Where can I get one of these locally? - Chicagoland Sportbikes
post #1 of 29 (permalink) Old 10-13-2009, 03:47 PM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Sportbike: 2014 Honda Grom
How you found us: Co-Worker
Send a message via AIM to Myles
VGA - HDMI Adapter
-Myles-
2014 Honda Grom
2000 Suzuki SV650 *SOLD*
1991 Mitsubishi Galant VR4 1929/2000 *SOLD*
Myles is offline
post #2 of 29 (permalink) Old 10-13-2009, 03:52 PM
for a decent price? probably no where. are there other options? what are you trying to do?
post #3 of 29 (permalink) Old 10-13-2009, 03:59 PM
tigerdirect should have then in stock at the naperville site
post #4 of 29 (permalink) Old 10-13-2009, 04:11 PM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
I'm trying to hook my laptop up to my HDTV(Samsung 40" 1080). I'm not sure if it has a VGA in but it wouldn't matter anyway cause I don't think it will transmit sound. I don't have an impressive audio setup so I'm not too concerned with that.
-Myles-
2014 Honda Grom
Myles is offline
post #5 of 29 (permalink) Old 10-13-2009, 04:26 PM
Abt.
post #6 of 29 (permalink) Old 10-13-2009, 04:28 PM
check if it has VGA. The proposted vga->hdmi converter wont do sound either unless you feed it sound. So instead of buying a converter you have to feed vga and audio to, just feed the TV vga and audio.
post #7 of 29 (permalink) Old 10-13-2009, 04:32 PM
I would think best buy would have something... at a total rip off price.
chach is offline
post #8 of 29 (permalink) Old 10-13-2009, 04:38 PM
Radio shack probably won't be too much of a ripoff, if they have it
post #9 of 29 (permalink) Old 10-13-2009, 04:39 PM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Right, I think the TV may only have VGA in and audio out, for a home theater setup. The adapter looks like it would work fine as long as I go from the laptop to the box with a VGA and 1/8" audio to RCA from the computer to the box. Then HDMI from the box to the TV.
-Myles-
2014 Honda Grom
Myles is offline
post #10 of 29 (permalink) Old 10-14-2009, 08:50 AM
See what your TV has for input before you spend money you dont need to, just my 2 cents.
post #11 of 29 (permalink) Old 10-14-2009, 08:52 AM
If your tv has a dvi input, VGA to dvi is a much cheaper alternative for the same result
post #12 of 29 (permalink) Old 10-14-2009, 09:01 AM
micro center
post #13 of 29 (permalink) Old 10-14-2009, 09:05 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
So I checked out my TV last night and it did have a VGA in with an audio jack. It worked very nicely except that I think my computer couldn't handle the resolution when trying to play 1080 rips. Or could it be the VGA cable? Would having the HDMI adapter play the media through the TV better?
-Myles-
2014 Honda Grom
Myles is offline
post #14 of 29 (permalink) Old 10-14-2009, 09:08 AM
using hdmi won't make a difference. will the computer play your "1080" rips ok on its own display? What screen resolution are you running?
post #15 of 29 (permalink) Old 10-14-2009, 09:09 AM
hdmi would be better
VGA sucks
even dvi if you can
post #16 of 29 (permalink) Old 10-14-2009, 09:10 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Yes the computer will play the hi res stuff on it's own. I think the resolution was 1080x1900
-Myles-
2014 Honda Grom
Myles is offline
post #17 of 29 (permalink) Old 10-14-2009, 09:12 AM
Your tv is 1080p? That means it's native resolution is 1920x1080, try running that.
post #18 of 29 (permalink) Old 10-14-2009, 09:12 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Yes, TV is a Samsung 40" 1080p
Sounds good, I'll check it out when I get home. Thanks!
-Myles-
2014 Honda Grom
Myles is offline
post #19 of 29 (permalink) Old 10-14-2009, 09:13 AM
You have to match the computer out to the tv resolution. 19xx by 1080
edit - you guys are fast
post #20 of 29 (permalink) Old 10-14-2009, 09:15 AM
What is the source? Is this a desktop or a laptop? If it's a laptop what is the screen resolution? Chances are if its a laptop it's not running a true 1080p(1920x1080) resolution on the built in display, which is why it would be able to play stutter free on it's panel but when output at full 1080p it jutters. Without hardware acceleration you need a lot of horsepower to reproduce 1080p using software.
You could try setting the output resolution lower, like maybe 1280x720 to see if that creates a smooth image.
post #21 of 29 (permalink) Old 10-14-2009, 09:18 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
It is a laptop. Definitely makes sense.
-Myles-
2014 Honda Grom
Myles is offline
post #22 of 29 (permalink) Old 10-14-2009, 09:19 AM
Chances are that laptop doesnt have the horsepower to reproduce a full 1080p image. Run it at 720p and see how it looks. Laptops for HTPC are rarely used for this reason.
post #23 of 29 (permalink) Old 10-14-2009, 09:23 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Fosho. I probably should have shut my mouth in my previous media PC thread, listened to you and MMRacing and bought myself a Popcorn Hour.
-Myles-
2014 Honda Grom
Myles is offline
post #24 of 29 (permalink) Old 10-14-2009, 09:27 AM
Wait, did you just buy this laptop for home theater duties?
post #25 of 29 (permalink) Old 10-14-2009, 09:33 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
No definitely not. I'm just trying to avoid shelling out the money right now to build something.
-Myles-
2014 Honda Grom
Myles is offline
post #26 of 29 (permalink) Old 10-14-2009, 09:38 AM
Yes, don't build anything till you've played with this enough to know some of the fundamentals. Otherwise you're just spinning your wheels, and wasting money.
post #27 of 29 (permalink) Old 10-14-2009, 09:39 AM
MM Racing's Avatar
Sportbike: Squat
How you found us: Your Mother
I love being right, any fool could tell you a laptop for sure is not the right way to do a HTPC.
Ian
MM Racing is offline
post #28 of 29 (permalink) Old 10-14-2009, 09:49 AM Thread Starter
Feed Me a Stray Cat
Myles's Avatar
Yeah, I'll see what laptop can end up pushing without getting shitty.
Hey, at least I can admit when I'm wrong right?
-Myles-
2014 Honda Grom
Myles is offline
post #29 of 29 (permalink) Old 10-14-2009, 09:57 AM
MM Racing's Avatar
Sportbike: Squat
Yeah.
Ian
