Evo Users - Upgrade to Gingerbread Now! - Chicagoland Sportbikes
post #1 of 31 (permalink) Old 06-03-2011, 02:20 PM Thread Starter
Gingerbread has been released for the Evo.
If you're rooted & running stock, go here:
http://forum.xda-developers.com/show....php?t=1038701
You can also just update your radio, if you're running another ROM.
DO NOT update just the HTC kernel - there are reports that it horks WiFI & WiMAX.
post #2 of 31 (permalink) Old 06-05-2011, 07:52 PM
sooo.. i'm rooted and running CM7.. how do i get it?
post #3 of 31 (permalink) Old 06-05-2011, 08:08 PM
ahh just found the new stock ROM on clockworkmod.
do i need to upgrade the radio too?
post #4 of 31 (permalink) Old 06-05-2011, 08:57 PM
soooo.. i installed the new "stock" and it looks exactly like the OEM rom when i got my phone. ummm.. am i missing something here? says 2.3.3
post #5 of 31 (permalink) Old 06-05-2011, 10:36 PM Thread Starter
If you're on CM7, you're already on Gingerbread.
post #6 of 31 (permalink) Old 06-05-2011, 10:40 PM
plotts's Avatar
Sportbike: KTM 690 SM
Years Riding: A little bit.
When will we get it for non-rooted users? They sure are dragging their feet.
plotts is offline
post #7 of 31 (permalink) Old 06-05-2011, 10:46 PM Thread Starter
Right now. To access the update from the home screen/Menu/Settings/System updates/HTC software Update. This will initiate the upgrade process.
Sprint released it for manual download/upgrade on Friday & will push it OTA tomorrow. This is the schedule they had previously announced.
I was posting that folks had already dissected and rooted the manual download release.
post #8 of 31 (permalink) Old 06-06-2011, 05:13 AM
says im up to date?
post #9 of 31 (permalink) Old 06-06-2011, 07:44 AM
ya i just figured it would look more like CM7.. it looks just like Froyo.. lame.
post #10 of 31 (permalink) Old 06-06-2011, 08:47 AM
Bek.. should i do radio upgrade too?
post #11 of 31 (permalink) Old 06-06-2011, 09:11 AM Thread Starter
says im up to date?
Try again in a day or two... seems Sprint is limiting the rollout. There's a manual executable floating around somewhere, but I don't have it on hand.
The changes are all behind the scenes.
Yes.
post #12 of 31 (permalink) Old 06-06-2011, 10:40 AM
plotts's Avatar
Awesome, thanks!
plotts is offline
post #13 of 31 (permalink) Old 06-06-2011, 11:08 AM
ya i'll give it that it feels faster than CM7.. I'll try it for a few days and decide.
post #14 of 31 (permalink) Old 06-06-2011, 11:13 AM Thread Starter
Here is an article detailing where to get the Official Manual Download & how to install it.
http://www.androidpolice.com/2011/06...ual-ota-check/
post #15 of 31 (permalink) Old 06-06-2011, 11:43 AM
Sportbike: honda
Years Riding: 5 yrs
What about battery life? With light use, I can get 3-4 days on my extended battery. Hard to believe an ota would be faster, given it's 2x as fat (installation file).
highdren929 is offline
post #16 of 31 (permalink) Old 06-06-2011, 12:00 PM Thread Starter
I would argue that you really cannot make accurate comparisons like that. Unless each device is identical, is freshly wiped, has exactly the same configuration, and the same set of apps installed, any attempt at making comparisons is not worthwhile.
Also, just because an installation file is smaller or larger does not correlate its performance capabilities. For example, a ROM's installation file could be filled with dozens of wallpapers & ringtones... something that doesn't directly affect OS performance but will make the base file larger.
If you really want to assess whether the Gingerbread OTA is for you, you're best off researching under the hood at the fundamental OS differences between Gingerbread and Froyo. I should also point out that the Froyo upgrade was also mostly behind the scenes changes, but were rather significant due to the Dalvik JIT changes.
post #17 of 31 (permalink) Old 06-06-2011, 01:08 PM
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
Bek do you have a 30 sec explanation of how to do this?
