Any Electricians Coming to TECH DAY? - Chicagoland Sportbikes
post #1 of 15 (permalink) Old 04-17-2009, 05:02 PM Thread Starter
Hey folks,
Just curious is any electricians are coming to Tech Day tomorrow. There is only ONE electrical wall outlet in my garage. It is a GFI duplex outlet, but my Compressor easily trips the circuit breaker at the panel.
I was curious if it might be a simple swap out to a larger circuit breaker in the panel so that the darn thing doesn't trip all the time. It would be far easier to run the day without resetting the breaker at the panel all the time.
Anyhow, if anyone can help, that would be ideal.
Thanks,
post #2 of 15 (permalink) Old 04-17-2009, 08:32 PM
RIP Ashwin
MVRC51's Avatar
Sportbike: twin turbo supercharged busa
Years Riding: Just got my license
How you found us: A tramp stamp
I have some electrical background. What size circuit breaker is in there now? If it's a 15amp you could go to a 20 amp but a 30 amp would cause the wires to get to hot which is not good. To go to a 30 amp you would need to pull new (larger) wires. This is all an assumption without seeing it.
MVRC51 is offline
post #3 of 15 (permalink) Old 04-17-2009, 09:31 PM
NickIF's Avatar
Sportbike: FJR1300
I've seen a few fires from people that went from 20 to 30 without upgrading to a larger gauge wire. Be careful.
NickIF is offline
post #4 of 15 (permalink) Old 04-17-2009, 09:43 PM
Wink,
You would need to inspect the wire pull from the box to the outlet first.
Wire gauge needs to be appropriate before you upgrade the breaker.
15A 14AWG
20A 12AWG
30A 10AWG
45A 8AWG
60A 6AWG
80A 4AWG
100A 2AWG
If it happens to already be 10 gauge...... have at it.
post #5 of 15 (permalink) Old 04-17-2009, 09:45 PM
boilermaker's Avatar
Sportbike: 98 FZR 600
How you found us: the interweb
Assuming your circuit is a 15 amp and you are going to 20, make sure you have 12 gauge wire. 14gauge is standard for 15 amp cuictuits. Code requires 12 gauge wire if you are running 20 amp circuits. I am not an electrician, but was told of this by a long time electrician when I rewired my garage myself.
98 FZR600R
boilermaker is offline
post #6 of 15 (permalink) Old 04-17-2009, 10:18 PM Thread Starter
Awesome info. Perhaps we can check it tomorrow if we get a break.
post #7 of 15 (permalink) Old 04-17-2009, 10:21 PM
Used, but not used up!
Fast Eddy's Avatar
Sportbike: Witch one?
Years Riding: again, witch one?
How you found us: Blame - Troy
Wink,
I had a similar problem. I talked to a master electrician friend.
He pointed out that breakers are a mechanical device and go bad with time and heat. You may solve your problem by just replacing with a new breaker.
Ed (AKA Dirt Nap)
The liver is evil and must be punished!
http://www.facebook.com/team.chouffe
CCS #17
http://www.southeastsales.com/
Fast Eddy is offline
post #8 of 15 (permalink) Old 04-17-2009, 10:24 PM Thread Starter
Not a bad idea as well.
post #9 of 15 (permalink) Old 04-17-2009, 11:01 PM
look in something called a "delay" circuit breaker
because compressors spike right when they start and use less power while operating.
post #10 of 15 (permalink) Old 04-17-2009, 11:19 PM
your compressor should not pop a 15amp circuit. Figure out what else is on that circuit.
post #11 of 15 (permalink) Old 04-17-2009, 11:54 PM
Wink, if that is the compressor you bought from Circuit City, we ran those on 20amp breakers. Nothing else was plugged into that breaker. In all the Circuit City stores I worked at, I never popped that breaker.
post #12 of 15 (permalink) Old 04-18-2009, 12:34 AM
beac83's Avatar
Sportbike: A couple
If your house is wired with EMT conduit, changing to a larger gauge wire is pretty easy. I'll be glad to come by and do it. If it's Romex (NM) we'll have to run a new line.
It's unlikely that the contractor ran a 12 ga wire and fused it for 15A. That would be a waste of materials and cost.
I won't be back in time for Tech Day. But unless it's a huge compressor, it should run fine on a 15A breaker. (all breakers have some inherent time delay, there aren't special time delay breakers in a 15A size) I'd try changing the existing breaker for a new one first. But it would probably be a good idea to plan on an upgrade to a 20A circuit for the garage anyway.
________________
beac83 is offline
post #13 of 15 (permalink) Old 04-18-2009, 06:25 AM Thread Starter
It is that compressor. So... 5 amps more and I;d be covered, cool.
post #14 of 15 (permalink) Old 04-18-2009, 06:26 AM Thread Starter
thanks, have a good trip!
post #15 of 15 (permalink) Old 04-18-2009, 08:06 AM
Make my day!!!!!
wingit's Avatar
Years Riding: 20+ yrs.
Throw in a 30! Plug everything into it and go to lunch. After the house burns down have INS wire everything for 30.
Don't forget to erase this post before contacting INS.
Joe
FACEBOOK
wingit is offline
