Major Laptop Issues - Chicagoland Sportbikes
post #1 of 28 (permalink) Old 03-24-2011, 04:08 PM Thread Starter
Major Laptop Issues
Well, I'm not sure if that's it for this laptop of ours or what, but this thing just keeps on completely freezing. I mean 100% other than being able to move the cursor around. Can't minimize windows, close things or even pull up the task manager with ctl-alt-delete.
Thoughts? I know it's not something easily diagnosable over the internet...we're already thinking about getting something new.
It's a Dell somethin' or other, just 3 years old. What do you recommend for cheap new laptops?
post #2 of 28 (permalink) Old 03-24-2011, 04:11 PM
I would reimage it before I decided the hardware was the problem. Most likely the OS or some application on it is the problem.
Can you do a system restore back to a date where you weren't having this problem? Or is the system completely unusable even in safe mode?
post #3 of 28 (permalink) Old 03-24-2011, 04:12 PM Thread Starter
Dunno yet, I'm not home. Vicki just said she ran a clean/reboot and it detected an error, said there was something stopping it from rebooting...it ran a bunch of self scans...worked for 5 mins and froze again.
I'll call in a sec
post #4 of 28 (permalink) Old 03-24-2011, 04:14 PM
have you blown the dust out of it?
post #5 of 28 (permalink) Old 03-24-2011, 04:17 PM
Sounds like an overheating issue.
Clean the thing out? Did an internal cooling fan die? Are the vents chock full of dust?
post #6 of 28 (permalink) Old 03-24-2011, 04:20 PM
yo quiero su taco
whiteSeatEnvy's Avatar
Before you do anything to try to fix it. Press F12 during startup until you get to the boot menu. Select Dell Diagostics and run it.
whiteSeatEnvy is offline
post #7 of 28 (permalink) Old 03-24-2011, 04:22 PM Thread Starter
^^I'll check those things when I get home...I'll try cleaning it out, but it doesn't sit much. I suppose it could still be an issue.
post #8 of 28 (permalink) Old 03-24-2011, 04:39 PM
It's a virus because you touch yourself at night.
post #9 of 28 (permalink) Old 03-24-2011, 04:40 PM Thread Starter
Dude.........not just at night. Does that make a difference? (obligatory)
post #10 of 28 (permalink) Old 03-24-2011, 07:15 PM
beac83's Avatar
Sportbike: A couple
Once you get it to boot, you can do a CTL-ALT-DEL and select Task Manager.
Click on the PROCESSES tab and see what is gobbling up your processor time. There is a display column for % of processor used. If it's a program see which one it is. If the processor is 30% or more free (noted at the bottom of the page (windows Idle), then see if your HDD light is lit steadily.
If it's a HDD issue, try defragging it, or it may be very close to full.
That at least might give us a chance to be internet experts.
________________
beac83 is offline
post #11 of 28 (permalink) Old 03-24-2011, 07:23 PM
Stop at apple store on way home...... buy mac..... problem solved.
post #12 of 28 (permalink) Old 03-24-2011, 07:42 PM Thread Starter
It's working for now and we're busy with a bunch of stuff. If I don't get to checking through everything above tonight I'll get on it tomorrow for sure and let you know.
Thanks all
post #13 of 28 (permalink) Old 03-25-2011, 07:43 AM
Liberal Slayer
Achtung's Avatar
Sportbike: Yamaha R6
Years Riding: Not Long Enough!
How you found us: I saw smoke signals
While it's still running backup up all your data to a USB External Drive / Fob.
From the command prompt run a chkdsk -r (Note if it detects hard drive problems), Make sure you are not overheating it...Sitting in bed or on the couch with it on a comforter or something is not good. Consider an OS\app reinstall with the latest drivers.
If it's hardware it could be anything: Bad stick of RAM/Motherboard/ or failing hard drive.
Sounds like the machine ran an automatic chkdsk and repaired itself..That means a hard disk problem. Either it got jarred and corrupted a system file or it's failing...
Dont get a Mac unless you are running low on tiolet paper.
