Garage door - motor issues? - Chicagoland Sportbikes
Home Improvement forum This forum is for the discussion of all things involving home projects, especially kick ass garage remodels.
post #1 of 28 (permalink) Old 03-29-2013, 11:44 AM Thread Starter
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
I have a 2 year old Chamberlain garage door opener that I believe crapped out.
When pressing the open/close button, the machine moves the door only by couple of feet in either direction.
In manual mode, the door opens and closes fine, so the door alignment is not the issue.
I've tried adjusting the door level on the back of the machine, but that didn't do much.
If the motor crapped out, is replacing it a relatively easy DIY project, or is a professional required?
Thx
Gone In 3 is offline
post #2 of 28 (permalink) Old 03-29-2013, 12:01 PM
probably the sensors at the bottom of the door not lined up right
post #3 of 28 (permalink) Old 03-29-2013, 12:06 PM Thread Starter
Gone In 3's Avatar
That was my first suspicion. Had a guy come check that. They were aligned correctly.
post #4 of 28 (permalink) Old 03-29-2013, 12:16 PM
Greg
gsd656's Avatar
If you haven't done so, reset the thing and reprogram. It worked for me. Good luck.
Greg
gsd656 is offline
post #5 of 28 (permalink) Old 03-29-2013, 12:52 PM Thread Starter
Gone In 3's Avatar
I'll try that. In case if that doesn't work. How difficult would it be to replace the motor...
post #6 of 28 (permalink) Old 03-29-2013, 01:10 PM
El Burrito Volador
spyder84's Avatar
Years Riding: I'm a rookie.
If the sensors are aligned the opener may need readjustment. There should be two adjustment screws on the box. One for up other for down. But unless you know what you're doing you could make it worse. My brother and father are garage door installers so I'm only spitting out what I think the issue may be based on the work talk I tend overhear.
Erik
05 GSXR600
spyder84 is offline
post #7 of 28 (permalink) Old 03-29-2013, 01:14 PM
Pringles can user
tnat's Avatar
Sportbike: 2005 YZ250
Years Riding: 1977
How you found us: Geo
I can come by and fix it, if your working just have your G/f let me in. I can show her whats wrong with you - i mean- the garage door!
CLICK THE LINK!
http://www.club57mx.com/
Doug Stanhope
tnat is offline
post #8 of 28 (permalink) Old 03-29-2013, 01:26 PM Thread Starter
Gone In 3's Avatar
I'll leave the backdoor open for ya.
post #9 of 28 (permalink) Old 03-29-2013, 07:33 PM
pricelister's Avatar
Sportbike: Without
Years Riding: 2004
How you found us: Blackhawk Farms website
I replaced the guts of a Chamberlain opener several years ago. I don't remember it being difficult.
It didn't solve the problem. Chamberlin did send a completely new opener at no charge. This was long after the warranty expired.
pricelister is offline
post #10 of 28 (permalink) Old 03-29-2013, 08:19 PM Thread Starter
Gone In 3's Avatar
Thanks. I'll try to take the new opener route before replacing the motor.
post #11 of 28 (permalink) Old 03-30-2013, 09:44 PM
When you take the cover off the opener do you see a lot of shaved plastic? If so you only need a $30 gear replacement. Easy to do.
post #12 of 28 (permalink) Old 03-31-2013, 01:39 AM
Sportbike: CBR1100XX & CBR1000F
Years Riding: I can't remember that far back.
The motor is easy to get in and out but the actual motors don't go bad that often. I'm thinking the same as Drama. Take the cover off and see if there are shavings around the gears. If the gears are worn they are about $30.00. You can order the parts on line from any number of places. Pretty easy to get the gears off and new ones on by yourself.
Strek is offline
post #13 of 28 (permalink) Old 03-31-2013, 04:21 AM
ThirdgenTa's Avatar
Sportbike: 2001 zx6
How you found us: Search
Your RPM sensor is more than likely the culprit. On some of the chamberlains they have a diagnostic code that you can read by counting the times the lights flash on the opener. If it flashes 5 times it is the rpm sensor code.
Open up the cover and check to make sure that the sensor is plugged in. If it is, order a new rpm sensor. They are pretty cheap, like $15.
I know for sure it's not your photo eyes, motor or gear so don't even bother with that.
ThirdgenTa is offline
post #14 of 28 (permalink) Old 03-31-2013, 11:28 AM Thread Starter
Gone In 3's Avatar
There are no flahes of light. The chain only moves back and forth by 3 feet.
Will have to look for shaved plastics.
post #15 of 28 (permalink) Old 04-01-2013, 12:13 AM
If your gears are shot it may move but not open. Do you have a chain drive or screw drive system?
Strek is offline
post #16 of 28 (permalink) Old 04-01-2013, 12:46 AM Thread Starter
Gone In 3's Avatar
Chain
post #17 of 28 (permalink) Old 04-01-2013, 06:55 AM
This guy used to (still does?) install and repair garage door openers. He probably knows what he's talking about.
