Computer geek questions again - networking... - Chicagoland Sportbikes
post #1 of 23 (permalink) Old 08-05-2003, 11:42 AM Thread Starter
Grand Master Crash
OmniGLH's Avatar
Sportbike: none for now
First off, thanks to those of you who helped with the DOS/AutoCAD problem. Got a copy of DOS, got my AutoCAD installed, everything works
Now on to my next project. A coworker and I are gonna start up a small internet radio station, running on a ShoutCast server (http://www.shoutcast.com). We get a day or two a week where we're allowed to work from home - and EVERYONE in the office listens to net radio during the day. Why not have a little fun and provide a service to those stuck in the office?
My computer setup at home is as such: I have a Linux (RH8) box running as a firewall/router, and 2 XP machines behind it. Problem is, Shoutcast will NOT accept connections from machines running behind a firewall. If you try to connect from behind one, you get an error like this:
<08/30/[email protected]:14:34> [yp_add] yp.shoutcast.com gave error (nak)
<08/30/[email protected]:14:34> [yp_add] yp.shoutcast.com gave extended error (Cannot see your station/computer (IP: 62.252.0.4:8000) from the Internet, disable NAT/firewall/ISP cache (Connection refused))
I really don't want to move one of the boxes outside of the firewall (tho I did it last night to make sure everything else worked, and it did.) I tried running the Linux version of the SC server, and it STILL didn't work - not until I shut down the iptables process. But once I do that, all my other PCs lose net access - no good.
I really want to mask my PCs behind a firewall - how can I make it look like they're not behind a firewall, when they really are?
I've read a bit about "port forwarding" in the SC forum. What is "port forwarding"? Is this what I think it is - when an outside source tries to connect to port 8000 of my router, the router passes the port request on to a specified PC inside the network, and make it look like it's coming directly from the router?
I'm kinda shaky on my networking abilities, but learning. I managed to get my Linux box working as a firewall/router on my own, so I'm thinking it can't be THAT hard to get this to work.
Thanks Sorry about the long-windedness.
Jim Ptak
-bikeless-
OmniGLH is offline
post #2 of 23 (permalink) Old 08-05-2003, 11:52 AM
you either need to open the ports on your firewall (try firestarter if your using shorewall - or you can use webmin for shorewall and just about everything else) - or you can use an IP masq, set up zones and permissions for your shoutcast server box (lets you be very specific about rules). Prolly can w/just shorewall too....
http://www.siliconvalleyccie.com/lin...work-linux.htm
http://www.shorewall.net/shorewall_quickstart_guide.htm
phozed is offline
post #3 of 23 (permalink) Old 08-05-2003, 12:42 PM
K.I.S.S
MikeD's Avatar
my bet is your useing xp's default firewalling so just open the incomming and outgoing port #'s and you will be set.
i set up a shoutcast server a while back and thats what i had to do too.
MikeD is offline
post #4 of 23 (permalink) Old 08-05-2003, 12:49 PM Thread Starter
Grand Master Crash
OmniGLH's Avatar
Thanks for the suggestion, but I'm fairly confident it's something to do with my Linux firewall/router. I have the firewalls disabled on both XP boxes. I know they are not the issue - I moved the broadcasting XP box out from behind the firewall, and it worked fine. I think I need to forward the ports on or something.
Phozed - thanks for the links, checking them out now.
Jim Ptak
-bikeless-
OmniGLH is offline
post #5 of 23 (permalink) Old 08-05-2003, 12:50 PM
port forwarding is like a statid ip for ports... You have your external address at the firewall and 10.* or 192.168.* internal... You "forward" port XXXX to a specific inward address. Example...
You want port 8000 forwarded to the shoutcast box which is running on 10.1.1.23. Now when you connect to shoutcast it will look like the external box is connecting because you have a pipe that's pretending to come from the external address but is really going to 10.1.1.23.
How to actually DO that in ick-nix I don't know tho.
Kanati
Kanati is offline
post #6 of 23 (permalink) Old 08-05-2003, 12:52 PM Thread Starter
Grand Master Crash
OmniGLH's Avatar
Kanati
Ok, that's what I was thinking port forwarding is. I need to figure out how to do it.
