Windows 7 Monitor resolution - Chicagoland Sportbikes
post #1 of 11 (permalink) Old 10-01-2010, 12:27 PM Thread Starter
So, my wife managed to do some weird shit and changed the resolution to one not supported by the monitor.
I tried booting in safe mode, and the default resolution there works and I can see the screen. I can change it, but the settings never carry over.
If I reboot in normal mode, the monitor doesn't work.
How can I change the resolution a) without seeing the screen, or b) within safe mode and have the setting "stick" when I reboot in normal mode?
post #2 of 11 (permalink) Old 10-01-2010, 12:32 PM
couldn't you just remove the video card from device manager in safe mode. then when booted into normal mode it will refind and install the correct device and set the resolution to a supported one.
post #3 of 11 (permalink) Old 10-01-2010, 12:38 PM Thread Starter
Thanks!
That should work. I'll keep that in mind next time she fucks it up.
I got it fixed using system restore.
post #4 of 11 (permalink) Old 10-01-2010, 12:40 PM
I'm surprised windows let her change it to an unsupported resolution. Typically those modes are hidden unless you specify otherwise. Even then after the change it asks you if you want to keep the changes and if you don't answer(which you wouldn't if you couldn't see the screen) it would revert. She must have hit the enter key.
post #5 of 11 (permalink) Old 10-01-2010, 12:42 PM Thread Starter
She did it hitting some function key combo trying to minimize a window, then when the screen went black, she rebooted before it could revert itself.
post #6 of 11 (permalink) Old 10-01-2010, 01:21 PM
stuck in 6th gear
Ernie's Avatar
defective wife, go turn her in for a refurb that's tuned properly
Ernie is offline
post #7 of 11 (permalink) Old 10-01-2010, 01:32 PM
pfft.
ill_ag's Avatar
couldn't you just remove the wife then boot into single mode
good suggestion
ill_ag is offline
post #8 of 11 (permalink) Old 10-01-2010, 01:33 PM
Sportbike: R6, SV1000s, rm250
post #9 of 11 (permalink) Old 10-02-2010, 09:31 AM
beac83's Avatar
Sportbike: A couple
If you have Premium or Ulitmate, you can use the Group Policy Editor to prevent screen resolution changes. Run gpedit.msc
________________
beac83 is offline
post #10 of 11 (permalink) Old 10-02-2010, 11:45 AM
The Kraken
Sportbike: 2007 Yamaha R6
Years Riding: 2.5
How you found us: I took the red pill.
Send a message via AIM to sandplasma
Dang it I was going to say ''Right click..Up arrow, Enter...tab..tab...tab..enter.." without looking
sandplasma is offline
post #11 of 11 (permalink) Old 10-02-2010, 11:48 AM
and that will have you adjusting sounds in windows7.