Must be flashed through hBoot/Fastboot! Not Recovery.
Jordan
Loki047 is offline
post #18 of 31 (permalink) Old 06-06-2011, 01:10 PM
Sportbike: honda
Years Riding: 5 yrs
Bek, true, each individual's battery life is unique, based on what they use on the device. The better question would then be relative battery life. That is, relative to what he got with cm7. I'm suspecting they changed governors or governor sensitivity to make it more responsive.
@loki, that means it gets flashed using the bootloader, not the recovery program. ie PC36IMG.zip in the root of the sd card.
post #19 of 31 (permalink) Old 06-06-2011, 01:13 PM
downloading now OTA
post #20 of 31 (permalink) Old 06-06-2011, 01:30 PM
Loki047's Avatar
Sportbike: Z1000
Thanks - I need to look into that (I have no idea what that means)
Jordan
Loki047 is offline
post #21 of 31 (permalink) Old 06-06-2011, 01:35 PM
Sportbike: honda
Years Riding: 5 yrs
Power button + vol down after a power off will put you in the hboot menu.
post #22 of 31 (permalink) Old 06-06-2011, 01:53 PM
how does 2.3 not have the gingerbread keyboard?!?! OMG so lame.
post #23 of 31 (permalink) Old 06-06-2011, 01:59 PM Thread Starter
You sound like a twelve year old!
post #24 of 31 (permalink) Old 06-07-2011, 08:18 AM
totally.. i tried living with it for like 5 hours.. i went back to CM7
post #25 of 31 (permalink) Old 06-07-2011, 09:28 AM
Loki047's Avatar
Sportbike: Z1000
Give savege rom a try. GB FTW
Jordan
Loki047 is offline
post #26 of 31 (permalink) Old 06-07-2011, 07:59 PM
Another Polak
c2000's Avatar
Sportbike: '05 CBR 600RR
Years Riding: Since '04
This update is super lame.
Not faster (I did compare Myan's rom to stock EVO), no battery improvement, sense 1.1, breaks netflix, radio update doesn't help with the signal, and kernel breaks wifi and 4g. When click valume bttt sound got changed and cant keep up when going up and down, when you hit power switch they eliminated couple options, power off it's really a sleep mode. Better root that sucker and load some 3 party rom and kernel, you guys will be much happier.
PSN: chamala2000
Peter
c2000 is offline
post #27 of 31 (permalink) Old 06-09-2011, 07:57 PM
DRZ
CLSB's in-house hooligan
DRZ's Avatar
Sportbike: couple braaapers
Years Riding: 13 street years
How you found us: your mom
Send a message via AIM to DRZ
This new update is very buggy. My EVO is my work phone, bone bone stock, minimal apps bla bla bla, anyways....
I noticed when I'm using my Youtube app, it'll randomly just close completely. Also it keeps randomly acting as if I just tapped the power button, asking if I'd like to shut down, airplane mode, etc, even though I never pushed the power botton. Annoying. Had a few, coworkers complain about it being buggy. One guy has his Pandora app randomly quit, just like my Youtube app does. Another guy said his music got all jacked up. It would for example be playing The Beatles but be showing that a song by Metallica was on, hit next and it acts the same way. Another guy complained his phone was acting wierd after the update but didn't get into detail. Anyways, hope they fix this.
Take it to the STREETS!
DRZ is offline
post #28 of 31 (permalink) Old 06-11-2011, 12:34 AM
Another Polak
c2000's Avatar
Go to those apps what are doing FC's and hit clear data. That should help with the problem.
PSN: chamala2000
Peter
c2000 is offline
post #29 of 31 (permalink) Old 06-17-2011, 06:06 AM
i am a newbie don't kick my butt please
Sportbike: uihoyu
hi thanks for your information i am new here
monuis is offline
post #30 of 31 (permalink) Old 06-17-2011, 10:23 AM
plotts's Avatar
I can't see any differences between the previous version and this one, although my phone has acted weird on a few occasions, dropping calls, closing apps automatically etc. Not sure what was "upgraded".
Non-rooted EVO.
Oh, there is the handy green thing when typing now that shows you the zoomed text, thats, um, pretty cool?
plotts is offline
