Torx sizes - Chicagoland Sportbikes
post #1 of 41 (permalink) Old 09-19-2008, 03:11 PM Thread Starter
Torx sizes
Ive lost a couple of screws on the back of my trailer. They are all Torx. I have a T20 which is too small and a T25 which is too big
I cant find anything in between. Is this a custom tool that CargoMate uses? Anyone know where to find something in between?
post #2 of 41 (permalink) Old 09-19-2008, 03:14 PM
Why not replace them with non-goofy Torx sizes, or better yet, socket allens or hex heads?
post #3 of 41 (permalink) Old 09-19-2008, 03:15 PM
I don't think there is a standard size between 20 and 25
http://www.newmantools.com/tech/torxspecs.htm
post #4 of 41 (permalink) Old 09-19-2008, 03:17 PM Thread Starter
sure, great idea
I dont even know what length the screws are or and cant get any out because I dont have the Torx for it.
I know I could use a flathead or something to try..
So here I sit............... pondering
post #5 of 41 (permalink) Old 09-19-2008, 03:18 PM
Originally Posted by 2weelpilot View Post
sure, great idea
Take a dremel with a cut-off wheel, make'em flatheads, then go replace them with non-goofy fasteners.
post #6 of 41 (permalink) Old 09-19-2008, 03:25 PM
drozek's Avatar
Sportbike: 2010 Yamaha R1
Years Riding: 4
There are sizes for both metric and standard torx wrenches FYI
drozek is offline
post #7 of 41 (permalink) Old 09-19-2008, 03:29 PM
Audiofyl's Avatar
Sportbike: 600rr & Zuma125
Years Riding: since 2002
of all the sets I have, I own nothing between 20 and 25.
the 20 should fit them even if it is a little loose.
are you 100% sure they're torx? (not trying to insult your intelligence, but i've been fooled by a weird looking allen screw before). Because a torx will technically fit an allen, but not the other way around.
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
1994 Honda Civic Turbo
My Fuelly
Flickr
posterous
Originally Posted by shadrach
Audiofyl is offline
post #8 of 41 (permalink) Old 09-19-2008, 03:29 PM
you need the 22.5 torx.
post #9 of 41 (permalink) Old 09-19-2008, 03:32 PM
not true. There is no "inch" and "metric" torx
Torx is T10, T20, T25 etc for both inch and standard. They're interchangable
there isn't any size between T20 and T25. Im not sure what you could have
<----fastener engineer
post #10 of 41 (permalink) Old 09-19-2008, 03:40 PM Thread Starter
I want a refund
post #11 of 41 (permalink) Old 09-19-2008, 03:49 PM
count the lobes on the recess. Torx has 6 lobes.
There are some security drives that look like Torx but have 5 lobes
post #12 of 41 (permalink) Old 09-19-2008, 03:51 PM
Maybe now would be a good time to ask, why Torx? Do they have any advantage over allen heads?
post #13 of 41 (permalink) Old 09-19-2008, 03:54 PM Thread Starter
Im not at home but I'll count the lobes in a while
geez I feel so dirty..
post #14 of 41 (permalink) Old 09-19-2008, 03:55 PM Thread Starter
also, it appears as though Im not going to find these screws as a replacement - hell I cant even find the damn tool to get them in or out. Yes, an allen head will probably be happening
post #15 of 41 (permalink) Old 09-19-2008, 04:01 PM
vice grips usually do the trick
post #16 of 41 (permalink) Old 09-19-2008, 04:06 PM Thread Starter
I cant grab these heads-theyre tight agaginst the side of trailer and i would end up scratching up the siding
I tried calling cargo mate and all I get is friggin VM all afternoon
post #17 of 41 (permalink) Old 09-19-2008, 04:10 PM
drill em out? I feel the pain, it really sucks when you can't get a freakin screw out.
post #18 of 41 (permalink) Old 09-19-2008, 04:30 PM
Audiofyl's Avatar
^^ even worse.....
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
My Fuelly
Flickr
posterous
Audiofyl is offline
post #19 of 41 (permalink) Old 09-19-2008, 04:50 PM
there are really only two drives that need no end-load to drive the screw. Torx and hex recesses, (allen). Not needing end load is a big plus for many assemblies
Torx are a looser fit between the recess and the bit but still work very well. Allen heads are miserable on an assembly line because the bit/recess has less clearance. Automotive picked up on Torx in the '80's and loved them. Just really been trickle down since then. Hex recesses are generally better and are sill used in most areospace and high strength apps
post #20 of 41 (permalink) Old 09-19-2008, 04:52 PM
Ahh, good info.
Knowledge rep!
post #21 of 41 (permalink) Old 09-19-2008, 05:03 PM
The Corn Contingency
SSCustoms's Avatar
Sportbike: 954
How you found us: Ernie
It looks like Torx Plus could become the new standard. Check it out: http://textron.com.au/PDFs/TP_tech/TPbrochure.pdf
It all goes back together the way it came apart...unless it came apart at redline!
SSCustoms is offline
post #22 of 41 (permalink) Old 09-19-2008, 05:07 PM
Didn't read the rest... but the screws on my trailer look like Torx, but in fact they are Number 2 SQUARE heads.
By the way, I have spare screws like this as well as the head if you need it.
post #23 of 41 (permalink) Old 09-19-2008, 07:44 PM Thread Starter
square heads?? what?
post #24 of 41 (permalink) Old 09-19-2008, 07:46 PM
They're pretty rare from what I've seen, but they do exist. Couldn't tell ya why.
post #25 of 41 (permalink) Old 09-19-2008, 07:49 PM
Like Herman
post #26 of 41 (permalink) Old 09-19-2008, 08:00 PM Thread Starter
it looks like theres 8 points on these screws???
post #27 of 41 (permalink) Old 09-19-2008, 08:22 PM
Audiofyl's Avatar
can you take a picture of one that's been cleaned?
There is a triple square which would have 12 points. I'm unsure of an 8 pointed fastener.
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
My Fuelly
Flickr
posterous
Audiofyl is offline
post #28 of 41 (permalink) Old 09-19-2008, 08:26 PM Thread Starter
I can try in the am
my point and shoot wouldnt focus but I can try my dslr
Im telling ya it looks like a torx
post #29 of 41 (permalink) Old 09-19-2008, 08:30 PM
Joe Momma...
JoJo's Avatar
Sportbike: None
I think I have some deck screws that have eight points. I remember thinking they looked like torx but something was off. I'll count them when I get home. If they are what you need you can get that bit by buy a small box of the screw since they come with the bit (assuming they don't sell that bit by itself.
Originally Posted by flinchy
JoJo is offline
post #30 of 41 (permalink) Old 09-19-2008, 09:19 PM
BandM's Avatar
Sportbike: X-1, XR-1000
How you found us: Badweb
Trailers and vans use Scrulox fasteners to secure their skins and decks. The eight sided version are called double square. #2 is the common size.
http://buy1.snapon.com/catalog/item....e=snapon-store
The dumber people think you are, the more surprised they're going to be when you kill them - William Clayton
BandM is offline
