window 7 install - Chicagoland Sportbikes
post #1 of 13 (permalink) Old 01-19-2012, 10:50 AM Thread Starter
window 7 install
trying to install win 7 on an older computer I know thats usually useless to do.
Got it loaded, and when it says starting windows for the first time, it goes to the "shut down" screen
Then, it reboots and goes black(you can't press F8) then reboots again in a loop.
put disc in and click repair, it says FAT error can't fix. Used windows 7 format and partition etc.....
this is on an older hp mediacenter computer. pentium D chip. 32 and 64 win 7 is the same. sata hard drive.
iz too tired to play with it. I might put win xp on it like it had orignally. To lazy to disconnect the card readers cuz theres so much addons with the media case. HP website looks lacking for drivers, even for XP.
post #2 of 13 (permalink) Old 01-19-2012, 10:54 AM
logtar's Avatar
Sportbike: CURRENTLY LOOKING
Years Riding: since I was 8
... why do I let myself get trolled!
Use Ubuntu! problem solved!
http://www.ubuntu.com/
Logtar - John
My Blog - @Logtar - Google+
logtar is offline
post #3 of 13 (permalink) Old 01-19-2012, 11:13 AM Thread Starter
I gonna be installing some USB devices. So i want to stick with microsoft.
post #4 of 13 (permalink) Old 01-19-2012, 11:31 AM
logtar's Avatar
Word of caution with USB and Windows 7, older devices will not work. So once you get it running get a VM running so you can actually interact with older USB devices.
Older PC though, you are way better off with XP. 7 will run like crap in old hardware. You are def trying to have a plane take off from a treadmill here.
Logtar - John
logtar is offline
post #5 of 13 (permalink) Old 01-19-2012, 11:37 AM Thread Starter
the usb device is brand new.
just the puter is 5 years old. I installed win 7 on an older puter, which had no problems before. Not sure why this one reboots automaticaly.
post #6 of 13 (permalink) Old 01-19-2012, 11:46 AM
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
Check minimum hardware requirements of Windows 7.
Gone In 3 is offline
post #7 of 13 (permalink) Old 01-19-2012, 01:00 PM
Most likely the hard drive is bad or going bad. Blocks where system files are stored have been corrupted and Windows cannot successfully boot. When you run the restore process it attempts to recopy over the system files but either the same files or different files will (seemingly) go bad at random.
Another possibility is the source data is bad; if it's a brand new W7 DVD then odds are slim that it's the media's fault. But the optical drive could be going bad and thus the data is getting corrupted during the installation as well. Hell, even the memory could be flaking out so that the data is being corrupted in transit.
post #8 of 13 (permalink) Old 01-19-2012, 01:03 PM
yo quiero su taco
whiteSeatEnvy's Avatar
Update your bios.
whiteSeatEnvy is offline
post #9 of 13 (permalink) Old 01-19-2012, 01:05 PM
Buy a Mac!
post #10 of 13 (permalink) Old 01-19-2012, 01:45 PM
What's the USB device? Most likely it'll work just fine in Linux. Oh, and my vote goes to http://www.linuxmint.com
Originally Posted by whiteSeatEnvy View Post
Update your bios.
Can't hurt, right?
post #11 of 13 (permalink) Old 01-19-2012, 09:52 PM Thread Starter
installed windows xp which is working so far.
did a real format which took 3 hours. stupid windows 7 does those quick formats that takes 10 seconds.
Now i just have to find a few drivers for the puter.
my main puter was acting up with the blue screen. I turned the cpu cache off, and hopefully it starts working again.
post #12 of 13 (permalink) Old 01-20-2012, 02:27 PM
It appears the full format during the XP install addressed your issues, so that tells me that HDD is on it's way out the door. The full format only masks the root issue, so I personally wouldn't trust any important data on that computer. But if it's just for using with the USB device then you'll probably be fine, until the OS refuses to load again some day.
post #13 of 13 (permalink) Old 01-20-2012, 02:32 PM
The real question is will the plane take off and if so, did Ron Paul help?
