Most Reliable Hard Drive - Chicagoland Sportbikes
post #1 of 24 (permalink) Old 10-09-2010, 03:40 PM Thread Starter
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
The drive in my Synology NAS just shit on me - I hadn't set it up in a raid yet, so I am transferring everything I can to a USB HDD for backup.
I had a Seagate Barracuda Model ST3750528AS SATA 3Gb/s 750GB 7,200 RPM
http://www.seagate.com/ww/v/index.js...D&locale=en-US
And the question is - what is the most reliable drive? Ideally I would like to raid (2) 1T drives for (1) redundant 1T server, with a back up to a 1T USB HDD. So what is the drive I should get next? I think my first step would be to look at 5400 RPM drives - since this is mostly for streaming music (mp3) or movies (mpeg / ISO) over the home network.
I assume the home network would be the limited factor not the drives, but give me whatever input you have.
Loki047 is offline
post #2 of 24 (permalink) Old 10-09-2010, 03:42 PM
I only use Western digital
and more specifically their black series. No touch heads and amazing fast speeds.
post #3 of 24 (permalink) Old 10-09-2010, 04:13 PM
Don't argue, you'll lose
Sportbike: NA
Years Riding: NA
How you found us: Na
WD Black or Raptop is awesome
I personally have always stuck with Seagate and have had great luck with them, I've had them take a shit then a few mths later work again (true story.) When I was with my old company we got the momentus as a demo hdd to test it out, was fantastic... until it heated up and started bsoding... but that was when the first started working on it... their Cheetah series is equivilant if not better (my opinion) than black or raptor from WD...
Kerosene is offline
post #4 of 24 (permalink) Old 10-09-2010, 04:44 PM
hdd are a crapshoot - just run raid 5 and be done with it
what was a good brand at one time was a shit brand another
ssd has less mechanical failure but the $/m is out of line and you probably are looking for nas stuff
disks are cheap enough to have a cold spare if it's for business.. that's what I have been doing
post #5 of 24 (permalink) Old 10-09-2010, 04:49 PM
yo quiero su taco
whiteSeatEnvy's Avatar
Any hard drive is a mechanical and electrical feat of extremely small proportions. The scale at which things are happening is almost uncomprehensible. If there was a reliable drive out there, raid and data backup would not exist, and computer manufacturers would guarantee your data. Backing up your data regularly is the only solution. Buy the cheapest fastest drive available and be done.
whiteSeatEnvy is offline
post #6 of 24 (permalink) Old 10-09-2010, 05:12 PM
Both these are correct.
Drives fail.... that's that.
Raid 'em or back them up.
post #7 of 24 (permalink) Old 10-09-2010, 05:32 PM Thread Starter
Loki047's Avatar
Sportbike: Z1000
Thanks for the input guys - Time to Raid. Is the WD Black series the same as the Caviar Black?
Since I can only have (2) drives on my setup im limited to RAID 1 which should be fine - since I can run one drive while the drive is repaired.
Second question (maybe this is dependent on my raid controller/software) I am going to get the 750Gig i have repaired by Seagate. Can I use raid 1 with a 750 gig and 1 or 2T drive? Obvious I will be limited to mirroring a max of 750 gigs.
Third question, if yes to above, can I swap out the 750Gig drive when I get the next 1 or 2T drive without formating the original 1 or 2T drive?
Fourth question, if I have less than 750 gigs stored on a RAID 1 of 1 or 2T can I swap out a single 1 or 2T drive for the 750G and keep on running?
Loki047 is offline
post #8 of 24 (permalink) Old 10-09-2010, 05:45 PM
Sportbike: NA
Years Riding: NA
Nvm
Kerosene is offline
post #9 of 24 (permalink) Old 10-09-2010, 07:16 PM
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
Originally Posted by loki047 View Post
the drive in my synology nas just shit on me - i hadn't set it up in a raid yet, so i am transferring everything i can to a usb hdd for backup.
I had a seagate barracuda model st3750528as sata 3gb/s 750gb 7,200 rpm
http://www.seagate.com/ww/v/index.js...d&locale=en-us
and the question is - what is the most reliable drive? Ideally i would like to raid (2) 1t drives for (1) redundant 1t server, with a back up to a 1t usb hdd. So what is the drive i should get next? I think my first step would be to look at 5400 rpm drives - since this is mostly for streaming music (mp3) or movies (mpeg / iso) over the home network.
ssd
Gone In 3 is offline
post #10 of 24 (permalink) Old 10-09-2010, 07:23 PM
yo quiero su taco
There should be RAID software out there that will let you do all of that. Not sure about the Black and Caviar. Side note, the only other issue is your OS/file system. Use NTFS to see all 2T.
post #11 of 24 (permalink) Old 10-09-2010, 10:09 PM
Originally Posted by Gone in 3 View Post
ssd
you, solid state drive. No moving parts, no worries. But huge $, and the storage capacities aren't quite there yet...
post #12 of 24 (permalink) Old 10-09-2010, 10:12 PM
As someone else has said, hard drives are a crapshoot. I run several machines in my basement 24/7. My home file server has 6 Seagate harddrives in RAID. I've run Seagate, western digital, even Maxtors for years with great success.
