed and set up the slide.
On cushion tracks...the brakes go untouched accept to stop in the pits.
Pitch it, blip it and grab a handfull to get 'er sideways and steer with throttle control and body english...if a rider is behind you, he doesn't exist...if he's in front of you you try to run up his exhaust until you can set up a pass!
You brake too hard and the guy(s) who are trying to run up your exhaust will be on top of you in the haybales!
But I digress....
post #28 of 32 (permalink) Old 08-28-2008, 08:11 AM
black magic
bio-nuke's Avatar
Sportbike: gxr600k8
Years Riding: 4yrs
crap i think i'm braking all wrong now after reading this. i haven't been on the track yet, but on the street i use all three and once i even locked them up to avoid rear ending a vett that got cut off(cat & mouse play) kinda cool actually i kept it straight with a little wiggle and left a nice patch.
bio-nuke is offline
post #29 of 32 (permalink) Old 08-28-2008, 09:17 AM
Street - Engine Brake
Track - Late with a handful
post #30 of 32 (permalink) Old 08-28-2008, 01:12 PM
Fast Old Fart on a Bike
tripod's Avatar
Years Riding: Since 1966
Aside from all the front vs rear brake, the biggest differenct to remember track vs street is that on the track, everyone is expecting you to pretty much attempt hard braking.
On the street, keeping in mind that no cage can possibly stop as rapidly as your bike, you better know that you can do a max effort stop without getting rear ended.
In other words, you better have your situational awareness up to snuff before grabbing a handful of front brake on the street.
tripod is offline
