manual tire changer - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 04-30-2009, 12:15 AM Thread Starter
manual tire changer
I picked up a manual tire changer for car tires and the like, comes in handy with a demo derby car...
anyways I have a trailer tire i need to get back on the rim... i get about d and it jams up...
hints tips suggestions are begged for here... nged tires before, with a coats pneumatic machine, thats not an option anymore though
post #2 of 9 (permalink) Old 04-30-2009, 12:17 AM
n00b
poor gasoline on it and set it on fire? Sorry I'm not help
zed88 is offline
post #3 of 9 (permalink) Old 04-30-2009, 12:52 AM
Captain Dryspell
Grumpy's Avatar
Sportbike: 2K4 Busa / 2K9 R1
Years Riding: About that long
How you found us: What
Make sure the bead is in the valley of the rim before trying to finish her off.
Grumpy is offline
post #4 of 9 (permalink) Old 04-30-2009, 12:56 AM
Lube. Seriously.
post #5 of 9 (permalink) Old 04-30-2009, 01:20 AM
toys4pops's Avatar
Sportbike: '07 Factory RSVR
tire changing
I could tell ya the secret but then I'd have ta kill ya!
Make sure the opposite wall is in the center valley of the rim. This will free/slack up the side you're working on. Piece of cake.
MC tires, Pirelli's are a little tighter to Remove/Replace
toys4pops is offline
post #6 of 9 (permalink) Old 04-30-2009, 01:23 AM
lube it up, and make sure the beads are in the drop center on the rim.
laundry detergent is prolly the best lube
post #7 of 9 (permalink) Old 04-30-2009, 01:39 AM
kc6
I'm mad bro
kc6's Avatar
Sportbike: butter churn
raise the forks in the triples to compensate
Kevin
kc6 is offline
post #8 of 9 (permalink) Old 04-30-2009, 01:42 AM Thread Starter
I got the damn thing finally... turns out the mount end of the bar is pretty useless like i was thinkin
and
as for the lubing the tire, I did
and i was gettin the bead in the valley as best I could, the bar is just useless... ill be getting/making my own nomar bar eventually. it doesnt help that the trailer tires are incredibly stiff both in the sidewall and the tread area
post #9 of 9 (permalink) Old 04-30-2009, 06:40 PM
CRF50 Squid
Years Riding: Veteran Poser
Using the bar to pry the tire on is a good way of sheering up the bead which could cause a slow leak. The trick as said before is to get the tire into the drop zone. Cut up some blocks of wood and place them between the rim and bead of the tire as you go. This will keep bead the tire in the drop zone. Do that and plenty of lube and the tire will slide on like butter.
I have used a manual tire changer all my life and have done everything from car tires to touring tires. It takes a bit of practice before you can get good at it. The stiffer the tire the more effort it takes.
Blah Blah Blah is offline