These days, I'd only buy WD or Seagate. They've proven themselves time and time again. That being said, there's no such thing as a 100% reliable hard drive... always assume a hard drive could take a shit on you at any time.
post #13 of 24 (permalink) Old 10-09-2010, 10:15 PM
Sportbike: 08 gsx six fiddy F
How you found us: forum link
Buy the cheapest one and make sure you back up your date every once in a while. There is no full proof drive, if there was then there wouldnt be so many brands of drives to choose from and you wouldnt be asking this question. I personally stick with seagate or wd.
2008 Suzuki gsx 650f.
Thomas Jefferson
michowski is offline
post #14 of 24 (permalink) Old 10-10-2010, 02:49 AM
Gone In 3's Avatar
His question was "And the question is - what is the most reliable drive?"
Didn't know money was a factor.
post #15 of 24 (permalink) Old 10-10-2010, 08:24 AM Thread Starter
Loki047's Avatar
Sportbike: Z1000
Re: Most Reliable Hard Drive
you, solid state drive. No moving parts, no worries. But huge $, and the storage...
It's not except I don't trust ssd right now - too new. Also not nearly as large as I would like.
Jordan
Loki047 is offline
post #16 of 24 (permalink) Old 10-10-2010, 08:49 AM
-= OuterSpace =-
OldSkoolMC's Avatar
Sportbike: Yamaha YZ450
How you found us: Shizzle
If you are looking for the most reliable HDs look at the WD VelociRaptor, Seagate Cheetah, or Hitachi UltraStar drives.
Don't listen to these guys about buying cheapo drives. Yes, all HDs can fail everyone in IT should know that but the drives listed above ARE some of the most reliable/best drives on the market. I'm pretty sure they all carry a 5 year warranty... I know the WD does for sure. I personally never cheap out on hard drives having years and years of service from my drives is important for me personally.. even in my home PC stuff. If you don't want performance and don't care about replacing drives everytime a cheapo fails then go for it.
06 Kawasaki BruteForce 750i
09 Yamaha Raptor 700r
- Mike - OldSkool - MC -
OldSkoolMC is offline
post #17 of 24 (permalink) Old 10-10-2010, 08:57 AM Thread Starter
Loki047's Avatar
Sportbike: Z1000
Holy shit the ultrastars are 15,000 RPM?
VelociRaptor is 10,000 RPM with a max of 600 gig?
I think I would be paying for performance I would never need.
Loki047 is offline
post #18 of 24 (permalink) Old 10-10-2010, 09:03 AM
-= OuterSpace =-
OldSkoolMC's Avatar
yeah, like I said, it all depends on your needs. Even in a NAS, I would put higher end drive in there for longevity reasons but that's just me.
Here is an old article from 2007 about enterprise class drives and performance.
http://www.tomshardware.com/reviews/...s,1575-23.html
post #19 of 24 (permalink) Old 10-10-2010, 10:18 AM Thread Starter
Loki047's Avatar
Sportbike: Z1000
Thanks for the input fellas. Going RAID 1 with (2) of these WD Black
http://www.compusa.com/applications/...oductresources
Loki047 is offline
post #20 of 24 (permalink) Old 10-10-2010, 10:22 AM
Sportbike: NA
Years Riding: NA
I'm not sure if you're aware of this, when 1tb-2tb hdd's came out there was a huge issue of them failing almost immediately, this was due to size being to advanced for an old drive... seagate and hitachi stuck with a STABLE GB size and did not exceed on their enterprise HDD's because it works and it costs them less $ longterm even if they have to replace a hdd after 3 years.
Like I said, Cheetah imo is better than black or raptor, Hitachi's Ultrastars are expensive but they've been around for a VERY long time and I've never had a problem with their drives...
I put high end drives in NAS devices too, if I buy a buffalo for a client I always take a look at the drives in it, no maxtors or WD's, I pull those out and buy new ones to replace them... I just don't have trust built up with those two companies (ESPECIALLY MAXTOR.)
Kerosene is offline
post #21 of 24 (permalink) Old 10-10-2010, 10:39 AM
I've been bitten by all brands except Hitachi.
post #22 of 24 (permalink) Old 10-10-2010, 11:00 AM
kingtony911's Avatar
Sportbike: GSX650F
Western Digital all the way! There RMA on dead drives is also amazing!!!
kingtony911 is offline
post #23 of 24 (permalink) Old 10-10-2010, 12:58 PM
I will NEVER touch a Hitachi, who used to be IBM's hard drive division. Got burned hard by them. IBM was at the top of their game 10 years ago, then released the infamous "Deathstars" which burned me hard.
http://en.wikipedia.org/wiki/Hitachi_Deskstar
Never again... they lost my trust.
post #24 of 24 (permalink) Old 10-10-2010, 04:52 PM
There are certain models to avoid from just about each manufacturer, that was certainly one of theirs to side step at the time. I was running WDs in that era and was getting bit hard. Prior to that, Maxtor... bit as well as seagates both before and after that... bit. If it's important, have backups and/or redundancy. Shit happens and eventually it will.
