Hot tub troubleshooting question - Chicagoland Sportbikes
post #1 of 27 (permalink) Old 03-16-2009, 05:00 PM Thread Starter
My hot tub display says it's at 102 degrees, but thats a lie, it's actually 96 according to the duc thermometer floating around in there, that I affectionately call, "Wilber the party duc".
My guess is the electronic temp sensor is the culprit here. as all pumps etc are still running correctly, the temp just isn't accurate. anyone know how to test a temp sensor before I just start throwing parts at it unnecessarily?
post #2 of 27 (permalink) Old 03-16-2009, 05:02 PM
Did you get it fully cleaned from that accident last summer?
post #3 of 27 (permalink) Old 03-16-2009, 05:03 PM
1 piece at a time
hexraptor's Avatar
Years Riding: Since I joined!
get a service manual!
although it would help if it did exist for the hot-tub, with troubleshooting to test the electronics behind it
- Steve
hexraptor is offline
post #4 of 27 (permalink) Old 03-16-2009, 05:12 PM
no clue off hand.
but since you and I have been riding together for years. I'll help ya out.
Have you tested the temp sensor when you first got the tub? It could just be the factory puts a shitty temp sensor which has a 10 degree +/- tolerance.
The sensor is close to the output where the water exits which will be hotter.
Or the tub's temp is just the setting what it will make the tub, and the thermostat for the heater is broke.
post #5 of 27 (permalink) Old 03-16-2009, 06:00 PM
Dirtbiker's Avatar
Meh. 6 degrees? Just turn the fucker up a little?
Dirtbiker is offline
post #6 of 27 (permalink) Old 03-16-2009, 06:25 PM
Lick Me
HeavyHand's Avatar
Sportbike: '01 sv650s, CRF 70
How you found us: from moparboyy
Send a message via AIM to HeavyHand
only problem you can have with a hot tub is if it is not full of naked woman.
-Nick
#86
HeavyHand is offline
post #7 of 27 (permalink) Old 03-16-2009, 06:41 PM
That would be my advice as well.
post #8 of 27 (permalink) Old 03-16-2009, 07:09 PM
Bingo.
You can spend a lot of time and water draining, replacing, filling blah blah blah.. or you can just set temp higher.
Also, Maybe your duck is fucked
post #9 of 27 (permalink) Old 03-16-2009, 07:16 PM
thats the only problem i see with it. temp? who gives a shit if the girls are naked.
post #10 of 27 (permalink) Old 03-16-2009, 07:27 PM
+2
Friction causes heat.
I predict a seven-way would raise the temperature the six degree difference.
post #11 of 27 (permalink) Old 03-16-2009, 07:36 PM
im the greek guy
Pete The Greek's Avatar
@ vcook
Pete The Greek is offline
post #12 of 27 (permalink) Old 03-16-2009, 07:54 PM
Big Pumpin
Slowride's Avatar
Sportbike: Currently without one
Years Riding: Since 1999
How you found us: bathroom wall
Hot tubs are nasty!! I love cooking in other peoples crotch funk. Nasty! Nasty!
Nasty cesspool of crap. But if there are naked girls involved I'm ok with hot tubs.
I came here to drink some beer and kick some ass. And it looks like we are all out of beer.
Slowride is offline
post #13 of 27 (permalink) Old 03-16-2009, 08:24 PM
Hmmmm. I'll take a stab the ole Duc temp guage is as unreliable as the actual product it promotes.
Well I guess the economy isn't that bad, people still have HOT TUBS!!!
post #14 of 27 (permalink) Old 03-16-2009, 08:27 PM Thread Starter
The duc temp gauge may be slightly off, but the tub is not Hot.
post #15 of 27 (permalink) Old 03-17-2009, 10:16 AM
Labdog's Avatar
Tony,
Try and remove the temperature sensor from the tub location or well housing (if you have that) and submerge it directly into the water. This will verify if the sensor has been installed where ambient outside air temps have affected it or if it is defective.
If needed insulate the wall pretty good so the outside air does not influence or fake out the actual temperature reading.
Not sure if you have the probe or cord type but you can always see if you need a new temperature sensor cord. This would be a cord that plugs into the circuit board and usually runs into a port usually connected into the "shell" of the tub to read the temperature of the water. Some of the temperature sensors are mounted or wrapped onto the heater tube itself, so see if you can find that probe and try replacing it and that should solve the problem. SOMETIMES the plug from the board to the cord or wire harness comes loose. make sure the connections are really tight. As far as a second thermometer goes you should use a decent mercury one that stays submersed. Sometimes 2 different ones side by side will prove out the sensor.
Good luck and as you know i am not a hot tub man by no means but always willing to lend a hand!
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #16 of 27 (permalink) Old 03-17-2009, 10:19 AM
Tony's got the best kind of hot tub........
the kind he takes care of and I can come over and use.
don't be dissn' Wilbur!!!!
post #17 of 27 (permalink) Old 03-17-2009, 10:43 AM
is it possible the last time i used it when i had back hair i clogged something up?
post #18 of 27 (permalink) Old 03-17-2009, 11:20 AM
post #19 of 27 (permalink) Old 03-17-2009, 12:07 PM Thread Starter
Originally Posted by Labdog View Post
Tony,
Thanks Kelly, you just gave me an idea
post #20 of 27 (permalink) Old 03-17-2009, 12:36 PM
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
Find out what the temp sensors resistance should be. Check it. I am gussing the thermistor is showing the wrong resistance. U could adjust it, so get that multimeter out.
Loki047 is offline
post #21 of 27 (permalink) Old 03-17-2009, 01:04 PM
I'm guessing that if it's a Duc it probably just needs a repair with parts only available in Italy...
post #22 of 27 (permalink) Old 03-17-2009, 11:09 PM
Labdog's Avatar
Any luck Tony?
"My dad is a tv repair man, he's got this ultimate set of tools, i can fix it!"
<--Kelly
2000 Hayabusa
2006 Honda CRF50
Labdog is offline
post #23 of 27 (permalink) Old 03-17-2009, 11:55 PM
TOOS Racing
dennywags's Avatar
Sportbike: gsxr 1000 gsxr 750
just replace the temp sensor. they go bad all the time.
dennywags is offline
post #24 of 27 (permalink) Old 03-18-2009, 12:09 AM
if you havent fixed it by now ill help you out by fucking one of your neighbors and leaving a load the size of peter north;s to lube the pipes and pumps. that always gets everything loose and working like ya dumped a bottle of slick50 in anything.
post #25 of 27 (permalink) Old 03-18-2009, 12:12 AM
slick 50= great mechanic in a bottle
peter north = pimp
post #26 of 27 (permalink) Old 03-18-2009, 12:13 AM
peter north = pimp
combine those attributes with some hot chicks and my cock?
its money in a bottle.
post #27 of 27 (permalink) Old 03-18-2009, 12:14 AM
