Banjo Bolt - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 05-20-2009, 06:15 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Years Riding: 20 years
Banjo Bolt
Help!! I need to buy a 12mm banjo bolt locally. Anyone know who might have one?
slwglide is offline
post #2 of 9 (permalink) Old 05-20-2009, 06:36 PM
Addicted
eE jeremy's Avatar
I have a couple left over from my old brake lines, you're welcome to come pick through them, not sure what size they are.
Shitty Pass Racing #513
eE jeremy is offline
post #3 of 9 (permalink) Old 05-20-2009, 07:12 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Thanks jeremy. But brakes use 10mm banjo bolts.
slwglide is offline
post #4 of 9 (permalink) Old 05-23-2009, 09:32 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Well it looks like i need a thread insert too, I was able to fix the bolt but it started leaking again tonight, so i think i can get one from grainger.
slwglide is offline
post #5 of 9 (permalink) Old 05-23-2009, 09:36 PM
Bop your way home...
Dr. D's Avatar
Sportbike: Hypermotard
Years Riding: since 99'
Since it's a brake system I would just get a new master or caliper. Threaded inserts and cheap fixed just sounds like bad idea when it comes to brakes.
-Alan-
Balancing the Paradox
of Art and Profit
Dr. D is offline
post #6 of 9 (permalink) Old 05-24-2009, 10:43 AM
singram's Avatar
Sportbike: CBR F4i, Kawi ZX6E
If its for you ZRX Call Keith in parts dept @888-829-2166. If he doesn't have it in stock, he can usually get it 1-2 days. Very cool guy, I've ordered lots of misc hardware from him in the past(speedo cable, head cover bolts, etc) and just went and it it up. Cant remember the name of the dealer, but their out of South Elgin.
singram is offline
post #7 of 9 (permalink) Old 05-24-2009, 06:52 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Its not a brake system leak. Its an oil line in the case. It comes out the bottom and returns in the side of the case. The bolt i found in the motor was very retarded, I can't believe someone would do this to a bike. I will try to post a pic.
slwglide is offline
post #8 of 9 (permalink) Old 05-24-2009, 06:54 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Its hard to see but the bolt was flatened on four sides, and its longer than the correct bolt. i was able to grind my tap down to a bottoming tap and get 10mm more thread. So i made an even longer bolt and was able to torque it.
slwglide is offline
post #9 of 9 (permalink) Old 05-24-2009, 06:56 PM Thread Starter
slwglide's Avatar
Sportbike: ZRX 1100
Cool thanks I will keep him in mind for future parts.
slwglide is offline