Jim Ptak
-bikeless-
OmniGLH is offline
post #7 of 23 (permalink) Old 08-05-2003, 12:59 PM
port forwarding is the key, amigo! too bad i know jack shit about linux firewalls.
post #8 of 23 (permalink) Old 08-05-2003, 01:37 PM
If you want to run a web server in-house behind firewall, instruct Seawall to "port forward" as follows:
login as root, 3-package settings, 5-Seawall, 3-servers, add one line tcp 80 0.0.0.0/0 192.168.10.4
make sure there is a blank line before the << EOF >> marker
Ctrl-S and Enter to save. Ctrl-C and (q) twice, (B) for backup, choose Seawall.
Go back to the # prompt and type (there is no need to reboot the LRP)
# seawall restart
Let me know if this helped.
R6bbie is offline
post #9 of 23 (permalink) Old 08-05-2003, 03:22 PM
CRAZe Inc's Avatar
Sportbike: Big Wheel
Years Riding: Since 3
rob, i didn't know you were a computer nerd too. cool.
CRAZe Inc is offline
post #10 of 23 (permalink) Old 08-05-2003, 03:23 PM
he is a nerd of all trades.
post #11 of 23 (permalink) Old 08-05-2003, 03:41 PM
Human lawn dart
rdrash's Avatar
How you found us: I know all
get a cisco firewall and make life easy
MotoGP 200 mph no roll cage
NESBA # 599
rdrash is offline
post #12 of 23 (permalink) Old 08-05-2003, 04:01 PM
Master of none.....
R6bbie is offline
post #13 of 23 (permalink) Old 08-06-2003, 12:09 AM Thread Starter
Grand Master Crash
OmniGLH's Avatar
Ok.. port forwarding was it. I can now broadcast from behind my firewall. Thanks for all the help guys :-D
But I'm not done. Here's something I'm a little more clueless on. How would I set things up, such that my Linux box sees my MP3 folder on my XP box, as if it were local?
Jim Ptak
-bikeless-
OmniGLH is offline
post #14 of 23 (permalink) Old 08-06-2003, 12:54 AM
CRAZe Inc's Avatar
Check out Samba, I haven't done any of this Linux stuff in 5 years, but Samba is what you want unless they've made it easier.
post #15 of 23 (permalink) Old 08-06-2003, 02:19 AM
That one will cost you 13 pudding pops!
R6bbie is offline
post #16 of 23 (permalink) Old 08-06-2003, 08:12 AM
BusaDave's Avatar
Years Riding: Lost Track
How you found us: Tony
Samba goes the other direction. It provides DOS-style mounts on Unix file systems.
Dave
BusaDave is offline
post #17 of 23 (permalink) Old 08-06-2003, 08:45 AM
if your mp3s are on a fat32 or fat filesystem just mount the drive.
I think the new kernel/redhat even reads NTFS but don't quote me.
phozed is offline
post #18 of 23 (permalink) Old 08-06-2003, 09:02 AM
OMG
NoStunner is offline
post #19 of 23 (permalink) Old 08-06-2003, 09:03 AM
J/K
me too
post #20 of 23 (permalink) Old 08-06-2003, 09:12 AM
Head Stepper
Pirate's Avatar
Sportbike: TREKK
Years Riding: 9
Oh yea... Omni, thanks for the IP of the shoutcast server! I'll be tuning in!
<-------- Jeff
Pirate is offline
post #21 of 23 (permalink) Old 08-06-2003, 09:26 AM
BusaDave's Avatar
Yes, but not over the network. Wasn't that the original question?
Dave
BusaDave is offline
post #22 of 23 (permalink) Old 08-06-2003, 09:35 AM
whoops yes it was. But I was still correct - you do need to mount the drive. I use a GUI tool called LinNeighborhood
http://www.mozillaquest.com/Linux02/..._Story-01.html
phozed is offline
post #23 of 23 (permalink) Old 08-06-2003, 10:25 AM
SAMBA includes the smb (windows file share) client which will allow a *nix system to mount windows file shares.
Type smbmount from a command shell, and it will give you the syntax for the mount command that you will need.
It will look something like this
mount -t smbfs -o user=username,host=ipaddress,pass=password
obijuan is offline