Achtung is offline
post #14 of 28 (permalink) Old 03-25-2011, 08:00 AM Thread Starter
It got really bad last night...two blues screens and two more complete lock ups in a matter of 20 mins. I was trying to wrap something up on it and finally just quit and went to bed.
I'll delve into everything tonight, but there's something really wrong with the thing.
Jon what am I looking for when I run a diagnostics check on the machine?
post #15 of 28 (permalink) Old 03-25-2011, 08:16 AM
My first test would be MemTest. Hop over here to get a copy - it's free.
http://www.memtest.org/
You'll need to get this onto a bootable USB key or burn the ISO to a CD to boot from.
Running this will accomplish two things.
1. It'll check your RAM and eliminate that as a possible culprit.
2. It'll take Windows out of the equation.
If you crash while running MemTest, you have a heat or hardware issue. If MemTest runs happily for 15-25 minutes without a crash, your RAM is good and heat most likely is not a culprit.
post #16 of 28 (permalink) Old 03-25-2011, 08:19 AM
Ryan's Avatar
Years Riding: Since 2001
Format hard drive, install Ubuntu, problem solved, for free.
Ryan is offline
post #17 of 28 (permalink) Old 03-25-2011, 08:47 AM
Ya, but I think you need to have a bone through your nose and a grass skirt to say "Ubuntu"
Guys its only a few years old, it shouldn't be having all these problems, maybe you should just take it back to the manufactures local store front and have their guys swap it out for a new one, and migrate all your data for you. Oh wait, you don't have a mac. carry on.
post #18 of 28 (permalink) Old 03-25-2011, 08:58 AM Thread Starter
If you don't have anything nice to say...........and all that shit.
post #19 of 28 (permalink) Old 03-25-2011, 09:18 AM
Shhhhhh.....
chadadams's Avatar
Sportbike: K6 GSXR600, 2012 Harley-Davidson XL1200N
Years Riding: I'm old. It's been a long time.
It sounds like a malware problem. Get a copy of malwarebytes anti malware. Install and run. Clean anything it finds. Then get a copy of CCleaner. Install and run. Do the registry analysis any fix anything it finds.
Both programs are free on the internet. Put them on a usb drive and move them to the infected machine.
If this doesn't work, lemme know....
CCS Amateur #133
K6 GSXR600
chadadams is offline
post #20 of 28 (permalink) Old 03-25-2011, 09:24 AM Thread Starter
^^run in safe mode right?
post #21 of 28 (permalink) Old 03-25-2011, 09:29 AM
Shhhhhh.....
chadadams's Avatar
If you can. If not, you can run in normal mode. THese apps will work either way....
CCS Amateur #133
K6 GSXR600
post #22 of 28 (permalink) Old 03-25-2011, 09:56 AM
yo quiero su taco
It runs a memory test. No need to install a 3rd party app for this. Dell includes it on their PCs. It will tell you it passed or it will start beeping displaying a code. Your issue sounds like a mem problem to me. The reason i say run this first is I would hate to see you format and reload when it didn't need it in the first place.
Next I would run chkdsk, be sure to run chkdsk /f. The /f fixes any errors it finds.
post #23 of 28 (permalink) Old 03-25-2011, 09:58 AM Thread Starter
Haha, I ran it last night, went to get ready for bed...came out of the bathroom and Vicki was bitching that the computer was beeping in the living room and she just clicked through a bunch of stuff. WHAT!? She didn't realize what I was doing...I just shut it down.
Ok, so if it was beeping what does that mean the next step is?
post #24 of 28 (permalink) Old 03-25-2011, 10:00 AM
You need to run it again and read the error messages.
post #25 of 28 (permalink) Old 03-25-2011, 10:02 AM Thread Starter
Sonofabitch...I bitched at her for a good 5 mins about that last night.
post #26 of 28 (permalink) Old 03-25-2011, 10:05 AM
yo quiero su taco
It means your mem or motherboard are bad. The Dell Diagnostics will display an error code and play a sequence of beeps. Note the error code and the sequence of beeps.
post #27 of 28 (permalink) Old 03-25-2011, 10:10 AM Thread Starter
Alright, I'll run it when I get home. Fack.
post #28 of 28 (permalink) Old 03-25-2011, 10:31 AM
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
Gone In 3 is offline
