Excel Gurus Come Hither! - Chicagoland Sportbikes
post #1 of 17 (permalink) Old 08-26-2010, 05:08 PM Thread Starter
d0 work s0n!
paintedblue's Avatar
Sportbike: '06 GSX-R
Any excel gurus out there? I need some help. I have a massive excel sheet for a job we are working on and the problem is some of the cells in each row has multiple numbers in it, room numbers to be exact. I have tried the "text to columns" button but it just moves everything to a new column. I need the data to move down (new row) and also, if possible, retain the rest of the data in the string. so for instance, i have a string as follows:
ITEM, DRAW, DEPT, RM NAME, RM #
If the data then reads:
ITEM/ DRAW/ DEPT/ RM NAME/ 12420, 12421, 12422, 12423
If the RM # column has more then one number, then I need a new row to start with the same data to the left of the RM # column, however with only one number (RM #). So if there are 12 RM #'s I need the data repeated per room. For example,
I need the data to then read:
ITEM/ DRAW/ DEPT/ RM NAME/ 12421
ITEM/ DRAW/ DEPT/ RM NAME/ 12422
ITEM/ DRAW/ DEPT/ RM NAME/ 12423
I hope that makes sense. I'm leaving work now but will try and check back later. If not, tomorrow.
Thanks for your help ahead of time.
#910
paintedblue is offline
post #2 of 17 (permalink) Old 08-26-2010, 05:29 PM
Aussie Grover's Avatar
Sportbike: bikeless!!!
Are the room numbers seperated by a comma, tab, space etc? If so, you could do an import data and specify the delimiter to see how that works out for you.
Glenn
Aussie Grover is offline
post #3 of 17 (permalink) Old 08-26-2010, 05:35 PM
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
If what centipede said above doesn't work, then upload the file along with nudies of wife/girlfriend for better results.
Gone In 3 is offline
post #4 of 17 (permalink) Old 08-27-2010, 05:49 AM
Ron
Workin' up to the track
Sportbike: In between bikes right now
Years Riding: 15
How you found us: don't remember
database guy by day...and there are a number of ways to do this, especially if the numbers are consistent in length. if that is the case use the excel LEFT or RIGHT formula to parse what you want from the string.
If it is more complicated than that drop an email to [email protected] with the file and some specifics and I can take a detailed look
We cannot defend freedom abroad by deserting it at home.
We must not confuse dissent with disloyalty. When the loyal opposition dies, I think the soul of America dies with it.
- Edward R. Murrow
Ron is offline
post #5 of 17 (permalink) Old 08-27-2010, 06:38 AM
Post a two lines of data, so people can give you an exact answer.
1 line with 1 room #, and another line with multiple room numbers...
ALso, do you have the raw data (text file, csv, etc) or just the excel sheet you currently have?
post #6 of 17 (permalink) Old 08-27-2010, 07:08 AM
Is this for scheduling the Craigslist adult services ad you have running?
post #7 of 17 (permalink) Old 08-27-2010, 07:20 AM
defiant's Avatar
Sportbike: Not worth stealing, really.
Years Riding: 6 years
How you found us: NA
You can use a vba or simple vbscript to do what you want. A nested loop can do it. If you need help let me know, if you want me to write it I expect some enumeration, a 1.75L bottle of Jack Daniels will do. Not just the bottle! The JD has to be in it and still sealed! Some cheap ass jokers out there.
defiant is offline
post #8 of 17 (permalink) Old 08-27-2010, 01:26 PM Thread Starter
d0 work s0n!
Thanks for all of the responses and sorry for my delay. Alright lots of answers and most over my head. I've attached a screen shot of an example since I can't attach an excel doc.
As you can see the first line (Column G) has one room number and the second has a ton. I need the second line to be broken up with the exact same info but with each room separate. So rows 3 through whatever should have all the same info as the second row but only one room number (one row - 12421, next row 12422, etc). Btw, the solution must be able to be used on an entire doc too, not just this one example.
Basically, I need to make the document filterable. I need to be able to filter by room number so I can see what equipment goes where. However, with some of the rows having multiple rooms I can't do this.
#910
post #9 of 17 (permalink) Old 08-27-2010, 01:37 PM Thread Starter
d0 work s0n!
I reread my original post and I must have been in a hurry bc it didn't make all that much sense. I changed it and made some clarifications. Thanks!
#910
post #10 of 17 (permalink) Old 08-27-2010, 02:12 PM
I can do this with a quick shell script, but not Excel... if I had a text file with the raw data in it, this would be very simple to do.
post #11 of 17 (permalink) Old 08-27-2010, 02:17 PM Thread Starter
d0 work s0n!
thanks arch but unfortunately i can't give out the data.
#910
post #12 of 17 (permalink) Old 08-27-2010, 02:22 PM
I'll write you a script that will work on any unix box, mac or windows box (with cygwin) anyway... and if you can use it, knock yourself out...
Will post it in a bit...
post #13 of 17 (permalink) Old 08-27-2010, 02:24 PM
Arch you friggen hippy liberal, you know the script won't work on a treadmill
post #14 of 17 (permalink) Old 08-27-2010, 02:35 PM
defiant's Avatar
Let me know which way you go. Outside of an macro, vbscript is prob easiest way to go since it's an excel spreadsheet.
defiant is offline
post #15 of 17 (permalink) Old 08-27-2010, 02:38 PM
Sportbike: HD V-ROD/Honda CBR1000RR
Depending on the format of the data in the cell, you might need to write a parse function. Then do text to column, and lastly you can do a pivot table to produce a row for each value in that column.
2004 Silver Honda CBR1000RR
2003 H.D. V-ROD
roman is offline
post #16 of 17 (permalink) Old 08-27-2010, 02:56 PM
If you can export the data into the format listed in the first post, I have a script that will do it for you... (fields delimited by / rooms delimited by , )
save the data to a text file 'pipe' the file through it, it will change it...
in.in = original data text file...
$ cat in.in
ITEM/ DRAW/ DEPT/ RM NAME/ 12333
ITEM/ DRAW/ DEPT/ RM NAME/ 12333, 1234, 1235, 1236
# breakit.sh is the script. pipe it to the script, and catch it into another file.
$cat in.in | sh ./breakit.sh >out.out
#Let's see what it did.
$cat out.out
ITEM/ DRAW/ DEPT/ RM NAME/ 1234
ITEM/ DRAW/ DEPT/ RM NAME/ 1235
ITEM/ DRAW/ DEPT/ RM NAME/ 1236
# Re-Import your new data...
# get drink, be happy.. it's 2:55 on a friday.
PM me for script location... I have it on a website that you can grab and save.
post #17 of 17 (permalink) Old 08-27-2010, 03:33 PM Thread Starter
d0 work s0n!
$ cat in.in
$cat out.out
I see lots of pretty symbols but only understand the part about me drinking. I'm f'd.
#910