It can't hurt to check for torn gears, but I don't believe they have enough teeth to move 3' and stop. At least it's easy to remove that as a possibility, and easy to replace if it's the problem (I fixed my parents gears when I was 14).
post #18 of 28 (permalink) Old 04-01-2013, 05:46 PM
If the gears (worm gear and drive gear) are stripped it may move the door until it hits the dead (worn) spot on the gears. This is exactly the symptom that my door opener had when the gears were worn. These gears are made of some sort of white plastic or hard nylon type material. When they wear they leave behind shavings from the wear. The gears wearing out is one of the most common failure items with garage door openers according to Chamberlain. I have some PDF's of the instructions and parts if it is the gears. I tried to attach them here but they are too large and would not attach. If you want to PM me your email address I'd be happy to send you the PDF's. They have some nice pics/diagrams of the parts in question.
You mentioned it was a chain drive system. Another possible failure item on the chain drive (although not anywhere near as common) is up on top where the drive gear axle exits the opener housing on top of the unit. The chain attaches to the opening sprocket at this point. There is a possibility that the bushing that keeps the axle straight and aligned on the top of the opener housing box has worn out and the axle and opening sprocket may not be aligned. You should be able to see this by taking off the sprocket cover cap retainer. It is normally a small black plastic cover cap the covers the chain and opening sprocket on the top of the garage door opener. The cover just snaps into place with a retainer clip type of system. Just squeeze it a bit and you should be able to lift the cap cover off. Remove that cap cover and hit the opener button. If that top bushing is bad the opening sprocket and axle will be wobbling as it starts spinning as the axle will no longer be held firmly in place. Either way if the gears are worn it is better to order the entire drive gear assembly instead of just the worm and drive gears. It is about $2-3 more in cost for the entire assembly. As an assembly it is much easier to replace IMO as you don't have to waste time removing the old drive gear from the axle assembly. Once you see the PDF's it should all make a lot more sense.
Strek is offline
post #19 of 28 (permalink) Old 04-03-2013, 10:37 PM
Gears were gone on my dad's opener last summer.
$50 kit and about an hour of time just chit chating in the garage.
take the cover off, if it's the gears you'll know right away!!
post #20 of 28 (permalink) Old 04-04-2013, 12:45 PM
I had the same issues you described Gone, and it was the same problem Ponch had. You can fix for $20-$30. I went with the more expensive $30 kit with the assembly which makes the repair very easy.
http://www.amazon.com/Chamberlain-Ga.../dp/B000V0KYQY
http://www.northshorecommercialdoor....eandspas1.html
post #21 of 28 (permalink) Old 04-04-2013, 12:58 PM Thread Starter
Gone In 3's Avatar
Thanks guys! I'll check out the gears and report back.
post #22 of 28 (permalink) Old 04-04-2013, 09:58 PM
I agree with Drama. If its the gears get the assembly. It will save you time in doing the repair and is worth the extra buck or two.
Strek is offline
post #23 of 28 (permalink) Old 04-05-2013, 03:52 AM
benneewilles's Avatar
Sportbike: CBR
How you found us: google search
Suggestion!!!
Your post seems like you are really in a trouble with the garage door!!
Isn't it?? So why don't you replace it?? As you said its a 2 years old, then if it is possible try to replace it with a new and suitable garage door!!
Considering me few years back when i was also facing the same problems but then i replaced with a more suitable and with good quality garage door and believe me it approx 3-4 years I didn't got any kind of problem!!
benneewilles is offline
post #24 of 28 (permalink) Old 04-05-2013, 09:41 AM
Sportbike: 05 SV
Years Riding: ...
How you found us: ...
I"m guessing spam?
2 years old is nothing on a door/opener. Manually the door works fine, so I doubt its the door
When I replaced the gear assembly on my parents opener, I remember it being from 1997? or something, and its still working fine to this day
Partially stripped gears is my guess
pothiawala786 is offline
post #25 of 28 (permalink) Old 04-05-2013, 09:59 AM
ThirdgenTa's Avatar
Sportbike: 2001 zx6
Yes.
OP: Does the opener make a grinding noise when you hit the button? There should be no reason for the gears to go bad unless your door is not balanced and it is putting stress on them. For those of you who replace them and don't balance your door, you are just going to have to replace them again in a few more years.
Based on what you described, like I said, it would be the rpm sensor.
post #26 of 28 (permalink) Old 04-06-2013, 03:08 AM
Yes.
Since you install and repair these things I'm sure you have way more experience than the average homeowner who normally only has to worry about their own opener. In my own experience I have fixed about 5 garage door openers. One of my own and about 4-5 others for friends and neighbors. In all instances the gears were bad. I've never had to go back and do it again so far. From the description of the problem provided so far I'm leaning towards the gears at this point.
Gone in 3. It takes about 2-3 minutes to get the cover housing off of the opener. On my opener if I recall correctly it has 8 screws that hold the cover on. Take the cover off and have a look.
Strek is offline
post #27 of 28 (permalink) Old 04-06-2013, 10:52 AM
Yes.
I checked the balance on my garage door when I did the replacement and it was fine.
post #28 of 28 (permalink) Old 08-25-2019, 06:14 PM
Hmm dragging up 6yr old posts. Generally means one thing.
